Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 08-31-2012, 10:08 AM   #126
BRASSHEAD
BRASSHEAD's Avatar
Re: '62 GMC Suburban "Rust"oration, Patina Build.....
I would like to see more on the front crossmember. Everything looks great.
BRASSHEAD is offline   Reply With Quote
Old 08-31-2012, 11:40 PM   #127
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
It's almost done ... working on a buddy's boat this weekend.
Will have a full spread on it soon...
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 09-09-2012, 09:43 PM   #128
Andyboy
Andyboy's Avatar
Looking good. Can't wait to see the how-to on cross member, doing my soon.
Andyboy is offline   Reply With Quote
Old 12-11-2012, 06:28 PM   #129
notsolo
notsolo's Avatar
Originally Posted by ChiefRocka View Post
After installing, I noticed the underside FRONT TWO bolt holes line up perfectly, and well as the upper a-arm studs are close, as well as indintations for a-arm clearance.
After checking Mark's how, and chatting with him....he seems to recall the REAR hole lineing up.....Hmmm ?? He also mentioned he did his 15 yrs ago, and doesn't recall exactly ...
I never did mark the spindle location to ground, so I'm gonna slide the torsion frontend back on to get a measurement, no biggie...
UNLESS SOMEONE HERE CAN CONFIRM THE FRONT TWO ARE CORRECT ??
Reguardless, I'm gonna take a lot of pics to add to Mark's How-to
Center Front A arm stud to center radiator support hole is 22 1/4 on mine. Donor was an 82..
notsolo is offline   Reply With Quote
Old 12-13-2012, 10:33 AM   #130
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
The HOW TO can be found here:
http://67-72chevytrucks.com/vboard/s...d.php?t=543729
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 12-13-2012, 10:41 AM   #131
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Not much progress, but some is better than none .....
Front A-arms diassembled and off to coating. Wasn't planning on coating the A-arms, but since the guy is just right across the parking lot, and I threw them with a bunch of other parts from a customer build.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 12-13-2012, 10:52 AM   #132
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Crossmember done, awaiting blasting ...
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 12-13-2012, 06:08 PM   #133
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
Cool! Be glad you have progress!! I am hoping to do more on mine the suburban population has grown!
gostranger is offline   Reply With Quote
Old 12-14-2012, 06:32 AM   #134
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
It has !
I got these last night from my machinist ...
He enlargened the openings to except the previously made bungs to convert to 88-98 LBJ's....
Weld the rings in and weld/smooth out spotweld drill marks (from removing the super tall, drop restricting, bump stop mounts)....then off to coating !
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 12-14-2012, 08:15 AM   #135
robber grin
Post Re: '62 GMC Suburban "Rust"oration, Patina Build.....
22 3/8" on my 62 C10's conversion done with a 78 1/2t 2wd burb clip
robber grin is offline   Reply With Quote
Old 12-14-2012, 05:57 PM   #136
Dinos63
chevy only
Dinos63's Avatar
cool stuff !
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 12-16-2012, 11:14 AM   #137
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Originally Posted by Dinos63 View Post
cool stuff !
Did you ever get my addy ??
Welded these up last night at ACC ....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 12-16-2012, 11:39 AM   #138
Dinos63
chevy only
Dinos63's Avatar
no? nice work kat nice work
Old 12-16-2012, 11:55 AM   #139
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
You PM'd me wanting my addy ... I'll send it again !!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 12-16-2012, 08:01 PM   #140
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Looks like RockTonka has my seats, wrapped and ready to ship !!!
Thanks PHIL !!!
Time to get some bids on shipping ....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 12-17-2012, 12:58 AM   #141
Captainfab
60-66 Nut
Cool
Did you happen to measure the ID after you welded them to see if they shrunk any? That is something I have been wondering about when I do mine.
Old 12-17-2012, 09:54 AM   #142
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I did not, but I did temporarily press in a BJ, and it went in perfect...with a nice "press fit".
Few pics from Rich ....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 01-02-2013, 03:39 AM   #143
54Caddy
GM Addicted
54Caddy's Avatar
what is the point of the 88-98 lower balljoint?
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 01-03-2013, 02:34 AM   #144
Captainfab
60-66 Nut
You have to use the '88-'98 lower ball joint if you are going to run the '88-'98 spindles and the factory style 6 lug rotors. Most guys that use these conversion parts, use a '67-'72 C20 lower control arm. But Chief wanted to use the '73-'87 control arms with the rubber bushings, so this is how to make that happen. I will be doing the same thing on my '66 Burb. The Chief just beat me to it.
Old 01-03-2013, 02:56 AM   #145
RockTonka
RockTonka's Avatar
Thanks PHIL !!!
I'm stoked they're going to a good home...any more progress on the burb??
Don't let the new shop take over ALL your time...
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 01-18-2013, 09:36 AM   #146
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Unfortunately, it has !
The only new thing lately is the A-arms have been coated a satin chassis black.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 02-11-2013, 01:34 AM   #147
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Dude! I haven't been on the forum for quite a while. This is the first time I saw your build. Excited to see what you're doing with this thing. It might even be a little motivation for me. Hopefully we can get these burbs back together and on the road soon.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 02-11-2013, 05:54 PM   #148
MikeS.
MikeS.'s Avatar
"Hopefully we can get these burbs back together and on the road soon."
Man I so agree, mine is getting closer every day.
Chief, keep plugging away.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 02-28-2013, 08:21 PM   #149
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Well ... I figure I work on my own stuff a day or so every couple months...
I dont have too much to report, other than I sandblasted and painted my spindles, oooooweeeee ! :
And most Importantly, I finally had the extra $$ to have the pallet of Suburban seats shipped to me from OKC !!!
I used "Uship" to get some quotes, and it was actually pretty reasonable !!
Should see them within 5 business days, cant wait to get them.
Rocktonka took the time to make sure they were well wrapped...
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 03-09-2013, 09:28 AM   #150
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Well last week I contacted "U-ship" to get some bids going on shipment of the Burb seats I purchased from Rocktonka....
After about 2 weeks total (bids accepted/shipping), they made it safe and sound !!
Rock swears the drivers seat was perfect when it left him ....
I went from NO seats, to all three rows !
Turns out, this material is still made....Might have to look into that soon.
One step closer...
BIG THANKS AGAIN TO ROCKTONKA FOR ALL HIS HELP AND PATIENCE !!!!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
