Old 08-28-2012, 08:28 AM   #526
FrankieD
FrankieD's Avatar
Re: Project "What was I Thinking" 68 SWB
Originally Posted by Bennett--G4L View Post
Thank you.
Don't have any pictures from this weekend but we started working on welding up my rear window seam that was rotted out. My brother is tig welding it and it is a PITA. There is some thin metal there and we may have to cut out and redo some sections. Also will have to pick myself up a stud gun cause it is starting to warp in some areas from the rotisserie. We should have welded up the back window before mounting it to the rotisserie and flipping it on its front to finish the floor. It was really frustrating, I really wish I had started with a rust free cab
Rust sucks probably the biggest problem with these trucks. Mine came from California but compaired to midwest trucks it is 99% rust free.
94 k2500 EXCab Long Bed 350ci New Toy
95 K2500 Suburban New PlowTruck 454ci
Support our Troops @ http://anyairman.com
http://www.woundedwarriorproject.org/
FrankieD is offline   Reply With Quote
Old 08-28-2012, 10:38 AM   #527
Bennett68C10
Bennett68C10's Avatar
I'm trying to keep my spirits up and not let this rust conquer me. It is the last of the rust left to fix.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 08-28-2012, 10:49 AM   #528
gringoloco
A guy with a truck
gringoloco's Avatar
...It is the last of the rust left to fix...
Then it's all downhill and you get to do more of the 'fun' stuff. There's something truly gratifying about knowing that your truck is completely rust free. Just drop your head and trudge through--it'll be over soon enough
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 08-28-2012, 01:32 PM   #529
Bennett68C10
Thanks for the encouragement buddy, it's just frustrating that 2 years of this build has been spent just fixing rust. I keep kicking myself, if I would have been patient and bought a rust free truck it would be done by now and I would be able to enjoy it. I'm just venting a little, sometimes you just have too.
Keith
66 Suburban
IG: bennett68c10
Old 08-28-2012, 02:35 PM   #530
Zoomin
Man of Mini-Talents
Zoomin's Avatar
I know how you feel. Sometimes for every step forward, you have to take two back. I know when I go to car shows now after having built a few, I have a whole new appreciation for the blood, sweat, tears, time and money that goes into these rascals.
Keep it up, your reward is going to be awesome.
Zoomin is offline   Reply With Quote
Old 08-28-2012, 03:21 PM   #531
Bennett68C10
Thanks, part of my problem is I want that reward now lol. I have to learn to be more patient.
Keith
66 Suburban
IG: bennett68c10
Old 08-28-2012, 03:27 PM   #532
FrankieD
FrankieD's Avatar
I'M ALMOST THERE BUT i HAVE TO KEEP KICKING MYSELF IN THE BUTT TO KEEP GOING
So just keep on TRUCKIN
Old 08-28-2012, 06:54 PM   #533
Bennett68C10
Thanks I will
Keith
66 Suburban
IG: bennett68c10
Old 08-29-2012, 10:33 PM   #534
Bowtie468
Bowtie468's Avatar
Yep it will be worth it ! Keep up the great work Keith
Chris
click here to see my buildpage
http://67-72chevytrucks.com/vboard/s...d.php?t=394656
1979 C10 Silverado Big10 SWB
Factory 454/400
Cardinal Red/Santa Fe Tan (original paint)
1969 Camaro X44 LS swap
1968 C10 SWB Fleetside (SOLD)
468BBC MultiPort TPI / Dynamic EFI P4
Black/Black
1963 Nova SS convertible (SOLD)
194 I6/ PowerGlide
Bowtie468 is offline   Reply With Quote
Old 08-30-2012, 03:00 PM   #535
7dee2
7dee2's Avatar
Hey Keith didn't you have your Coys for sale? The link I sent a buddy is now dead.
Thanks,
Brett
67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594
72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.)
72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 08-30-2012, 03:13 PM   #536
Bennett68C10
Thanks Chris
Keith
66 Suburban
IG: bennett68c10
Old 09-02-2012, 01:47 PM   #537
gringoloco
A guy with a truck
gringoloco's Avatar
Quick question, as I'm soon to be needing them, too: what did you use for lower shock mounts up front?
-Chris
Old 09-02-2012, 09:53 PM   #538
Bennett68C10
I used the lower shock studs that came with my porterbuilt arms and shocks. The stud bolted to the arm and the shock bolted on the stud. Did you get your arms yet? Your using different shocks right?
Keith
66 Suburban
IG: bennett68c10
Old 09-03-2012, 09:35 AM   #539
gringoloco
A guy with a truck
gringoloco's Avatar
Arms should be here tomorrow. I did not order their shocks, as I'm using Bilsteins- dunno if they sent the studs or not. Was just curious, as I noticed that the mount is single shear, but hadn't seen any mention of how the shock mounts...
Thanks again for the info- you are most helpful
-Chris
Old 09-03-2012, 06:45 PM   #540
Bennett68C10
Anytime buddy if you don't get the studs with the arms just email Nate, he will send them right out to you.
Keith
66 Suburban
IG: bennett68c10
Old 09-03-2012, 07:34 PM   #541
Bennett68C10
Well this weekend I worked on switching out my stock trailing arm crossmember for the Porterbuilt tubular 2pc driveshaft one. I have to say I hate rivets, a total of 14 in the stock crossmember, boy it sucked. I will be running a 2pc driveshaft so it gave me the reason to switch over.
Also my brother welded up the bottom of my rear window channel and also started shaving my firewall by welding in most of my porterbuilt kit. Forgot to take pictures again, I will get some next weekend.
Keith
66 Suburban
IG: bennett68c10
Old 09-03-2012, 09:47 PM   #542
gringoloco
A guy with a truck
gringoloco's Avatar
You should try it with the cab on! Bring on the pics...
-Chris
Old 09-03-2012, 10:10 PM   #543
Bennett68C10
Yeah I wanted nothing to do with that will get some pics up next weekend
Keith
66 Suburban
IG: bennett68c10
Old 09-06-2012, 10:49 PM   #544
HotRod C/10
HotRod C/10's Avatar
Got my rear axles swapped out and my coys mounted. They are 20x10, 5.5" bs with Yokohama Advan ST 295/40/20.
How hard is it to swap the rear axles? dont have to mess with resetting the carrier unit do you?
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 09-06-2012, 11:31 PM   #545
Bennett68C10
Mine was easy, just pulled the c-clips and pulled the axles out. Put new seals in the rear and replaced axles. I did one axle at a time, didn't have to mess with the carrier.
Keith
66 Suburban
IG: bennett68c10
Old 09-06-2012, 11:32 PM   #546
HotRod C/10
Just what I wanted to hear!......Thanks for the response.
LS SWAPPED
-1976 SILVERADO
Old 09-06-2012, 11:37 PM   #547
big_al_71
big_al_71's Avatar
keith im looking forward to the picts.......
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 09-06-2012, 11:41 PM   #548
Zoomin
Man of Mini-Talents
Zoomin's Avatar
X2.
Old 09-07-2012, 08:12 AM   #549
Bennett68C10
X2.
I'll make sure I get some this weekend for you guys
Keith
66 Suburban
IG: bennett68c10
Old 09-07-2012, 08:57 AM   #550
HotRod C/10
is it posi?
LS SWAPPED
-1976 SILVERADO
bbc, dropmember, intro wheels, porterbuilt
