Old 07-07-2013, 02:41 PM   #176
Hart_Rod
Hart_Rod's Avatar
Re: Project "Shifted"
I have an inch between mine.
Hart_Rod is offline   Reply With Quote
Old 07-07-2013, 03:58 PM   #177
lolife99
67-72 parts collector,…
lolife99's Avatar
Different oil pan?
Keith
Convert to disc brakes.
Old 07-07-2013, 04:11 PM   #178
Hart_Rod
Hart_Rod's Avatar
Different oil pan?
Mines off of a Fbody, 2002 Camaro Z28.
Old 07-07-2013, 07:04 PM   #179
RRC
RRC's Avatar
Mine is a truck pan......but I have a f body pan that I'm painting and will be using
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=563712
Instagram: http://instagram.com/rockylakekustoms
Rocky Lake Kustoms
Russ
RRC is offline   Reply With Quote
Old 07-08-2013, 09:50 AM   #180
Hart_Rod
Hart_Rod's Avatar
I think you will have the same gap as I currently do when you swap to the Fbody pan. What tranny are you running? I'm using a 4L60E. Right now I'm setting everything back up the way I had it when I first did my measurements, and rechecking everything.
Old 07-08-2013, 10:49 AM   #181
RRC
RRC's Avatar
I'm using a 700r4 trans.....that sounds like a good plan , hope it all works out.
Rocky Lake Kustoms
Russ
Old 07-12-2013, 08:56 AM   #182
Hart_Rod
Hart_Rod's Avatar
Thanks! When are you swapping your pan out? I got the new motor trusses and will try to get them installed this weekend.
Old 07-12-2013, 09:07 AM   #183
SeTx67
SeTx67's Avatar
Read the thread the other day and guess I got caught up on pictures and forgot to post . Cool build for you and your son. I need to read your other build thread also. There's so many awesome builds and so much info on this site I think my brain is going into meltdown
SeTx67 is offline   Reply With Quote
Old 10-27-2013, 12:18 PM   #184
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
not sure how I missed this one....sweet project...any updates?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 01-23-2014, 09:59 PM   #185
Hart_Rod
Hart_Rod's Avatar
New transmission mount and drive line is done. Might be putting this up for sale.
Old 01-23-2014, 10:03 PM   #186
Rusbuilt
Rusbuilt's Avatar
Looks good! I hope you don't sell it!
Rusbuilt is offline   Reply With Quote
Old 01-23-2014, 10:13 PM   #187
jmedero
jmedero's Avatar
Lord only knows what you have in store.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 01-23-2014, 10:15 PM   #188
Dobster
Wish I was closer. I would love to have this project!
Dobster is offline   Reply With Quote
Old 01-24-2014, 12:23 AM   #189
jasonhall
jasonhall's Avatar
Why do you wanna sell it?
jasonhall is offline   Reply With Quote
Old 01-24-2014, 06:37 AM   #190
Bennett68C10
Bennett68C10's Avatar
Wait, what are you selling? The drivetrain or the entire project?
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 01-24-2014, 09:17 AM   #191
mcbassin
Still Learning
mcbassin's Avatar
I thought that he might want to sell the old tranny mount when I first read the post...?
Old 01-24-2014, 09:19 AM   #192
Zukowner
Zukowner's Avatar
I think it may be the entire project.
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=614365
68 & I'll Owe You 1
Zukowner is offline   Reply With Quote
Old 01-24-2014, 10:25 AM   #193
Hart_Rod
Hart_Rod's Avatar
Just a short road trip, .
Just thinking about moving on to something that is a little more "new driver" friendly
Not 100% sure yet.
Chevy sonic......
Sorry for the confusion, .
The entire project:
Here's a list of most of the parts for the truck. I'm sure there are some more smaller things that I'm missing.
Original rust free Cab (clear title) and front clip with all glass
NOS Stainless vent shades
bolt in high hump tranny cover
New rubber cab mounts
Factory Buddy bucket front seats with center console
Original steel front and rear painted sport bumpers and brackets
Hills fiberglass front tubs for dropped trucks
10 Gallon air tank with custom pin striping
Custom gas pedal setup
OEM inner wheel tubs
Factory short bed chassis with front and rear Porterbuilt extreme dropmembers
Porterbuilt tubular upper and lower A-arms
Porterbuilt rear tubular trailing arms and crossmember
Porterbuilt front radiator cross bar
Porterbuilt transmission mount (with HartRod mods,)
Front and rear airbags, fittings and shocks
New power rack and pinion with steering joints and rod
1.25" Adco sway bar
CPP 2” dropped modular spindles with aluminum hubs
CPP front and rear big brake kit (13”/12”)with powdercoated calipers (black), zinc coated rotors, and braided stainless brake lines
New 20x10 and 20x8 Coys with BFGoodrich tires
Custom 2 piece 3.5” driveshaft/slip joint
12 bolt rear with Eaton posi 3.73 gear and new ECE 5 lug axles
Brake lines and braided hoses
The chassis and all components have been painted with POR 15
2002 Z28 LS1/4L60E with only 25K documented miles
MAF/O2 sensors
Custom stainless cold air intake setup
Holley accessory bracket spacer kit
2010+ Camaro manifolds with 2 new stainless Magnaflows
Custom aluminum fuel tank with in tank fuel pump and sending unit (with braided fuel lines and Corvette fuel pressure regulator)
Custom ECM mount
LOKAR shifter linkage
Old 01-24-2014, 12:09 PM   #194
mcbassin
Still Learning
mcbassin's Avatar
Dang brother. This is a great starter truck for a new driver
I totally understand. I have two kids myself. It was tough handing over the keys to both of them. BTW, they both drive chevy trucks...just saying.
Old 01-24-2014, 03:59 PM   #195
snailhouse_projects
this is the second time this has happened to me, I read an entire thread that I hadn't seen and when I get to the end, the truck is getting sold...... bummer. I say keep it, but I also know the thoughts that go through your head when you hand the keys over to someone.....
great build
snailhouse_projects is offline   Reply With Quote
Old 01-26-2014, 11:56 AM   #196
Hart_Rod
Hart_Rod's Avatar
great build
It hasn't sold yet, so we'll keep working on it until it does or it's done, .
High hump is mounted, and the cab is back on.......looks like a truck now instead of a bunch of part,
Old 01-26-2014, 12:05 PM   #197
Dobster
So" you post your sons truck up for sale for motivation? Lol jk Good to see y'all are getting some work done. It's looking good!
Old 01-26-2014, 01:05 PM   #198
Bennett68C10
Cab looks great on there
Keith
66 Suburban
IG: bennett68c10
Old 01-26-2014, 01:22 PM   #199
rwade
rwade's Avatar
Do you have a fleet side bed for it or will you sell it with the stepside bed?
Wade
rwade is offline   Reply With Quote
Old 01-26-2014, 03:09 PM   #200
Rusbuilt
Rusbuilt's Avatar
So cool Rob!
