68 shortbed 5.3 4l60e DBW swap :)
Yessir.. I'm starting this thread to help.. (Show off my work) lol I have a 68 Chevy c10, putting an 04 5.3L 4l60e in it... I had a 350/350 turbo.. I have done lots of research before the build... I got motor/trans PCM harness tac gas pedal for 1300$ motor had 62,000 miles on it... I live in Dallas Texas... These motors are very easy to find... I got a custom grind to cam.. Got some springs and lifters ... Professional valve job... Got the harness modified locally.. Can hook u up w number if interested.. Got PCM flashed from ol boy from lt1tech , quick turnaround.. Real good guys..
Pix coming soon I dropped motor and trans in today and it fits perfect. 5.3 manifolds didn't fit, I'm using dirty dingos and the pedestals that came with the truck when I got it.. Had 350/350... So gonna try the tbss manifolds? What year guys?? Driveshaft fit... Awesome!! Mounting fuel system tomorrow.. Got the vetted filter and a external fuel pump... Have a 18gal tank under bed ( came with truck) for now at least... Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device |
Re: 68 shortbed 5.3 4l60e DBW swap :)
Only letting me one at a time
Bat
did you use the stock oil pan?
So the stock driveshaft length fit just fine in the 4l60??
Any chance of getting a picture of the driveshaft in the trans? |
#9 | |
![]() Join Date: Sep 2005
I uzed the dirty dingo mounts with my engine all the way forward mine was 3 inchs to long i went a head and slide the motor and trans all the way back and had 6 inchs taken out of my front shaft.
Dude, Subscribed. I wanna see thin thing running.
Seth |
![]() Join Date: Feb 2007
Where did you get the motor and transmission from?
68'chevy swb 350/200r4 71’ chevy swb 6.0/4l80e |
motorandtransfromjunkyard
you have one clean truck. who did the cam swap for you. an what part of dallas
#15 |
northTexas machine.. I'm inIrving
#16 |
#17 |
Far out! more pics of the truck when you get a chance.
#18 |
![]() Join Date: May 2013
Are you running the 350 trans ?
what cam and springs are you using ? truck looks clean I had major issues with manifold/headers using cpp's pedestal mounts had to modify a set of pacesetter headers to work , did not want to fork out the coin for dougs headers
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
#19 | |
I ended up using stock 5.3 manifolds.. had to grind a little on passenger. side I'm using the sbc stands and dirty dingo adjustable mounting.plates. I have motor as close as I could to.fire wall |
Tags |
2004, 4l60e, 5.3, dbw, ls swap |
