Old 08-28-2012, 08:49 AM   #51
shawno72
C/10 junkie
shawno72's Avatar
Re: 1970 Longbed Build
I'll say. It appears to have turned your whole build into a Tahoe
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 08-28-2012, 08:49 AM   #52
Hart_Rod
Hart_Rod's Avatar
Originally Posted by dsigh View Post
Received the Wilwood rear kit. The difference is night and day.
Those look sweet! Could you post the part number? Thanks,
Hart_Rod is offline   Reply With Quote
Old 08-28-2012, 09:11 AM   #53
sighlurr
______________
sighlurr's Avatar
http://www.wilwood.com/BrakeKits/Bra...no=140-10094-D
Rear Brake Kit No.: 140-10094-D
Parking Brake Kit No.: 330-9371
sighlurr is offline   Reply With Quote
Old 08-30-2012, 11:57 PM   #54
sighlurr
______________
sighlurr's Avatar
I drove her for the first time in many months last night. Apparently the carb wasn't too happy with sitting for 6+ months. So now I've got to rebuild it before I can get it back on the road.
Buttoning up the rear brakes Sat AM and wiring my temporary trailer lights until the bed is finalized.
More pics to be added Sat afternoon. I can see the light at the end of the tunnel!!
Old 09-05-2012, 01:26 PM   #55
sighlurr
______________
sighlurr's Avatar
Lights, check.
Old 09-05-2012, 11:46 PM   #56
shawno72
C/10 junkie
shawno72's Avatar
It's good to hear its on the road again!! What are your plans for the bed?
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 09-06-2012, 12:21 AM   #57
sighlurr
______________
sighlurr's Avatar
I've got my eye on a couple of really clean ones. It's a matter of me finding the time to pick one up, then drop it off at American Stripping Co. to strip and prime.
Old 09-06-2012, 01:42 AM   #58
VA72C10
VA72C10
VA72C10's Avatar
Project is looking great! Love the look of a lowered longbed!
Old 09-06-2012, 02:32 AM   #59
sighlurr
______________
sighlurr's Avatar
Thank you sir. Kinda goin' against the grain with the LWB.
Old 09-07-2012, 01:59 AM   #60
sighlurr
______________
sighlurr's Avatar
Ran the fuel line, installed filter and filler tonight. Tail lights are now wired and I've got functioning turn signals, brakes, and signals!
I need two braided lines for the rear brakes, bleed them and I should be good to go.
Old 09-12-2012, 03:28 AM   #61
sighlurr
______________
sighlurr's Avatar
Driver's side axle seal started leaking last Friday. Pulled the cover tonight and found some metal shavings. Removed the axles and found that the metal flakes were coming from behind the ARP studs from when they were installed. Cleaned both axle tubes out with brake cleaner, some rags, and a mop handle. Hosed out the diff and put it back together.
Baby steps.
Old 09-12-2012, 09:18 AM   #62
shawno72
C/10 junkie
shawno72's Avatar
Whew at least the metal shavings weren't the bearings.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 09-12-2012, 10:34 AM   #63
FrankieD
FrankieD's Avatar
Nothing wrong with a long bed! I have one but not doing as much as you are. Nice job on the frame work. How do you keep tha floor so clean a little OCD going on? Hope you got your money back on the parts that didn't work.
94 k2500 EXCab Long Bed 350ci New Toy
95 K2500 Suburban New PlowTruck 454ci
Support our Troops @ http://anyairman.com
http://www.woundedwarriorproject.org/
FrankieD is offline   Reply With Quote
Old 09-12-2012, 11:32 AM   #64
sighlurr
______________
sighlurr's Avatar
Talking Re: 1970 Longbed Build
Thanks Frank. And no, you're not the first person to make OCD comments. Everything has a specific place! Right?
I ended up taking a bath on the CPP garbage, but I was expecting that. I ended up CL'ing the kit and got $450 for something I paid close to $900 for. Couldn't stand the thought of putting anymore of their stuff on this truck, and will only use Wilwood for the front.
It's all good. Lesson learned.
Old 09-12-2012, 11:35 AM   #65
FrankieD
FrankieD's Avatar
Only in the house other wise the wife would hang me but the garage and basement are not so much.
Old 09-12-2012, 12:23 PM   #66
shawno72
C/10 junkie
shawno72's Avatar
Doesn't everyone have OCD? I have it but my wife is the opposite, we have a lot of fun with it
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 09-12-2012, 12:39 PM   #67
FrankieD
FrankieD's Avatar
My wife wishes I did. I suppose I could use a little bit then I might be able to find stuff
Old 09-13-2012, 01:00 PM   #68
sighlurr
______________
sighlurr's Avatar
Gentlemen, last night was huge for me! Nate helped me with a one-off set of conical bushings, a little thinner than what he sells with his kit. Perfect for his trailing arms, and the CPP carrier xmember.
Tightened up the trailing arms, bled the brakes, and sealed the fuel cell. After a full tank, I went out for the maiden voyage. I'm loving the 3.08's and this 4 speed on the freeway. Rolling at 80MPH was great and I didn't feel like I was kiling the motor.
Now I need to look into setting the thrust angle. I've got the trailing arms adjusted all the way in now, so it may be as good as it's going to get.
Old 09-13-2012, 02:15 PM   #69
shawno72
C/10 junkie
shawno72's Avatar
Looks really good. Are you running a four on the floor? I got to get that 3.08 rear end in mine soon. The 3.73's limit me to about 60mph without killing the motor.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 09-13-2012, 02:39 PM   #70
sighlurr
______________
sighlurr's Avatar
Thanks bud.
4 speed on the floor with a granny low.
Old 09-13-2012, 02:43 PM   #71
shawno72
C/10 junkie
shawno72's Avatar
Thanks bud.
K that makes my 3.08 rear end install a top priority.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 09-13-2012, 11:19 PM   #72
sighlurr
______________
sighlurr's Avatar
Got her tucked in tonight for the first time in many many months. Wet sanded the back of the cab and ordered a set of re-pop'd hood hinges today.
I think I've found my bed. The guy claims it's a 9.5/10, no extra holes and the floor is solid (metal). I'll probably go pick that up in the next couple of weeks and get it blasted by American Stripping Co. in Sacramento.
Making some progress. Kind of feel like she's had a butt lift and tummy tuck, but still has a buckled face and jacked teeth.
Old 09-13-2012, 11:38 PM   #73
shawno72
C/10 junkie
shawno72's Avatar
I know what you mean. My passenger side door has what I like to call a bad scar, an area where the repaint has peeled of revealing the original red paint. Luckily I have decided that when I get her painted I will go with the original red.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 09-14-2012, 12:11 AM   #74
sighlurr
______________
sighlurr's Avatar
Don't wait to get it repainted, knock down the white and red with 1k wet grit and rattle can over it with some white primer. Sand it down and you'd be surprised how much better it will look....
Old 09-14-2012, 12:49 AM   #75
D-Bo
D-Bo's Avatar
You should just only look at her from the back. I'm only going to look at mine from the front until I get the rest of the paint done. It's the only reasonable way to be happy. Seriously though, it'll be a shame to get a bed on there to cover up all that nice work. Plexiglass bed floor???
D-Bo
70 GMC 3/4 ton
Vortech 350
D-Bo is offline   Reply With Quote
