California Rod And Customs 68 C-10 build
Just posting some pictures of a project that we are building for a customer
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() [I MG]http://i30.photobucket.com/albums/c328/dirtydeedss/DSC_0531.jpg[/IMG] ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() [IMG]http://i30.photobucket.com/albums/c328/dirtydeedss/DSC_0446.jpg Toyota FJ Cruiser 8" headlights with custom headlight buckets ![]() ![]() Bumper has been finish welded ![]() ![]() ![]() Under valance area where the power steering resivoir and coolant overflow are mounted ![]() ![]() Inner passenger fender almost done, ![]() ![]() Bottom side of the hood ![]() Hidden hinges with gas struts mounted behind the firewall ![]() Valance set on to show dimples for rad cap, and resivoir caps ![]() ![]() ![]() Handmade new hood peak ![]() ![]() The factory hood peak for reference ![]() ![]() finish welded inners ![]() Bottom valance ![]() Heres the guages and heat/ac controls ![]() ![]() ![]() ![]() ![]() Pedals with under dash hydro boost brake master ![]() Heres the drivers seat mounted, all computers/Electronics for the engine, transmission, air ride ect are mounted under the seat. The seat has a release button on the side of the seat base for the hinge set up for easy acess to the wiring. We used gas shocks to hold the seat in the up position ![]() ![]() ![]() ![]() Drivers inner fender ![]() steering shaft coming out of firewall ![]() ![]() |
Re: California Rod And Customs 68 C-10 build
Heres a couple pictures i forgot, The cowl welded on to the cab, the passenger wiper hole has been re located
![]() ![]() Heres a rendering done by Carter Hickman Designs, ![]() Flush mount gas filler ![]() ![]() ![]() ![]() Updated pictures of the box and wheel tubs ![]() ![]() ![]() rear full roll pan ![]() ![]() New rear box corners ![]() ![]() Pancaked the roof and modified the roof peak ![]() ![]() bear claw door latches installed ![]() ![]() heres a pic of the 90* hydrobrake and the a/c ![]() |
We took the truck to the World of Wheels show in abbotsford this past weekend, truck took the under construction award.
Heres the turn signal/ park lights on the front ![]() A/C and heater lines going into the cab ![]() We got the hood hinge holes all filled in and made valve cover vent lines ![]() ![]() heres the not finished console with the flip up stereo faceplate ![]() ![]() shot of the under bed area ![]() rear bumper/ licence plate mount finished ![]() exhaust cutout ![]() ![]() rear brake line and fuel line through frame fittings ![]() we notched the bottom of the cab to clear the driveshaft ![]() under passenger seat, engine fuse box, battery shut off and stereo mount ![]() custom battery mount ![]() exhaust over the rear end ![]() Finally some updated pictures for you guys A few shots of the engine, we painted everything the same coulor and used a flat clear on the drive set up and tops of the valve covers ![]() ![]() ![]() intake bodyworked and painted ![]() ![]() Parts waiting to be installed ![]() ![]() Heres the box in the booth ready for paint ![]() Rear bumper ready for paint ![]() ![]() Cab sandblasted and the chassis all welded and ground. ![]() ![]() And lastly the transmission ![]() |
Rusty Nuts
that is some nice metal work, keep posting pics i like to see it to the end
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
![]() Join Date: Jan 2012
Keep it up. I am digging some of the mods...
'68 Longbed Stepper. Mango Tango |
Amazing work! I really like those headlights with the integrated parking lights/turn signals.
2002 Silverado 2500HD LB7 CCSB LT EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's 2004 Tahoe LT 2006 Silverado Z71 LS 1971 Chevy C10 |
Junior Member
Beautiful. Someone has some cash.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
There's some neat mods there.
Must be rough to have a shop like that!
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
1972 K20
![]() Join Date: Apr 2008
Let me start off by saying "WOW" the execution and craftsmanship are over the top. That truck will be a show winner for sure. The bumpers fit the 67-68 body lines well... maybe not so much on the 69-72 years. Keep us updated on your project as the pictures of your work are inspiring... to me!
Bud |
nice fab work. I love the gas filler.
But you cant drop the tailgate. how are you gonna load kegs in the back of that thing? |
Amazing. Looks built from scratch.
Old member
Dang! That is one sweet looking truck! It want be long and we will see it on a cover of a mag! Well done sir.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Looks amazing. I wish I had the time and tools to do all that metal work.
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins |
#15 |
Amazing!! Finished pics a must have....
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
#16 |
dayum
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 1972 Chevy SWB Highlander OLIVE Build thread coming |
#17 |
Laid Back
![]() Join Date: Apr 2010
Wow!!
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
#18 |
That metal work is really awesome!!!! suscribed i will be following up this one closely...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#19 |
Frequent Flyer
Killer!
#20 |
Florida Edition
![]() ![]() Join Date: Oct 2010
I'll ride with ya.....
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#21 |
![]() Join Date: Oct 2005
WOW!.....somebody's got deep pockets!
Beautiful work!
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
#22 |
Never Ending Projects
Glad to see you made it over from the HAMB board. I hope the link I posted got you over here. The HAMB can be a little rough if you don't meet the traditional pre '65 vehicles.
Welcome and like I said over there, AWESOME work!!!
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#23 |
body work alone probably cost as much as my house!
gorgous truck! cant wait to see it finished!
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! ![]() 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 |
#24 |
Beautiful work, I would like to see some pics of the frame without the body to see all the mods and suspension work. Cant wait to see more of this one!!
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
#25 |
![]() ![]() Join Date: Jul 2002
Very nice!
