Old 05-15-2013, 05:06 PM   #1
TireSmoke420
One of the few GMC'ers
TireSmoke420's Avatar
what all year 4l60e fit in 2000
I've got code 1870. I've read all about it but I'm kinda stranded in Spokane Washington till I get this fixed. I found a few trannys on cl but what all years will work for a 2000 1500?
87' Silverado 4x4
"Young, Dumb And Full Of Cum"
TireSmoke420 is offline   Reply With Quote
Old 05-15-2013, 07:15 PM   #2
clinebarger
Re: what all year 4l60e fit in 2000
V8 or V6??
I have never changed a transmission because of a P1870 code.....Its generally the Isolator/Converter valve bore is worn out...and results in poor, or no, TCC apply.
A Trans-Go SK 4l60E shift kit "Fixes" the valve body bore with a long ISO/CONV valve.
How to test if the valve body is worn....
Cold engine, Clear the code, Test drive the truck....If it shifts fine & no codes while cold.......Then it heats up & acts-up.......Its the valve body.
Buying a used transmission is a big gamble because it might have the same problem yours does......
clinebarger is offline   Reply With Quote
