Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 03-15-2013, 10:34 PM   #176
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: Project Family Truckster: 2wd Conversion Turbo LSx Blazer Build
I let 29od1 do the hard work and figure out the best way to do it. I'll be patterning my setup after his, but making my rear seat frame out of aluminum instead of steel.
http://67-72chevytrucks.com/vboard/s...61#post5224761
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 03-17-2013, 12:00 PM   #177
longbed67
longbed67's Avatar
Wow! Just read through the build. Its looking really nice! I might of missed it but which MS series are you running?
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 03-17-2013, 02:24 PM   #178
ls1nova71
ls1nova71's Avatar
Maybe I missed it, but are you going back with the factory green? I see you painted the firewall green, but for some reason was thinking you were going to change the color. I guess in true 'Family Truckster' fashion, it should be green.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-18-2013, 09:11 AM   #179
Wasted Income
Boosted Member
Thanks. I'm running a Megasquirt 3x with a Megashift for the 4L80e.
I'm leaving the body exactly how it is for now. Kinda going for the "patina'd POS" look, with a supercar underneath I will be doing all the bodywork and changing the color in "stage 2" once I get sick of driving around something that looks kinda like a turd.
I have been freshening it up under the hood, so when it's popped it looks nice.
Turbo diesel
Old 03-18-2013, 09:11 AM   #180
Wasted Income
Boosted Member
Got a new radiator core support to replace the rusted out one on my '68 front clip. Aside from the rust, it looks like it had been pushing those big round hay bales around at one time...it was all bowed in.
Got the holes for the side and center A/C vents located and cut, and got the vents in place.
Got the firewall all cleaned up, with a fresh coat of the original green paint. Also got the block off plates installed for the Vintage Air.
The A/C unit is also mounted under the dash.
Looks like the boneyard Dodge Intrepid fans should fit perfectly on the radiator. Just need to make some bosses and weld them to the end tanks. I've used Intrepid fans before on a previous LS swap and they work awesome.
Turbo diesel
Old 03-25-2013, 11:25 AM   #181
Wasted Income
Boosted Member
Got the AC compressor on. Fits tight to the center of the engine, which should give penty of room for turbo plumbing around it.
My partner in crime wanted to help.
Threw the core support on and got the AC condensor and drier mounted.
Threw the grille on for giggles. Also got the Jeep composite headlights installed.
Started messing with the radiator. Made some fan mounting bosses and welded them to the end tanks. Not sure I like how this "direct fit" radiator works, so I may hold onto it for another project and find something else.
Got the bulkhead connector for the transmission controller mounted in the firewall as well.
My brother fabricated an aluminum mount for the Megasquirt 3x, Megashift trans controller, and the RTMR fuse/relay block. This will mount under the dash, on the firewall. He also got the wiring for the rear of the truck done, and tucked into the framerails.
Started with a pile of aluminum with the intention of building a rear seat frame.
Started on the front seat brackets as well. Had to modify them to make them fit the floor of the blazer.
Stock bracket once removed from the seat.
Tacked together and ready for welding.
Lastly, cut the flanges off the exhaust manifolds, and did a lot of grinding, to get rid of the parting lines, and other casting BS. Once the seats are done, turbo fabrication begins.
Turbo diesel
Old 03-25-2013, 12:38 PM   #182
ColoradoK5
ColoradoK5's Avatar
BLazer Looks amazing!! Keep up the great work
ColoradoK5 is offline   Reply With Quote
Old 03-25-2013, 01:07 PM   #183
Low Elco
Great stuff! Fab looks terrific, Can't wait for the next stage.
Low Elco is offline   Reply With Quote
Old 03-25-2013, 01:58 PM   #184
gringoloco
A guy with a truck
gringoloco's Avatar
Lookin' SO good! What's the compressor/bracket setup? I like!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-25-2013, 02:16 PM   #185
Wasted Income
Boosted Member
It's a hybrid setup that a guy on LS1tech sells. It uses a truck offset crank pulley, with an f-body pump and fbody accessories. It was $$$ but worth it to me because I need room for turbo plumbing, and I hate how stupid the aftermarket AC brackets look with the compressor hanging way out in Guam.
It's pretty simple, really...and I could have easily made it myself, but I have a May 18 deadline. Making a 600 mile roadtrip, so it needs to be up and running and tuned by then.... Every minute is valuable at this point
Turbo diesel
Old 03-25-2013, 04:32 PM   #186
gringoloco
A guy with a truck
gringoloco's Avatar
I like it. Are the ps/alt spaced 3/4"? Got a link or username?
-Chris
Old 03-25-2013, 04:56 PM   #187
Wasted Income
Boosted Member
Yes, the ps/alt are spaced out to match the truck offset.
He goes by fox12303 on 'tech.
Turbo diesel
Old 03-26-2013, 12:49 PM   #188
thor
thor's Avatar
This should get you closer...
http://m.ls1tech.com/forums/showthread.php?p=16249395
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 03-26-2013, 02:41 PM   #189
Wasted Income
Boosted Member
Originally Posted by thor View Post
Yeah kinda. He had two other threads with a lot more pics and details of a setup similar to mine, but they have since been removed from Tech. I'm guessing because he's not a sponsor.
Turbo diesel
Old 03-26-2013, 09:54 PM   #190
29od1
Your build looks awesome so far! It's going to be a bad ride when you're done.
29od1 is offline   Reply With Quote
Old 03-26-2013, 11:32 PM   #191
longbed67
longbed67's Avatar
Those manifolds look like they are aluminum..... are they?
Adam
(608) 214-8706
Old 03-27-2013, 09:15 AM   #192
Wasted Income
Boosted Member
No, they are cast steel. They've just been blasted and painted before I got them.
Turbo diesel
Old 03-31-2013, 05:49 PM   #193
82ZZZR
Saw this project in person today, looks great. Thanks for letting me stop by.
82ZZZR is offline   Reply With Quote
Old 04-01-2013, 09:44 AM   #194
Wasted Income
Boosted Member
No problem Eric. Was good to meet you and the wife.
Turbo diesel
Old 04-01-2013, 09:46 AM   #195
Wasted Income
Boosted Member
Transmission harness is mostly complete and routed. Need to wrap it yet.
Front seats are done.
The hold downs that came with the fuel rail didn't fit worth a damn. Ended up having to make some stainless pieces to weld to the brackets to make them fit. They are solid and not going anywhere.
Tacked v-band flanges to the manifolds. That's all the further I am on the turbo setup as of right now, lol.
Rolled it outside to sweep up the shop and regroup...couldn't resist snapping a couple pics.
Built some brackets to mount the engine oil cooler to the core support. Also made a bracket and welded it on for the transmission cooler.
The start of coil relocation brackets.
The final product.
Turbo diesel
Old 04-01-2013, 10:32 AM   #196
Farm Shop
Farm Shop's Avatar
Post some more pics of the seats moved forward for rear entry and showing the rear seat leg room. They look nice sitting there, but you gotta show them in action to appreciate how tailor-made they seem for the truck!
Farm Shop is offline   Reply With Quote
Old 04-01-2013, 10:38 AM   #197
Wasted Income
Boosted Member
Yeah Kyle, I thought I had some pics of them folded forward, but I guess I don't. I'll snag some soon.
Turbo diesel
Old 04-01-2013, 10:58 AM   #198
Splash4195
Nice and clean!
Splash4195 is offline   Reply With Quote
Old 04-02-2013, 09:18 AM   #199
Wasted Income
Boosted Member
Well....sometimes procrastination is the fastest way to get things done. That is certainly the case with my turbo hot-side. Really glad I didn't fab it all up with the body off....because i would have been REALLY pissed when I saw this.
Piss.
Luckily, I have sets of manifolds from like 4 different LS powered vehicles kicking around the shop, and the good ol' flipped truck manifold was the clear winner. Time to do a bunch more grinding.
I like the stance much better, after I reworked the rear suspension to drop it another 1.5"
Getting the body back on was another infusion of motivation that I needed.
Also, here is why I used the seats I did.
Turbo diesel
Old 04-02-2013, 09:24 AM   #200
Splash4195
Piss.
Nice seats where did you get them from?
