06-17-2013, 10:03 AM | #51 |
Re: Project "It's a Jimmy Thing"
I got a tilt column from a fellow board member the other day.
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
06-18-2013, 02:18 AM | #52 |
Professional Grade
I am guessing you must be an industrial instrumentation mechanic? My truck is filled with swagelok stuff too, haha!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
06-21-2013, 01:30 PM | #53 |
A little bit of progress. After 2 rolls of masking tape i got the body all masked off for the Raptor Liner. Then the hard part started when i had to scuff up the epoxy primer. My arms felt like jelly after that. I sprayed 2 and a half kits of the liner on outside and i think i pissed my neighbor off because they were having a graduation party when i was spraying with a breeze in their direction. Oh well, i wasn't invited so how was i to know. Haha. I think that it turned pretty good. I just hope it holds up good and doesn't start flaking off in time.
06-21-2013, 01:36 PM | #54 |
More pictures.
06-21-2013, 01:41 PM | #55 |
More pictures.
06-21-2013, 08:52 PM | #56 |
72 K/5 Junkie
You give classes? Lol, excellent work!
Posted via Mobile Device |
06-23-2013, 11:14 AM | #57 |
Nice work, patiently waiting for updates.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
06-24-2013, 09:55 AM | #58 |
Nice build!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-26-2013, 10:24 AM | #59 |
Haha. Thanks, but i am the one that is going to need lessons soon when i get to the wiring.
Thanks, I am sorry you have to sell your Jimmy. Hopefully you can find a way to keep it. Thanks.
06-26-2013, 10:35 AM | #60 |
I got the body back on the frame exactly a year from the day i brought it home. Only one small problem. The upper tranny line was rubbing on the tunnel so a $25.00 AN 45 took care of that. I put the doors on to shim the body to get the correct gaps and then locked it all down. I think i got it close to where it needs to be and i can final adjust in the hinges during final assembly.
06-26-2013, 10:52 AM | #61 |
Here are a couple of pictures of the rotisserie that i cobbled together from some scrap steel i had laying around. It worked out better than expected. I hauled it on my trailer to the place i blasted it and to my painters shop without any issues.
06-26-2013, 10:59 AM | #62 |
Door alignment pictures. As you can see i still have the doors and fenders to work on. Luckily they are in great shape except for the the drivers side fender which has a nice large dent in the center of it that i am going to try to save.
06-26-2013, 12:22 PM | #63 |
Nice work!! Those LS engines look so right in the K5s, well done. Following your lead on the fuel lines, thanks for the help
06-30-2013, 08:54 PM | #64 | |
I got a little bit done. I installed some sound deadner, the center section of the insulation pad, computer, harness and the TAC module. The TAC module mount looks a little ghetto but i don't think you will be able to see it very well.
06-30-2013, 08:58 PM | #65 |
A couple pictures of the harness.
06-30-2013, 09:09 PM | #66 |
I also bought a radio and a dash bezel. I got the dash bezel from a guy on ebay for $59.00. I know there is a guy on the board that sells these as well but i think it takes him a while to get them built and shipped, although i am sure the quality of his is better than this one. It was shipped raw finish so i just used some aluminum polish and a cotton wheel on my die grinder to polish it up a bit.
06-30-2013, 09:46 PM | #67 |
VA72C10
Everything looks fantastic so far!
Looking for a 67-72 swb or blazer project in or around VA. |
07-15-2013, 08:18 AM | #68 |
I got my steering column torn apart, painted and installed with one of ls1nova71's cruise levers.
07-15-2013, 08:24 AM | #69 |
I also got a whole pile of misc. parts blasted and painted.
07-15-2013, 08:31 AM | #70 |
I got the radio, parking brake assembly, ash tray and the drivers side sound deadner and insulation pad installed.
07-15-2013, 09:52 AM | #71 |
Nice project. I'm in your same neck of the woods, just off Spinkle Rd. South of Centre .
Looking good. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
07-15-2013, 10:26 AM | #72 |
Thanks. I saw your truck going down 9th street on Saturday! What year is it? I would like to check it out sometime. I have a 51 5 window that will be my next project.
07-15-2013, 12:57 PM | #73 |
Nicely done...that radio looks great in there
Howd you like puttin that tilt back together. Thanks for the pics
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 07-15-2013 at 01:03 PM. |
07-15-2013, 01:35 PM | #74 | |
I'm ussually not in that neck of the woods but my wife and I took a truck ride over to South Haven for dinner. It turned out to be a great night for a drive. Your welcome to check the truck out anytime. Thanks Marc
07-15-2013, 02:40 PM | #75 |
Thanks, The tilt was kind of a pain in the butt. After i tore it apart i put it back together before i painted it just to make sure i could do it. I still scratched it during final assembly though.
