Old 04-26-2013, 10:10 PM   #1
truckininarizona
Bench seat for 59
I know this has probably been asked a million times, but what kind of bench seats work well in 59s. I have buckets out of 2011 honda odysey, but they just don't look right.......! The custom one I like is like $2000, and that's not going to happen. Pictures would be great!!
truckininarizona is offline   Reply With Quote
Old 04-27-2013, 08:40 AM   #2
Rude Dude
Rude Dude's Avatar
Re: Bench seat for 59
Seat from 1989 to mid 90's chevy truck fit good
Rude Dude is offline   Reply With Quote
Old 04-28-2013, 06:57 PM   #3
sgtusmc
sgtusmc's Avatar
I used a 1988 C1500 seat in my 59.
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 04-28-2013, 07:34 PM   #4
SCHRUMGMC
SCHRUMGMC's Avatar
Is it hard to find an Original one ?
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 04-28-2013, 08:40 PM   #5
poncho_villa
poncho_villa's Avatar
I did like what sgtusmc did. Bought a bench seat from a 89 chevy at the pick'n pull for $100 and had it reupholstered for $500 in colors that match the truck. Fits in place like it was meant to be there. No regrets. $2K for a seat is robbery.
58 Apache short fleetside ona 64 chassis:
poncho_villa is offline   Reply With Quote
Old 04-29-2013, 10:22 AM   #6
entourageguy
Yellow truck club
entourageguy's Avatar
1989 1/2 ton chev. Works really well little thiner than original and gives up a bit of space for the steering wheel clearance. Some guys pie cit out a piece from the rear of the seat bracket to lay the seat back a bit.
Name:  seat change 012.jpg
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 09-17-2013, 11:34 PM   #7
NW Task Force
NW Task Force's Avatar
Question Lowering the bench..........who's done it?
I am doing the same swap with an early 90's chevy Silverado bench. My big question is............ "Has anyone on here cut the seat frame to lower the bench seat down" I would like to have my 90's Chevy seat sit lower so that the top of the rear seat back is level with the bottom of my wrap around window. I have heard stories of guys doing this and would like to hear it from someone and see some pics.
1957 Chevy Pickup 1/2T, stepside, big window, 77' Camaro subframe, 3rd gen Firebird rearend w/3.23 gears & disc brakes, 66' 283cid, TH350 auto, everything else is original
NW Task Force is offline   Reply With Quote
Old 09-18-2013, 02:01 AM   #8
truckininarizona
Re: Lowering the bench..........who's done it?
I used a seat out of an 1989 for my 59 small window. It touched both doors, so we cut 3 inches out of the center and narrowed it. That was easy and it fits great. My stitch guy said the frame is just pipe, so I would guess you could also lower it the same way. Not positive though! If no one else knows, let me know and I will contact my stitch guy and find out for sure. A guy could cut out a section of the bottom stand and lower it that way, but then it would probably be sitting to close to the floor. Mine is a perfect height for a small window...........but too high for the big window I'm sure.
Old 09-18-2013, 10:57 PM   #9
NW Task Force
I appreciate the input, something to think about. I am sure I read someplace on the board where someone did this........just can't find the post.
Old 09-18-2013, 11:02 PM   #10
Dan in Pasadena
Dan in Pasadena's Avatar
The "post" is #6 above, lol!
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 09-19-2013, 12:08 AM   #11
NW Task Force
Your referring to "pie cutting" the rear part of the seat frame?
