Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 12-20-2012, 04:01 PM   #126
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: Project Family Truckster: 2wd Conversion Turbo LSx Blazer Build
Back to my project.
Cleaned up the heads, and started swapping valve springs. Also started tearing into the 6L. Sadly, I won't get a chance to work on it for another week or so....travelling home for chirstmas. In the meantime I've got a buddy that is powdercoating the valley cover and the front timing cover.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 12-20-2012, 06:56 PM   #127
RocketChevy56
Certified BFH Operator
RocketChevy56's Avatar
Ya, Chris has the itch to build, so i'm gonna set him loose on my c10 when he gets time.
Looking good! Hope to clear out some more of your shop space by gettin some pesky parts out of your way soon and relocating them onto my truck
- 1969 swb C/10 fleetside -LSx swap and Resto in progress
LQ4/TH400/Ed Curtis cam/Pro Flo intake/Brian Tooley Goodies ..... a couple snails may be trying to crawl into my engine bay...
-1997 Z/28 - LT1/T-56 - Bolt ons, 9 inch, built trans/clutch and on the bottle
RocketChevy56 is offline   Reply With Quote
Old 12-25-2012, 12:34 AM   #128
mopar250
mopar250's Avatar
Great build!
mopar250 is offline   Reply With Quote
Old 01-03-2013, 05:23 PM   #129
Farm Shop
Farm Shop's Avatar
This truck is going to be awesome when finished. And the pictures don't do the fab work justice... the out board shock mounts look right at home with the PB parts.
Farm Shop is offline   Reply With Quote
Old 01-07-2013, 10:40 AM   #130
Wasted Income
Boosted Member
I stripped all the ricer paint off the block, and sprayed it with a single stage urethane black.
Studded
Welded some crankcase vent fittings to the valve covers.
These are the manifolds I'm using for the new turbo setup. They're from a C6 vette. (ZOMGVETTEPARTS!!!)
Engine is pretty much finished. Next comes the trans.
Turbo diesel
Old 01-07-2013, 04:34 PM   #131
gringoloco
A guy with a truck
gringoloco's Avatar
Nice, clean work as usual. Looks beastly! Doing single or twins?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-08-2013, 02:04 AM   #132
Wasted Income
Boosted Member
Thanks. Going back to a single setup for now....I think twins are in store for this truck eventually
Worked for a bit tonight. Gutted out the old trans....I guess the broken case was a mixed blessing, because I found a couple other issues during the teardown.
Been wanting to do this for awhile....build a completely gutted LS1/4L80E for mockup purposes.
Had a toast LS1 sitting on the shelf
Welded the broken bellhousing ears back on to the trans case
Voila! Mockup goodness. It's kinda awkward shaped, but I can lift it by myself.
Turbo diesel
Old 01-12-2013, 03:03 AM   #133
Wasted Income
Boosted Member
Got the steering rack put on last night
Time to mate the body to the frame to check how everything fits
Everything seems to fit decent for the most part. Plenty of clearance around the engine and trans. A couple of my chassis stiffening bars tag the body underneath, so that will have to be reworked. Also I'm gonna have to do some tweaking to level out the rake.
Turbo diesel
Old 01-12-2013, 10:05 AM   #134
gringoloco
A guy with a truck
gringoloco's Avatar
Nice progress! Cool to see it together. Do you have enough adjustment in the coil overs to get it to sit how you want?
-Chris
Old 01-14-2013, 10:19 AM   #135
Wasted Income
Boosted Member
Thanks GL. I can go up a bit in the front yet, but I'm gonna have to rework the rear a bit to get it to sit how I want. Such is live with building hot rods I guess
Rolled it outside on saturday to snap a couple more pics. Seeing it take shape is definitely a motivator.
Turbo diesel
Old 01-14-2013, 11:41 AM   #136
Bennett68C10
Bennett68C10's Avatar
Looks awesome, especially those wheels
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 01-18-2013, 12:16 PM   #137
aggie91
I'm just glad to be here!
aggie91's Avatar
Can't wait to se more progress. I like your build plan and like how you did the rear coil overs.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-18-2013, 02:56 PM   #138
jaros44sr
jaros44sr's Avatar
That motor is awesome, cant wait to see the turbos on top of it....big bucks!
Nice work on all the fab work
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-22-2013, 03:07 PM   #139
inovermyhead
Now this is a nice project. I just wish my 7yr old daughter was excited about the cars/trucks but runs away. But I still plan on her running w/me in the 81 when it's done.
81 GMC C15 RC SWB 5.3L 4L80E project
inovermyhead is offline   Reply With Quote
Old 01-23-2013, 02:33 PM   #140
Wasted Income
Boosted Member
Thanks guys.
Got the frame 90% boxed in. Just need to finish welding, and a couple other things, and the chassis will be mostly done and ready to paint.
Also finished up the Megasquirt harness and tested all the sensors.
Turbo diesel
Old 01-23-2013, 09:47 PM   #141
lopemaxx
lopemaxx's Avatar
Lookin good Jeff.
Danny looks proud of his wiring work and ready to be done with it.
70 Chevelle SS (clone), 454, 350 auto
71 K5 350, 350 auto, 3" body lift, 35's
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |____|__|___]
*.*..*.*.._@_ _ _ _ @
lopemaxx is offline   Reply With Quote
Old 01-24-2013, 01:58 PM   #142
thor
thor's Avatar
nice work on the frame and wiring!
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 02-15-2013, 01:16 PM   #143
Wasted Income
Boosted Member
I've been welding my ass off, and not much to show for it other than 3 empty TIG tanks in the past month or so. Grind, prep, weld, repeat. My garage is destroyed right now with grinding dust everywhere.
Everytime I thought I was done with the frame...I'd think of something else I forgot....but at least now everything is welded up.
Got the coilover mounts all burned in, and fabbed up a panhard rod mount.
The valvecovers also made their way back from the powdercoater.
I forgot how much I hate painting. I would rather weld for an additional 10 nights, than to have to paint an additional night. Anyway, it's done. Sprayed it a gloss black urethane with an HVLP gun. Made a big ass mess, but the finished result looks pretty awesome.
Turbo diesel
Old 02-16-2013, 08:49 AM   #144
duallyjams
duallyjams's Avatar
That's really nice.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 02-18-2013, 11:22 AM   #145
Wasted Income
Boosted Member
Swapped from drums to discs on the rear axle. They're police Caprice / Impala SS brakes.
Also routed the rear brake lines to the calipers and temporarily secured them.
Got all the front and rear suspension back underneath it. Gotta run the brake hardline along the framerail yet.
Next up....big fuel.
Turbo diesel
Old 02-21-2013, 05:41 PM   #146
ColoradoK5
ColoradoK5's Avatar
WOW great progress on the build!!
ColoradoK5 is offline   Reply With Quote
Old 02-21-2013, 08:59 PM   #147
fatgump
fatgump's Avatar
I see you changed the position of the coil over to raise the front. I am also going to do this in a couple weeks. I'm curious to see how much this will lift the front.
fatgump is offline   Reply With Quote
Old 02-22-2013, 11:05 AM   #148
Wasted Income
Boosted Member
I did it while the body was on to try to gain some ride height...I didn't notice any difference. As you can see, I cranked the preload adjusters all the way down in an effort to level the truck out a bit. It doesn't help that my frame is a 4x4 and kicks up an extra inch at the front, effectively lowering the front of the truck an additional inch.
We'll see how it shakes out.
Turbo diesel
Old 02-22-2013, 11:06 AM   #149
Wasted Income
Boosted Member
Slowly checking tasks off the list.
Got the transmission put back together and buttoned up. Would really like to get it mated to the engine and back in the chassis this weekend. Hopefully.
Like everything else on this project, the running the brake lines is taking way more time than I budgeted for it.
Started out with a roll of copper/nickel alloy line, a flaring tool, and went to work.
After 3 hours, this is all I got done...lots of head scratching and pondering the best route, clipping points, etc....gotta leave room for the downpipe to make it thru.
Also got the PS rack re-installed.
Gotta find a place to mount this guy. Will probably wait until the body is back on, and fab a bracket that comes off the master cylinder.
Turbo diesel
Old 02-22-2013, 07:08 PM   #150
hgs_notes
GEARHEAD
hgs_notes's Avatar
Hell of a build.
hgs_notes is offline   Reply With Quote
