Old 01-10-2013, 03:39 PM   #1
JOJABOY
69 - 70 Pointer and Shift Indicator
Maybe I just need a class on how to thoroughly search the forum for what I am looking for. Normally, I won't ask until I have exhausted at least three days looking. Ha-Ha.
I am working on my steering, steering column and wheel. I have found most of what I needed to know from everyone's wealth of knowledge. However, I can't seem to find information on the 69-70 shift pointer.
I found the part for the pointer and for the fiber cable at ClassicParts. I know where the fiber cable attaches to the bracket on the light bulb. What I am trying to find out is:
a. How does the fiber cable snap into the pointer? Should there be some kind of rectangular lens in the pointer? How does the pointer attach to the column? Does it simply snap in?
b. Where can I buy a replacement shift indicator? (plastic lens part) I can only find the one for 71-72 on line. I need the one with L1 and L2.
JOJABOY is offline   Reply With Quote
Old 01-10-2013, 03:52 PM   #2
70cst
70cst's Avatar
Re: 69 - 70 Pointer and Shift Indicator
Hope this helps ...
Shift Indicator adjustment
http://67-72chevytrucks.com/vboard/s...d.php?t=555640
How does the shift indictor pointer........
http://67-72chevytrucks.com/vboard/s...d.php?t=265046
fiber-optic cable
http://67-72chevytrucks.com/vboard/s...d.php?t=400468
Where does the fiber optic cable go???
http://67-72chevytrucks.com/vboard/s...d.php?t=243532
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 01-10-2013, 04:23 PM   #3
JOJABOY
Does the insert that the fiber cable hooks to from 71-72 model also fit the pointer for the 67-70 model? I have looked at Brothers, Truck Shop, Classic Parts and LMC and can't find a solid answer.
Also, still wondering about shift indicator (insert not housing) with L2 and L1?
Old 01-10-2013, 04:32 PM   #4
70cst
70cst's Avatar
Give WES a call at Classic Heartbeat. He can tell you and he has tons of parts.
http://www.classicheartbeat.com/
Old 01-10-2013, 07:30 PM   #5
JOJABOY
I will try to give them a call. Their website is void of any 67-70 model year pointers and indicators. It's a mystery....kinda like how many licks it takes to get to the center of a Tootsie Pop. The world will never know.
Old 01-10-2013, 07:44 PM   #6
70cst
70cst's Avatar
WES knows these trucks...if he doesn't have the parts he will send you in the direction to locate one (I hope). By the way ask him about the Hot Dog
Old 01-10-2013, 09:40 PM   #7
Longhorn 70
Longhorn 70's Avatar
Attachment 1038993
As I recal LMC has them but as I further recall, the last time I ordered one it was backordered.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 01-11-2013, 01:35 AM   #8
JOJABOY
OK....so I found the 67-70 pointer housing on various websites. I have also found the fiber optic wire. I am still looking for the rectangular lens piece that the fiber optic wire plugs into inside the pointer.
Also, I am looking for the indicator lens. Are these pieces not produced? Is this something I am going to have to go to a donor vehicle to find?
Someone has to of climbed this mountain before me.
Old 01-11-2013, 12:07 PM   #9
LockDoc
The Older Generation
LockDoc's Avatar
Here is a web site that lists them for cars. They might be the same, looks like it.
http://www.shiftworks.com/lens.htm
I would presume the measurements are the same for the two listed there. Be sure and post back in this thread if you get one and it works OK.
LockDoc
Leon
Old 01-11-2013, 01:28 PM   #10
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I got my fiber optic, pointer, pointer lens and indicator from a 75 van at the wrecking yard. They are identical to the truck
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 01-11-2013, 01:45 PM   #11
JOJABOY
The van's are identical to the 71-71 pick ups but not the 67-70. The shift indicator from the 67-68 Camaro is the closest I can find. The lens from the Camaro is 1/4" wider than that of the 67-70 C10 but the curve looks close. I think i can grind the edges a little and it will slide right in the truck housing.
I called around this morning. Apearantly, no one ever made a reproduction indicator lens for 67-70 and the pointer housing has been discontinued. I see modifications in my future.
Old 01-11-2013, 02:57 PM   #12
Longhorn 70
LMC has the pointer housing in stock. eBay has them too for about the same price after shipping. They say they have the Fibre Optic but no pointer.... I have ordered one and I'll figure something out for the pointer.....
Old 01-11-2013, 04:38 PM   #13
JOJABOY
My boss is telling me to get back to work and stop researching shift indicators. Ha-Ha-
I think I am going to order both pointers (parts #7 & #8 from LMC). I think that if push comes to shove I can modify and make the parts work. Even if I have to take the illuminating part out of part #8 and put it in part #7. Or even trim and make part #7 work on my column.
As for the indicator dial....I am having my housing re-chromed and am going to order the indicator lens from a 1967 Nova. I will post a photo once parts come in and I get it put together.
Old 01-30-2015, 11:55 PM   #14
muckyp
muckyp's Avatar
I know this is kind of an old thread, but did anyone ever find the 67-70 fiber optic indicator piece? Or figure out a solution?
70 SWB 454/TH400
muckyp is offline   Reply With Quote
Old 01-04-2017, 05:03 PM   #15
nicklear36
nicklear36's Avatar
I would like to resurrect this thread because I am in search for the same rectangular piece that the fiber optic wire plugs into.
nicklear36 is offline   Reply With Quote
Old 01-05-2017, 10:38 PM   #16
70STOVEBOLT
70STOVEBOLT's Avatar
It's not just a rectangle, it is L-shaped. Here is a pic of the NOS fiber optic cable assembly I bought off eBay. The part number is 6291357.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 01-06-2017, 07:56 PM   #17
nicklear36
nicklear36's Avatar
Thanks I will be on the lookout for one of those
Old 11-03-2018, 10:50 AM   #18
68ihscout
Does anyone make that clear end for the fiber optic wire ,that is what i am missing anyone make their own ,any input will be great fully appreciated..
68ihscout is offline   Reply With Quote
Old 05-01-2019, 01:26 PM   #19
7-D Stepside
Does anyone know if the 71-72 pointer/housing (non-tilt) will work on the 67-70 columns? LMC lists a different part number for the fiber optic cable for the 71-72, so I suppose I would need that one to go with it. Would the bulb holder be the same? The PO had removed all four of these parts, so starting from scratch.
7-D Stepside is offline   Reply With Quote
Old 01-05-2020, 12:17 PM   #20
Montierth
Montierth's Avatar
Keeping this old thread alive..... Did anyone ever find a source for the pointer insert for a 69-70 non tilt? It is easy to find the fiber optic cable and the 1969-70 Column Shift Pointer Housing-w/o Tilt. Strange that no one reproduces this small part.
1970 GMC C1500 short fleet
Sellers Regret
- 1950 GMC
- 1967 Chevy C10
- 1970 GMC C2500 Dually Flat Bed
- 2003 Silverado
Montierth is offline   Reply With Quote
Old 01-24-2020, 12:45 AM   #21
Montierth
Montierth's Avatar
Well after having 2 1970s I thot I would dig through some old boxes of parts and found 2 pointers for 69 to 70 c10s. So I bought the pointer housing and tried to install the pointer lens only to find the housing is made incorrectly. I'll have to use a dremel to try to carve out the housing to the right shape so that the lens will be flush.
Sellers Regret
- 1950 GMC
- 1967 Chevy C10
- 2003 Silverado
Old 01-24-2020, 09:22 AM   #22
LockDoc
LockDoc's Avatar
Looks like you might have it figured out. Keep us updated on the project.
Thanks,
LockDoc
Leon
Old 01-24-2020, 10:27 AM   #23
Andy4639
Old member
Andy4639's Avatar
I found this for the Ididit 2600200020 Chrome 3-Speed Shift Indicator with Aluminum Housing
https://www.amazon.com/Ididit-260020...ASBWHTJK1126ZW
Here is one for a tilt.
https://www.ebay.com/itm/133035207240
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-24-2020, 11:57 AM   #24
Montierth
Montierth's Avatar
I have an original nontilt column. The Ididit would not work. I also have the chrome shift indicator. This weekend I'm gonna look at it closer and try to figure get it to fit. Right now I'm using a 71-72 shift indicator and pointer that works but doesn't look right. I am wondering if a 3D printer could print some of this stuff up and maybe fit and inish be better.
Sellers Regret
- 1950 GMC
- 1967 Chevy C10
- 2003 Silverado
Old 01-24-2020, 12:43 PM   #25
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 69 - 70 Pointer and Shift Indicator
Ididt just got back to me and confirmed it wouldn't fit. I have a billet housing a friend gave me and it must be for the Ididt column cause it doesn't look anything like my 71 tilt I bought from Randy500. I took the indicator housing off and tried to fit it with the lens but it wouldn't work. As you stated earlier it may work with some filing & sanding. I may order one and see.
Good luck with it and let us know how it turns out.
