Old 12-22-2012, 02:59 AM   #1
cmyc5575
Please help...
Got off work tonight and managed to start the truck no problem but as I was headed home my cluster lights got dimmer and dimmer unit they shut off along with the head lights and turn signals would stay solid when trying to be used then the seat belt buzzard lit up and was buzzing until I got home. Parked it shut it off then tried starting it again and wouldn't try turning over. What would cause this any help much appreciate since I have to work again tomorrow. Thanks
cmyc5575 is offline   Reply With Quote
Old 12-22-2012, 03:13 AM   #2
dieseldawg142
dieseldawg142's Avatar
Re: Please help...
sounds like your alternator is'nt charging your battery, your headlights sucked all the juice out of your battery. check your connections first, then test or replace your alt.
dieseldawg142 is offline   Reply With Quote
Old 12-22-2012, 03:15 AM   #3
cmyc5575
Re: Please help...
Ok what connections am I suppose to look at?
Old 12-22-2012, 03:22 AM   #4
rcbildr
rcbildr's Avatar
Re: Please help...
Check the belt and make sure it's there and check tension too. Start with the battery connections, then go down to the starter, and then to the back of the alternator. If they all look good and are tight pull the alternator and have it checked at a parts store. Another check is to put a voltmeter on the battery terminals just after you start the engine and see what voltage is there...check the battery voltage with the engine off first to give you a base line. With the engine running it should be around 13-15 volts, and with the engine off just over 12 volts.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 12-22-2012, 03:28 AM   #5
cmyc5575
Re: Please help...
Ok I'll do it. To dark now. What do u think a alternator will cost for an 82?
Old 12-22-2012, 03:48 AM   #6
dieseldawg142
Re: Please help...
x2 what rcbildr says, also check the battery voltage. i replaced my alt. couple years ago,90 amp- $100, but i live north of the border. depending on how many amps, you should be able to pick up an alt. from about $40 up
Old 12-22-2012, 04:41 AM   #7
86c20
86c20's Avatar
Re: Please help...
check also the where the main harness goes in the cab. have had a lot of weird problems there. 2 red wires feed everything
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 12-22-2012, 03:16 PM   #8
cmyc5575
Re: Please help...
So I replaced the alternator for about 35 bucks. The tested the old one at the store and said it passed but the bearings went bad. Could this chase issues to even tho it passed?
Old 12-22-2012, 06:51 PM   #9
cmyc5575
Re: Please help...
bump. could the blown bearings on the alternator cause issues even with it passing the auto parts store tests?
Old 12-22-2012, 07:42 PM   #10
krazy_texan
krazy_texan's Avatar
Re: Please help...
Don't think so unless the pulley was seized preventing it from spinning
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 12-22-2012, 07:52 PM   #11
cmyc5575
Re: Please help...
Well the pulley was causing it to spin so idk what else could cause it. I did make it to work with it today maybe there is some kind of freak accident going on with it. I just find it hard to believe what the store manager told me about the bearings going bad causing it to not charge the battery, and I hate to question the guys knowledge of vehicles but this is my only d/d.
Old 12-22-2012, 07:53 PM   #12
68Timber
I know the pieces fit
68Timber's Avatar
Re: Please help...
Did you check the belt?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 12-22-2012, 07:58 PM   #13
cmyc5575
Re: Please help...
[QUOTE=BRUISER;5772856]Did you check the belt?
Posted via Mobile Device[/QUO
Yeah the belt is spinning the new alternator I put on just fine. Im wondering why my old alternator that I already took back was not charging my battery, when it passed the stores tests and the only thing that was bad in the darn thing was the bearings.
