Old 05-28-2013, 10:46 PM   #26
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Ultra Family and Hauler Mobile
Yeah, I saw it a while back and was like dang, he got his running before me. The truck was for sale on ebay when I saw it.
Ryan
1969 Chevy milk truck
Old 05-28-2013, 11:24 PM   #27
ryanroo
ryanroo's Avatar
Originally Posted by Dieselwrencher View Post
Nah, it's prolly 3.73. They quit 3.55 with the old body style and now only have 3.73, 4.10, and 4.30. Pretty dumb if you ask me. Was it a D60 front?
looks like im the tard....
didnt say. i was just skimming over the listings. i forget what i was searching for.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 05-28-2013, 11:51 PM   #28
Dieselwrencher
No you're not a tard, it's just Ford's lovely way.
Ryan
Old 05-29-2013, 11:54 PM   #29
ryanroo
ryanroo's Avatar
a few pics of the ryanroo method on fan shrouds
the one on my truck will be similar, but i think i will build it so it splits in the middle to make the fan easier to remove. this one on the jeep is a major pain witht he low clearance between the fan and core
72 K20 12v build
Old 05-29-2013, 11:57 PM   #30
ryanroo
ryanroo's Avatar
it works like a charm though! walk to close to the jeep while its running and that thing will suck off your shirt. not good if you are in crowd of females. they swarm a fella. learned that the hard way....
72 K20 12v build
Old 05-30-2013, 05:39 PM   #31
jbclassix
Junk Yartist
jbclassix's Avatar
1. Never had that problem... any scars from it?
2. Is that Aluminum?
3. Is that a BBC?
4. Why do you still have an AIR pump on it?
5. Are you going to build one for Ryan's wife's family mobile as a baby shower present?
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 05-30-2013, 11:06 PM   #32
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Is that a Kaiser with a BBC? 454?
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 05-31-2013, 12:20 AM   #33
ryanroo
ryanroo's Avatar
3. Is that a BBC?
only a few scars!
yes
yes (of course)
air pump is long gone now! its also TBI now
well, id have to have some plans before i could even think about it. he wants some black plastic thing though, said it looks better than hack welds...
yessir
72 K20 12v build
Old 06-01-2013, 10:46 PM   #34
jbclassix
Junk Yartist
jbclassix's Avatar
Hey Ryan, there us an 01 diesel 4x4 Excubus here in town getting parted out. You want me to ask about any of it?
-Jeremy
Rebuilding an NP205
Old 06-03-2013, 03:01 PM   #35
Dieselwrencher
Sure, check to see if it's a limited by chance. I'd like to get the woodgrain inserts from the door panels and console. Thanks for keeping me in mind.
Ryan
Old 06-03-2013, 03:09 PM   #36
Dieselwrencher
That's complete BS!
Ryan
Old 06-03-2013, 10:03 PM   #37
Dieselwrencher
Ok, time for some updating to this thread. While Ryanroo's fan shroud is awesome, I don't have the means to weld aluminum right now. So I opted for a more factory appearing method which I could complete. I cut the factory V10 fan shroud, and another donor shroud, and built a new to it shroud by plastic welding it all together. It isn't perfect, but I can't spend a lot of time making it perfect as I need to get this thing running ASAP.
Upper radiator hose modified and installed.
Fan Shroud Building
Once I got the fan shroud finished, I moved on to building the lower water inlet. I didn't want 6 different hoses and 12 hose clamps, so I built this pipe and it will use a 90* hose up top and a straight hose on the bottom.
Next I moved on to the down pipe. I wasn't happy with how the S300 compressor cover sat on the exhaust manifold, or darn near it. The waste gate was also really close to the HVAC box. So I drilled the holes out on a T3 spacer I aquired from my friend Ryanroo. Thanks buddy! Next I used some 4" 90* pipe bends and an expensive HX40 outlet flange, and built the down pipe.
I also got my power steering lines modified and installed. I got the 3:55 ring gear installed on the 4:30 carrier, ran the exhaust, installed the oil presser sender and the coolant temp sensor, installed the Tcase, ran the tranny cooler lines and hooked them up, and cleaned and painted the fan shroud.
The next jobs to do are:
Install new to it pinion and set up rear diff
Remove yoke from dodge donor rear drive shaft and install on tcase and measure for new rear shaft
Get exhaust hangers and install them, then install exhaust clamps, paint down pipe
Clean fuel tank and install pick up tube
Run fuel lines and install fuel filter housing
Build throttle bracket and reposition speed control unit
Modify the ford engine harness and eliminate un needed wiring
Rebuild turbo, paint exhaust manifold, drill for pyro
Install Pyro, Boost, and trans temp gauges
Add fluids, flush cooling system before fill up, plug in block heater and retorque head bolts before fire up, then recheck the over head
Figure out a/c lines and get them going, purchase new receiver/drier,
Finish grind CAC tubes and paint them, install a/c condensor and new a/c comp
Build Air Filter Inlet Pipe
Purchase Voltage Reg and install it
Hopefully this list can get smaller soon.
Ryan
Old 06-03-2013, 10:14 PM   #38
Mattman2010
Mattman2010's Avatar
This thing is going pretty fast man! Keep up the work.
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 06-03-2013, 11:19 PM   #39
ryanroo
ryanroo's Avatar
looking good!
72 K20 12v build
Old 06-05-2013, 08:11 PM   #40
Dieselwrencher
I've been trying to get odds and ends on this thing. Ordered a new throttle cable for it, got my yoke robbed from a dodge drive shaft, installed the tcase rear out put shaft seal, installed yoke and measured the shaft length. Took the shaft to the drive line shop yesterday, and they got it done today. Yesterday my dad installed the 3:55's in the rear axle and got it set up. Now I'm trying to arrange the fuel filter location so I can get the throttle bracket built and on. Little by little..............
Ryan
Old 06-05-2013, 09:39 PM   #41
Ackattack
Ackattack's Avatar
Makin progress!
My list looked very similar a few months ago....now its really short.
Ackattack is offline   Reply With Quote
Old 06-05-2013, 11:00 PM   #42
Dieselwrencher
Originally Posted by Ackattack View Post
Makin progress!
Thanks! I swear as soon as I get a list completed, a new list starts.
Ryan
Old 06-05-2013, 11:07 PM   #43
jbclassix
Junk Yartist
jbclassix's Avatar
little by little is better than my none at all!
-Jeremy
Rebuilding an NP205
Old 07-12-2013, 03:37 PM   #44
Dieselwrencher
No big progress to report on this. We did get the rear end figured out. Dang pinion bearings are different on the inners from old body style to super duty. Also my rear calipers were deteriating and the pistons were coming apart. So it got new calipers and pads in the rear. The aluminum diff cover is on and new fluid and a new pinion seal are in. The fuel tank is back in and the fuel lines are hooked up from the tank to under the driver's seat area. The shift cable for the trans is installed and hooked up. Intercooler tubes are made, just need to finish grind them and weld one bead on another. I got a new A/C comp, but have to figure out the best way to complete the A/C lines. I need to rebuild the turbo, build the throttle linkage set up, finish running the fuel lines, and mount a lift pump. Then I should be able to add fluids and start it. It isn't too far off really.
Ryan
Old 08-06-2013, 07:27 PM   #45
Dieselwrencher
I've gotten some more done to the Ex. I got the turbo rebuilt, installed the exhaust manifold, turbo, and hooked up the heater lines. I had to reroute them as the turbo would have burnt them in the OE location. I got the steering wheel lower cover repaired and replaced the air bag. I got 07 Harley head lights for it, a double deep trans pan, and a small HID head light kit for it. I also dug out the step tubes I've been hanging on to for years and started installing them. Little by little. Here are some pics.
Ryan
Old 08-07-2013, 10:39 AM   #46
Mattman2010
I wish I would have looked at this thing while I was up there. Looking good Ryan!
Build Thread
Build Thread
Thread
Old 08-07-2013, 02:50 PM   #47
Dieselwrencher
You might see it some day. I doubt it'll be in KC, we'll have to see. If I have to haul the Longhorn down there, I obviously can't use this. No GN hitch.
Ryan
Old 08-07-2013, 03:25 PM   #48
Mattman2010
Oh I know ill see it some time, but I walked past it idk how many times while I was up there, you just have to much stuff to look at that 5 days up there wasnt enough time haha. Just cut the back half off and mount a gooseneck hitch in the back floor. Im sure it would work!
Build Thread
Build Thread
Thread
Old 08-07-2013, 03:32 PM   #49
Dieselwrencher
Uh, heck no on that.
Ryan
Old 08-07-2013, 08:50 PM   #50
ryanroo
ryanroo's Avatar
cutting the rear body would be bad. do this instead
72 K20 12v build
