Old 02-28-2013, 06:34 PM   #326
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: 2 for 1, My son's first Square Build
Well we have not gotten much done at all lately on this thing. Korbin is playing Baseball and that has taken A LOT of time away from the shop. I hope to go out to the shop tonight and get some work done.
We got the new gas tank in the other day, so I will get some pictures of the parts before we install them. I did cut out the driver's side of the firewall the other day and started making a smooth panel for it. I am glad I cut it out, there was some rust in there that I did not see before.
Tomorrow I will be ordering a few parts for the steering so I can finish up that area of the Fab. I plan to finish up the firewall while waiting on those parts to come in and get more of the cab patches in place. Once the parts for the steering come in, we will finish that fab, then pull the cab for the last time to finish the body work and start the paint.
Hopefully on Sunday, I can get Korbin out there to sandblast the bed parts so we can do more of the fab work on those parts. We might even move the chassis to the house so that we can do some non-fab work on it and keep it clean and out of the way while doing body and paint at the shop. We will see how that goes over the next couple of weeks.
Later,
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-03-2013, 02:34 PM   #327
aggie91
aggie91's Avatar
Spent some time at the shop yesterday and will go again today. I worked on the cac rust repair and got quite a bit accomplished. Once I got the driver's side firewall cut out, I decided to add some support behind the new panel since there was some rust damage to the cowl piece inside.
I got the rust of the hole in the driver's side floor next to the kickpanel welded in and roughed finished. I found a couple more small rust holes in the floor. I'll work on those today.
After that I worked on the driver's door jam. The flange that holds the weatherstripping was in bad shape (about 20" of it). I had already cut it out doing the inner rocker and floor, so I made patches to weld in. I ground it down and finished off with 80grit on my DA. (I think I killed my DA, it barely spins with 100psi air...)
Today's plans call for finishing up the passenger's door jam flange and working on a few other smaller rust areas around the windows.
We will see how today goes. I hope to set the cab back on the frame to check clearences around the motor/trans.
Karl
The LST Challenge:
Old 03-04-2013, 11:18 AM   #328
aggie91
aggie91's Avatar
Well yesterday did not go as planned. I got no help at the shop.
I finished up the passenger side door jam and got is rought finished. It will take a little filler to make it right but I'm ok with that.
After that I worked on the passenger cab corner. We had already cleaned it up and coated the inside with KBS Rust Seal.
I had a little trouble in one spot with my welder wanting to blow holes the instant I pulled the trigger. I never changed any settings and would make nice welds then the next weld would blow a hole. That small opening is a patch that I need to make for the holes I kept blowing...I figure that might have been some rust on the backside that I missed...
The bottome edge of the cab corner is not welded yet, thats why is seems to hang a little low at the pinch weld.
Karl
The LST Challenge:
Old 03-05-2013, 11:03 AM   #329
aggie91
aggie91's Avatar
We ordered some steering parts last week. Here is the first peice to arrive. Billet Half Wrap wheel from Forever Sharp Steering. Very nice wheel for the price. Came with horn button, and adapter set up.
Should be getting more parts over the next few days.
Karl
The LST Challenge:
Old 03-05-2013, 09:19 PM   #330
bucknorris
sweet wheel. great build. wish i had started with my dad that young. he tried. haha. had a 59 apache fleetside that i ended up selling. bad move
bucknorris is offline   Reply With Quote
Old 03-06-2013, 01:58 PM   #331
aggie91
aggie91's Avatar
Got a little work done on the truck. It is mocked up to check for fit at the firewall and to set up the steering shaft/u-ujoints. The stance is close but for now it has too much rake for Korbin and I. But it is still missing a few body parts...
Got the Driver's side cab corner welded in and rough finished. Just a few more patches on the cab, then epoxy and body work....
Here is how the front and rear look from the side. The rear needs to come down more, but the front is about where we want it. BTW these are NOT the wheel Korbin wants, but they are the right size for mock up...
That's it for now, no shop time today, its my Daughter's Birthday!
Karl
The LST Challenge:
Old 03-07-2013, 12:15 AM   #332
ol'blazer
ol'blazer's Avatar
i have been fallowing this build for awhile now and love this project! you guys do amazing work!
Tyler
1980 2wd blazer
1985 k10 diesel truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=652276
1987 wrangler 4x4 build-http://67-72chevytrucks.com/vboard/s...d.php?t=663784
ol'blazer is offline   Reply With Quote
Old 03-07-2013, 09:19 AM   #333
JRANGER
JRANGER's Avatar
Really looking good
JRANGER is offline   Reply With Quote
Old 03-07-2013, 03:52 PM   #334
made2drag
made2drag's Avatar
best billet wheel out there for sure!
made2drag is offline   Reply With Quote
Old 03-15-2013, 10:22 AM   #335
aggie91
aggie91's Avatar
We spent some time out at Martin Creek SP Sunday-Tuesday. Man it was COLD at night, but the days where nice. Korbin caught the only fish that made it into our hands...had some other bites but never got them on the hook. This one was on his second cast...pissed my wife off since she had been out for about an hour before he decided to fish...
Got a little more work done this week. Korbin had a buddy come over and help get the rest of the bed apart so that we can blast and get ready for primer and paint. Korbin put the seats in and I got the column and wheel mocked up. I just need to work out the connections between the column and the rack. I have to call Rob at No Limit to ask his advice on what I want to do.
I would like to run a single shaft from the column to the joint at the rack. Rob's kit comes with a third joint, but since I raised the crossmember, I just don't see it working like I want. I would like to cut off about 1" to 1 1/8" of the shaft coming out of the column to get the U-joint a little higher to make my angles better. What do you guys think?
Karl
The LST Challenge:
Old 03-15-2013, 12:01 PM   #336
theastronaut
theastronaut's Avatar
Nice catch! I like the idea of of losing the third joint, never have been a fan of joints everywhere in the steering system.
I really like this thread, you're a few steps ahead of where I am so I can see how mine will go together!
theastronaut is offline   Reply With Quote
Old 03-16-2013, 01:22 PM   #337
Driver4r
I would slit the frame and run a solid shaft down to the other u-joint.
Driver4r is offline   Reply With Quote
Old 03-18-2013, 10:01 AM   #338
aggie91
aggie91's Avatar
Got the steering shaft issue resolved on Saturday. I made a simple fixture to determine where the shaft would g thru the frame and verify that a straight shaft would work. Once that was done I marked the frame and made the hole. I used a step bit to get the rough hole then, used a carbide burr to finish out the hole. I used a high tech steering shaft to get it all hooked up, just need to get it stained a cool color . Final assy will be with a polished SS shaft:
Once that was done the boys had to go for a "cruise"...
The rest of Saturday was very unproductive, the sand blaster would not cooperate with us, seems like I was just not getting anything done and we lost a set screw for Owen's go kart throttle linkage. On a side note, we did get the back yard all mowed, edged and fertalized for the first time this year...
That's all for Saturday's updates...
Karl
The LST Challenge:
Old 03-18-2013, 10:15 AM   #339
aggie91
aggie91's Avatar
Sunday was much better. We all got up and went to church then after lunch I got to the shop and worked on the core support modifications. I have the top cover about 90% complete before body work and paint. I can finish that up in about an hour of time. It is removable to service the radiator.
It is made in three pieces that I welded together, it will be held in place with 4 machine screws in the front and 2 in the back of the radiator. I will probably use a chrome button head machine screw for it...
Here are some other views...
For the back side, I will make a panel that will hide the wiring and lights and cover the sides of the radiator tanks. I will have to make those after I get the lights and buckets installed.
From the front, we cut out the center of the core support and added panels on each side of the radiator to force air thru the core. I have one more lower filler panel to make and finish the welding before doing the body work on paint. I think it will turn out real nice when I get it done.
While I was working on the core support, Korbin was out blasting the bed sides. Turns out the nozzle was to small for the grit of sand we changed to. I went with a #4 sand to be a little more aggressive to get the paint off quicker. He got started late and ran out of day light to get them done, but he made progress.
That's all for the weekend work....
Karl
The LST Challenge:
Old 03-19-2013, 05:40 PM   #340
Can't kech me
Can't kech me's Avatar
i'm really happy the way that the steering shaft came out, what guages do you guys think would fit in a black carpet/seats/headliner and read sheetmetal interior. the standard 6 guages aren't enough because i want a tach, speedo, oil pressure, water temp, voltemeter, trans temp, fuel level, and fuel pressure guage. idk what to do about the extra 2, no one makes guage pillars for these trucks and there's no where i can think of to put 2 more guages, anyone have any ideas?
"As I walk through the valley of rice i fear no honda, for i have torque!"
Can't kech me is offline   Reply With Quote
Old 03-19-2013, 10:17 PM   #341
MadManAndrew
Fiberglass work is not hard at all. Look up some how to's on making fiberglass subwoofer enclosures and then apply that to making your own gauge pillar. You could probably start with your factory A-pillar cover, cut out some wood rings and glue them protruding from the cover with wooden dowels to position the gauges, and then glass over them. Easy peasy, and it'll be custom just like the rest of your truck.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061
MadManAndrew is offline   Reply With Quote
Old 03-22-2013, 09:37 AM   #342
aggie91
aggie91's Avatar
Got some shop time yesterday, went for a little between work and Korbin getting done with baseball practice and again for about a hour after the kids went to bed.
I fabricated the cab notch covers and got them all bent up and the corners welded after test fitting them a few times. I did not think to take process pictures, but these started out as a flat sheet of 20ga cold roll. I made a cardboard template that some how during the process ended up being about 10" to long??? that is better then too short..
Anyway I was able to finish them and get them tacked onto the floor. These look much better then my first ones and clear the frame rails much better. I will finish weld them once the cab comes back off to finish the firewall.
Tonight, Korbin plays out of town, but to early for me to get there after work. I will head out to the shop and set the core support and fenders back on for one more look before the cab comes off so that I can finish up the firewall and trans tunnel/floor. Then it is body work and paint on the cab.
Karl
The LST Challenge:
Old 03-23-2013, 11:12 PM   #343
Can't kech me
i know i can build one, but we are running out of time, that may be something i do later down the road, for now ill probly just mount the extra guages somewhere kinda outa the way and hidden
Old 03-24-2013, 09:02 PM   #344
Dirty-b
Korbin, I just read this thread. You and your dad are doing a great job!! No matter what happens with the truck you will always have the memorys of building the truck not to mention the skills you learned from your dad.
It makes me smile just thinking about all the time my son(he'll be 5 in July) and I have and will spend in the garage. We are currently putting lights and a bigger battery his power wheels Jeep so he can drive it around the campground after dark this summer.
Keep up the great work it's almost done.
Jamie
Dirty-b is offline   Reply With Quote
Old 03-25-2013, 05:12 PM   #345
aggie91
aggie91's Avatar
Got some more work done this weekend. Korbin had a buddy come over and he stripped the roof while Korbin blasted bed parts. I worked on the core support and the front inner fenders.
I used the fleetside fender wheels to make new front inner fenders. They are not 100% complete yet, but you can get the idea of what they will look like and how I got there...
Started with this: (green tape is for marking my cut lines)
Cut and welded to get this:
One more with them side by side: Still have to finish the rear of the inner fender that goes next to the firewall. I will need to make a few brackets to support it and will try to use a couple of the original holes in the firewall that were/are below where the AC/Heater box was...
All this work led to getting some of the front fender's inner structure cut out to fit our front tire combo that we are going to run. We verified the tire would fit and what rim width and back spacing we are going to use. Here is the tire/wheel size with the lower a-arm against the bump stop.
Here is what the inner fender looks like installed:
Thats it for this weekend's update.
Karl
The LST Challenge:
Old 04-02-2013, 01:41 PM   #346
aggie91
aggie91's Avatar
More progress has been made. Firewall is just about finished and close to getting a skim coat of filler. Got a few spots where I need to go back and weld up...
Going to put it back on the frame tonight and make sure that my tunnel mods are going to clear everything, then back off to finish the floor and spray on the Raptor liner. I should have the liner kit this week. So the goal is to have the floor done and the liner sprayed on the top and bottom sides of the floor this weekend.
Karl
The LST Challenge:
Old 04-05-2013, 12:11 PM   #347
made2drag
made2drag's Avatar
getting close! so the raptor liner will seal and protect all your hard work on the sheetmetal you did....is that a roll on type liner? and does it also eliminate the need for dynamat and jute padding?
Old 04-05-2013, 12:13 PM   #348
made2drag
made2drag's Avatar
inner fenders look great! mount them as high as possible....just in case
Old 04-05-2013, 01:49 PM   #349
aggie91
aggie91's Avatar
Raptor liner is a spray on two part system. It is also tintable with basecoat, so it will be red on this truck. It does have sound control, but we will still use some kind is pad under the carpet but not jute padding.
Karl
The LST Challenge:
Old 04-05-2013, 09:41 PM   #350
made2drag
made2drag's Avatar
thanks!
project, son, square body
