03-10-2013, 10:55 PM | #101 |
SAVING ONE TRUCK AT A TIME
Re: 1940 "project moonshine"
few updates.lots has been going on but nothing that looks cool in pics.truck is mostly wired.motor is all closed up now.air system is working.lots of small stuff.got the rest of the sheetmetal on.we will be louvering the hood so that will go on last.last major hurdle will be changing the gears from 2.73 open carrier to 3.73 posi.thanks chizzler.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
03-10-2013, 11:11 PM | #102 |
Lookin good Chizzler..
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
03-11-2013, 10:37 AM | #103 |
How did you mount your wood bed floor? Specifically with those strips and where did you get them from?
1955.2 Chevy 3100, 6bt, Getrag G360 5-speed, NP205, Dana 60/70 - http://67-72chevytrucks.com/vboard/s...d.php?t=536540 1992 Chevy K1500 Silverado ECSB 1965 "Crewcab" Chevelle 300 Deluxe - soon to be LBZ Duramax/4L85E powered |
03-11-2013, 05:14 PM | #104 |
if you look back on my build you will see we made a raised bed floor frame using 1x1 steel.i then got the bed strips from mar-k and had them not drill the holes so i could drill through the bed strip and the frame below.the bed strips come with or without holes at any length you want.
03-16-2013, 06:59 PM | #105 |
I love everything about this truck. A 37-40 Chevy pick up may be in my future after see what you have done with this one.
Posted via Mobile Device |
03-16-2013, 09:01 PM | #106 |
today we got a little more done.we punched 112 louvers in the hood.we also had to massage the front sheet metal around to align with the hood.all electrical is done but we have to mess with the yankee 960 turn signal switch a little.chizzler
03-17-2013, 08:44 PM | #107 |
Great work. How long does it take to make all those louvers?
03-17-2013, 11:08 PM | #108 |
thanks.louvers took about 3 hours to lay out and punch.you have to grid the backside so you have something to follow once you start going.it helps keep everything in line.
03-18-2013, 03:09 PM | #109 |
Nice ride, what is the wheel and tire setup?
"Dixie" - 1988 Chevrolet V30 CC DRW "3+3" | 7.4L 454 (L19) | TH400 | 4" lift | 35"s "Lucille" - 1949 Chevrolet 3100 (on hold) |
03-18-2013, 07:55 PM | #110 |
15x5 w 620-15 tire on front,15x7 w 820-15 tire on rear.wheel vintiques.soon to be hurst super cushions in front and 710-15 firestone vintage in rear.
03-19-2013, 01:26 AM | #111 |
I love this truck. Just wicked!!!
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
03-23-2013, 11:54 PM | #112 |
well today was the day.fired the motor and everything went well.no major problems or leaks.noted a little clicking coming from the valve covers.not sure if the roller rockers are hitting the inside of the valve covers.all n all motor sounds great temp and oil were perfect.electric fan came on.
03-24-2013, 12:41 AM | #113 |
Tot Roddin'
Beautiful!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
03-24-2013, 09:32 AM | #114 |
Time to see some action !
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
03-24-2013, 11:45 AM | #115 |
You've got an awesome truck, man.
-Holden 1983 & 1972 Chevy Longbeds (16) 67-72s (Rollback, 402's, Sierra Grande, Shortbeds, Shortsteps, Longhorn, etc) 1968 GMC Suburban- (Current project) Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=569806 (6) 60-66s (shortstep, rollback, two-ton, longbeds) (3) 47-59s half tons + MANY more and always looking for more |
03-28-2013, 10:57 PM | #116 |
Holy cow man thats a beauty
1971 GMC Sierra 1959 GMC 100 |
04-04-2013, 09:20 PM | #117 |
got the seat back today.we had to make a new plywood base because it was rotted out.probably was a good thing.now has a nice new foam bottom.big swap meet this weekend.
04-04-2013, 10:50 PM | #118 |
Tot Roddin'
Lookin good!
04-13-2013, 08:18 PM | #119 |
few update pics.today we took the red door and sanded it and blended in some other colors to try and match the rest of the body.it is not a great match for now but a little closer.we also put the seat in and made some kick panels from a sheet of black abs.thanks.
04-13-2013, 08:22 PM | #120 |
Looking great
04-13-2013, 08:24 PM | #121 |
Love the Bench Seat man, really nice
04-13-2013, 08:26 PM | #122 |
Ridin' Dirty
Cool build! Sweet truck, love the triple deuce, I'll stay tuned
1978 C3500 Crewcab (Project) 1979 C2500 Crewcab (Driver/project) 1988 R2500 Crewcab (Driver) 1988 V3500 Crewcab 1988 R2500 Crewcab (Mint, Ex Fire Dept) 1968 Chev Suburban (4x4 conversion) LINK 1970 Chev C20 Suburban (driver/cruiser)LINK 2005 Impala (Incognito vehicle) 2004 Yukon XL Denali (Kid hauler) 1947 Case tractor Facebook Page(1000's of pictures of GM cars and trucks organized into albums) YouTube Channel |
04-13-2013, 11:16 PM | #123 |
Tot Roddin'
Nice work.
04-14-2013, 09:53 AM | #124 |
The door looks a 100 % better, just don't touch the out side of the truck then put your hand on the seat.
04-14-2013, 09:55 AM | #125 |
Will you show the Original Owner ?
