Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 07-03-2013, 10:11 PM   #1126
mud.man.rj
mud.man.rj's Avatar
Re: Crash's 69 K10
See a yoke that that quite a few times, prob just get week over time and torque.
mud.man.rj is offline   Reply With Quote
Old 07-03-2013, 10:12 PM   #1127
Crash_OK
Crash_OK's Avatar
Re: Crash's 69 K10
Thanks..
Have you ever seen it cause u joint failure in ~1000 miles? Maybe I should not say failure.. it still worked, but it did burn up the needle bearings..
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 07-03-2013, 10:35 PM   #1128
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: Crash's 69 K10
That's definitely a premature death. Good luck finding a yoke.
Zoomin is offline   Reply With Quote
Old 07-03-2013, 10:36 PM   #1129
Crash_OK
Crash_OK's Avatar
Re: Crash's 69 K10
Thanks Steve..
Mark
Crash's 69 4x4 SWB
Old 07-04-2013, 01:39 AM   #1130
mud.man.rj
mud.man.rj's Avatar
Re: Crash's 69 K10
I have seen it happen twice now and not ptiing down your work by any means but the out of three I have seen 2 of them were not installed correctly and the u joint cup was not totally in the pocket and the u joint cap was tightened down so it never sat flush with both sides down, the 3rd on had too much play in the yoke and just a bit wore out so the u joint would actually slide back and forth and hit one side then slide the other way until the tab broke off other than that the only thing would actually be that maybe a needle bearing was out of place or damaged per factory, as defective.
Old 07-04-2013, 06:56 AM   #1131
Crash_OK
Crash_OK's Avatar
Re: Crash's 69 K10
I believe the problem with this one is the 3rd one you listed above. That was what I was attempting to show in the pictures. The tab that locates the u-joint on the yoke is wore down about a 1/8 of a inch on one side... Hopefully I can find a good at McBassin's this morning.
Thanks..
Mark
Crash's 69 4x4 SWB
Old 07-05-2013, 07:02 AM   #1132
71Sixer
71Sixer's Avatar
Re: Crash's 69 K10
If you have trouble finding a new yoke, you should find what you need here.
http://www.dennysdriveshaft.com/c258..._hardware.html
71Sixer is offline   Reply With Quote
Old 07-06-2013, 01:23 AM   #1133
67c10rustbuket
67c10rustbuket's Avatar
Re: Crash's 69 K10
Dang that yoke is beat up a little bit, I have been known to shred some U joints in a previous vehicle but that was because I had a bad pinion bearing and thought it was a bad U joints causing the problem. Well I was the one causing the problem doing too many burn outs back in the day...
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 07-13-2013, 08:54 PM   #1134
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Crash's 69 K10
Great looking truck it sure turned out nice congrats.. It only took me about a week to get through the whole build thread.. I'm not sure if its just the pics or my anal retentiveness but you may wanna swap the reverse lenses from side to side to see if they fit better..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 08-04-2013, 10:26 AM   #1135
Crash_OK
Crash_OK's Avatar
Re: Crash's 69 K10
Thanks for the link.
Mark
Crash's 69 4x4 SWB
Old 08-04-2013, 10:30 AM   #1136
Crash_OK
Crash_OK's Avatar
Re: Crash's 69 K10
LOL.. I am sure this truck had been abused in a similar manner in the past... So far I have put over 600 miles on the new yoke with no problems..
Mark
Crash's 69 4x4 SWB
Old 08-04-2013, 10:30 AM   #1137
Crash_OK
Crash_OK's Avatar
Re: Crash's 69 K10
I think you are right.. thanks...
Mark
Crash's 69 4x4 SWB
Old 08-04-2013, 11:30 AM   #1138
Crash_OK
Crash_OK's Avatar
Re: Crash's 69 K10
Time for a little update.. Last week I finished up all of the steering and suspension work. I think it is as good as it is going to get. It drives and steers very nice.. it is still a bumpy ride, but that is to be expected…
I installed a 2” drop steering arm.. this leveled the drag link, and eliminated the bump steer that I had.
I also went ahead and installed new tie rod ends, I had originally re-used the old one because they felt tight (and also because the new ones are so expensive)
Next I installed a sway bar off of later model 4x4.. I built the brackets instead of replacing the front crossmember. This really made a lot of difference…
Mark
Crash's 69 4x4 SWB
Old 08-04-2013, 11:46 AM   #1139
Crash_OK
Crash_OK's Avatar
Re: Crash's 69 K10
This week I installed some badging.. Kyle recommended that I use barrel nuts to easy the installation pains.. I decided I didn’t want to wait, after a few hours I finally got them installed. I will most likely use the barrel nuts in the future
I also installed the 4 wheel drive badging.. much easier to install..
Mark
Crash's 69 4x4 SWB
Old 08-04-2013, 02:03 PM   #1140
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: Crash's 69 K10
It keeps getting better and better!
Old 08-04-2013, 09:50 PM   #1141
Crash_OK
Crash_OK's Avatar
Re: Crash's 69 K10
Thanks Steve.. I think so as well.. Need to get the seats done, have Kyle finish his magic when he gets some time.. take it to a car show or two.. and then drive the hell out of it. We drove it over 250 miles today.. it is so much fun..
With that said, I am looking for my next project.. keep a eye out for a 67-69 Camaro for me..
Mark
Crash's 69 4x4 SWB
Old 08-04-2013, 10:01 PM   #1142
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: Crash's 69 K10
Oh, I'm always on the prowl for something good...
Old 08-05-2013, 03:32 AM   #1143
driller35
driller35's Avatar
Re: Crash's 69 K10
Wow the truck turned out awesome , Congrats and enjoy the ride, just wondering on your steering box setup, does the 77-79 gear box bolt rite in or needs mod, as I find the same with my stock one ,is way to loose and would like a tighter feel
Thanks really enjoyed watching your project
72 Chev Cheyenne Super SB 4x4 350,4spd,buckets, tilt,tach,am-fm,extreme tow hooks,Canadian Model Production 1 of 52 SOLD
70 Chev CST, 350 auto, PS, PB, AC, tach
driller35 is offline   Reply With Quote
Old 08-05-2013, 05:39 AM   #1144
Crash_OK
Crash_OK's Avatar
Re: Crash's 69 K10
Thanks..
Every thing bolts up except for the steering coupler (rag Joint). You will need one from the same year.
Mark
Crash's 69 4x4 SWB
Old 08-05-2013, 10:47 AM   #1145
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: Crash's 69 K10
This truck turned out great. The paint is unbelievable.
hgs_notes is online now   Reply With Quote
Old 08-05-2013, 12:56 PM   #1146
driller35
driller35's Avatar
Re: Crash's 69 K10
Thanks Mark , will track one down and update , I belive the wild horse ride u experience is very much from the short wheel base of truck and no weight to the truck either , mine is the same , I would like to ride in a stock 4x4 suspension setup and see how much difference there is, screamin did one hell of a job on that paint
Cheers Lloyd
Old 08-05-2013, 01:31 PM   #1147
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Re: Crash's 69 K10
Looks great mark!!
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 08-06-2013, 09:53 PM   #1148
71Sixer
71Sixer's Avatar
Re: Crash's 69 K10
Crash
Did you use the original tie rods from the pitman arm to the steering knuckle? I have the same lift kit on the truck I am building and I ordered the same drop pitman arm, but the stock tie rods that I ordered do not work. They are too long and will never line up.
Old 08-06-2013, 11:09 PM   #1149
Crash_OK
Crash_OK's Avatar
Re: Crash's 69 K10
Crash
Yes.. I replaced them, but they were the same as the ones I took off..
Mark
Crash's 69 4x4 SWB
Old 08-06-2013, 11:11 PM   #1150
Crash_OK
Crash_OK's Avatar
Re: Crash's 69 K10
Originally Posted by screaminchevypickup View Post
Looks great mark!!
Thanks Kyle... I am really proud of it...
Mark
Crash's 69 4x4 SWB
