Old 03-31-2013, 02:00 AM   #1
ol'blazer
ol'blazer's Avatar
Unhappy easiest way to change the rear main seal
so the 350 in my truck has a leaky rear main seal ... im wondering what the easiest to replace it? do i have to pull the trans? or can i get away with just pulling the pan and and back main cap?
Tyler
1980 2wd blazer
1985 k10 diesel truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=652276
1987 wrangler 4x4 build-http://67-72chevytrucks.com/vboard/s...d.php?t=663784
ol'blazer is offline   Reply With Quote
Old 03-31-2013, 07:56 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: easiest way to change the rear main seal
Assuming its not a later model engine with a 1 piece rear main seal, yes, you just drop the pan and rear bearing cap to change the seal. No need to drop the trans.
Tx Firefighter is offline   Reply With Quote
Old 03-31-2013, 10:12 AM   #3
cdowns
cdowns's Avatar
easiest way i found was to drop it off at a good shop and pick it up after its done
Old 03-31-2013, 12:36 PM   #4
ol'blazer
ol'blazer's Avatar
thanks man!
something said to be said for doing it that way!, it is easier for sure, but im to cheap to send my truck into a shop for anything.
Tyler
1980 2wd blazer
Old 03-31-2013, 01:25 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
If it's in the '80 in the Blazer in your sig line... you won't need to lift the engine to get the pan out. Which it a good thing. But... the whole process is a PITA no matter how you do it.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 03-31-2013, 01:42 PM   #6
Tx Firefighter
I don't know about getting the pan off without lifting the engine on his truck.
Old 03-31-2013, 01:51 PM   #7
GASoline71
GASoline71's Avatar
I've done a few rear mains in late 70's and early 80's (2 piece) trucks and didn't have to lift the engine. They were all 4x4's as well.
Gary
Old 03-31-2013, 01:51 PM   #8
ol'blazer
ol'blazer's Avatar
I just tore into it this morning and I got the pan and main cap off without lifting the motor, should have it put back together tonight.
Tyler
1980 2wd blazer
Old 03-31-2013, 02:03 PM   #9
Tx Firefighter
Gary
I've never done on on a 4x4 personally. I was just going by 2wd trucks.
Old 05-23-2013, 07:32 PM   #10
GuyO
GuyO's Avatar
There's a guy in another thread who takes about making sure the timing mark is facing straight down. Apparently this places the crank in a position where the pan slides out once unbolted. My rear main is leaking like a sieve, and am planning on doing the seal replacement myself. I will let you know about the pan.
GuyO is offline   Reply With Quote
Old 05-23-2013, 11:19 PM   #11
ol'blazer
ol'blazer's Avatar
i never did that.. but it sounds like a good idea.. tell us how it works, best of luck!
Tyler
1980 2wd blazer
Old 05-24-2013, 08:00 AM   #12
burnin oil
They are trying to make sure that the counter wieght on the crank doesn't catch the pan as it slides back. It is fun trying to get the rear of the pan to clear the trans, baffle clear the oil pump and pickup, and clear the crank all the while bottoming out on the crossmember.
burnin oil is offline   Reply With Quote
Old 05-24-2013, 08:23 AM   #13
Tx Firefighter
I never try to work around the oil pump. I drop the pan enough to get a wrench on the oil pump bolt and drop the pump into the pan.
Old 05-26-2013, 07:59 PM   #14
SSC's76
No No
SSC's76's Avatar
Yep been there 1st one I ever did lined up perfect second on was like what the heck why isn't this working raised the engine and got the pan off was like hmm that's why. Making sure the crank is lined up properly will make it a easy job unless you are working on a 4x4 the. It don't matter
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 05-27-2013, 09:21 AM   #15
burnin oil
My 72 K20 isn't that bad. A jack and about 15 bolts gets the 3 piece crossmember out. You can then drop it straight down. Easiest one I have ever done. Pan easy, realligning the crossmember is a PITA due to slight frame twist (old age, not damage)!
Old 05-27-2013, 11:23 AM   #16
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Hopefully you will roll the seal through so it's sticking out an 1/8th inch or so otherwise you might be right back in the same situation. In other words, don't have the where the 2 halves of the seal line up with the 2 halves of the main cap. That is where oil wants to leak under pressure.
prostreetC-10 is offline   Reply With Quote
