Old 01-28-2013, 01:05 AM   #1
77dwh
Mine finally runs again
Finally for the first time in 6 years my 77 K10 moves under its own power again. I have had this truck for 17 years and I am currently rebuilding again. All started late last summer when found a rust free cab to replace my priorly repaired and rusted out again cab. So back down to frame and start again. I sold the 454 and 400 geardrive a few years and go now I am just wrapping up a 5.3 4L60e 241 swap. It started up for the first time in years Friday night. I just need a box for it and I may have a line on a locally found southern box then back to body shop. I love hearing it run again finally. I will try to get some pics up soon.
77dwh is offline   Reply With Quote
Old 01-28-2013, 02:02 AM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Mine finally runs again
Welcome to the forum! Sounds like a sweet ride! Look forward to the pics!
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 02-20-2013, 11:43 PM   #3
77dwh
Thanks here are pictures. I can't wait to finish it up some more a finally drive this thing.
Old 02-20-2013, 11:50 PM   #4
77dwh
Plus I got a different set of wheels for it. I had to buy a rusted out 88 GMC Jimmy to get them. I worked out though I have the 35s listed on craigslist because they are nice but to big for my ride. Plus I got a good running TBI 350 with harness and all for my 78 crew cab dually as soon as I find a 700r4 its going in there.
Old 02-21-2013, 12:13 AM   #5
Duster
Duster's Avatar
That is my next project for my c10. Clean work. I am going to run a 5.3 4l60e also. Any heads up on problems you ran into would be appreciated.
Is that a pre 2005 5.3 or did you program out the DOD? Also is it a drive by wire or cable.
I have a ton of questions, that I won't bug you with. You can hardly ever find a 5.3 swap because everyone shoves a 6.0 4l80 in them.
Again, nice work.
Duster is offline   Reply With Quote
Old 02-21-2013, 12:40 AM   #6
77dwh
Thanks it has been a lot of work but worth it as soon as I hit the ignition switch. Its a 2000 5.3 4L60E 241 transfer case. It is set up with DBC. I had S & S performance make my harness a standalone and tune my ECM. I put the schoenfeld (sp?) headers on it. I had the PCM programmed to used the speed sensor in the 91 suburban transfer case and also use the 91 suburban gauge cluster with the electronic speedo to match. 87 TBI fuel tank and sending unit for feed the thing. Other than small hurdles it was mostly straight forward swap.
Old 02-21-2013, 01:03 AM   #7
Duster
Duster's Avatar
I didn't even think about using a 91 cluster. Great idea.
I didn't know if an 87 sender would feed one or not. Wasn't sure if the fuel pressures would match up. Don't the 5.3's run at 60 psi?
Old 02-21-2013, 01:14 AM   #8
77dwh
Yes I used the 87 sending unit with a 96 vortec 5.7 pump. It gets the pressure and volume right while still fitting in the sender
Old 02-21-2013, 01:48 AM   #9
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Looks great 77dwh!
DirtyLarry is offline   Reply With Quote
Old 02-21-2013, 01:52 AM   #10
Duster
Duster's Avatar
Awesome. Thanks for the info. I am still a little bit away from swapping. My truck has the origional 305 with 53K origional miles. Bought it from a family, it was their dads who passed away. The truck drives like a new one, but it is a carb truck. I am going to drive it untill I just can't stand it anymore. It is hard to molest an origional truck, but the valve seals are dried out, so it smokes on start up, and working on a 305 top end just sucks. Thought I would start getting my ducks in a row for the swap.
Old 02-26-2013, 12:02 AM   #11
Duster
Duster's Avatar
One quick question... You aren't running a factory tach with the electronic cluster are you? And if so, does it work? I have a c65 gauge cluster, and want to mate it with the electronic speedo. What I am afraid of is VSS interference between the 2 gauges. I bet they do.
Old 02-26-2013, 04:53 PM   #12
Low87
been here longer than Liz
Low87's Avatar
Congrats man! I cannot wait to say the same thing. I've had my 87 for almost 20 years, and it's sat for the last 6. Kills me, but I know one day...
Trust me, I know how excited you are. Where are the full truck shots?
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 02-26-2013, 06:22 PM   #13
pontgta
pontgta's Avatar
Love seeing the "newer" engines in these truck. Just looks awesome...
Got to ask.....Does it have AC?.....I can not tell if the line is cut or not..
pontgta is offline   Reply With Quote
Old 02-26-2013, 10:57 PM   #14
77dwh
Thanks for the compliments guys. I got this truck from dad years ago and he redid it the first time when I was in high school. He passed away 6 years ago so it became a little more special to me.
Anyways on to the questions, I dont have a tach in it. There so guys that have done it before. I dont think there would be any problems having the speedo and tach side by side.
It currently does not have ac I plan to do so someday. The factory ac compressor would not fit without modding the frame. This was my first ls swap and I learned alot from it. The next one I will change a few small things.
I do like the looks of the swap also and am really looking forward to the improvment of the in the drivablity more than anything.
Old 02-26-2013, 11:57 PM   #15
motornut
78K & 79C Jimmys
motornut's Avatar
hi ,wow ,it looks great in there
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 02-27-2013, 01:47 AM   #16
beamn7
Nice job! Looks great!
beamn7 is offline   Reply With Quote
Old 02-27-2013, 11:55 AM   #17
Jonboy
Slots go on anything!
I set up a 91 cluster with the GM sport salvage tach. the font is close, and it was pretty much plug and play. I sent you a PM as well.
Jonboy is offline   Reply With Quote
Old 02-27-2013, 11:55 AM   #18
Jonboy
That is great that you have got your truck going again. The LS swap is pretty cool!
Old 02-27-2013, 11:05 PM   #19
77dwh
Thanks again guys kinda nice knowing others like the looks of my work. I have been busy at work plus plowing my place out from an 8 inch snow the other day. Once it melts off I will get pics of the whole truck. The truck still has a long ways to go. front half is jammed and the box is still in blue fresh from Arkansas. It will be headed back to the body this fall.
Someday I would like to add a factory style tach but I have other places to put a couple hundred bucks to get it on the street first.
Old 04-09-2013, 11:45 PM   #20
77dwh
Weather was finally nice enough to get it outside for awhile and clean up the shop. Still need to align the doors and fenders then pick up the hood from the body shop and get this truck looking more complete yet.
Old 04-18-2013, 09:08 PM   #21
77dwh
I am having trouble deciding on which wheels to put on it. The centerlines or the leave the ultra 50/51s on it. What do you think?
Old 04-19-2013, 01:07 PM   #22
Low Elco
The Ultra's. Beefy!
Low Elco is offline   Reply With Quote
