Old 09-19-2013, 10:40 AM   #1
88Ironduke
Need help putting a location to this wire....
Subject truck is 72' C-10 with the 250/3OTT. I have a new engine harness that I bought from one of the vendors here on the forum. Its nicely built and looks really good. I have identified everything on the harness except for one wire. Its a large pink, looks like a 12G lead with a connector that is similar to an HEI but is not. I have been digging thru the schematics and the location or use has eluded me. My assessment is electric choke? The wire is wrapped into the section of the harness leading across the engine over to the points distributor. It makes sense but I expect to be wrong.
http://i1291.photobucket.com/albums/...psdcc1f609.jpg
Here is a picture where the connector goes in to the fire wall. Its the double pink set, 2nd from the right on the top row.
http://i1291.photobucket.com/albums/...ps27a470d6.jpg
What is it and can it be repurposed to supply power for an HEI distributor? This harness is so simple yet this one lead has been bugging me.
Thanks in advance.
88Ironduke
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!!
My Build Thread: Project 72' Green
http://67-72chevytrucks.com/vboard/s...d.php?t=587932
88Ironduke is offline   Reply With Quote
Old 09-19-2013, 02:08 PM   #2
Fitz
Re: Need help putting a location to this wire....
Thanks in advance.
88Ironduke
Yellow and purple go to starter. See Diagram.
Fitz is offline   Reply With Quote
Old 09-19-2013, 04:37 PM   #3
88Ironduke
Thanks but those are the easy ones to pick out. I'm looking for the purpose of the large pink wire. It is tied to the same location on the firewall plug as the distributor ballast circuit. I can't find the pink wire on any schematics.
Any one else?
88
Old 09-19-2013, 05:50 PM   #4
marvgarr68
marvgarr68's Avatar
looks like its for hei. Is there a cloth white wire in the harness? If not its for hei if you do have the ignition wire and the heavy pink one is tied into it at the plug then its for hei. Pink is for hei in later model trucks with factory hei
1976 k20, 350 built, 44/14 axles
1968 c10 6.5 turbo diesel,t5 trans
1977 gmc c3500 dually, crew, 4-53t, 5&3 trans
http://67-72chevytrucks.com/vboard/s...d.php?t=591188
marvgarr68 is offline   Reply With Quote
Old 09-19-2013, 06:14 PM   #5
jaros44sr
jaros44sr's Avatar
In GM language, pink is always 12volt switched, so you could use it to power HEI or choke
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-19-2013, 07:15 PM   #6
bigmac73
bigmac73's Avatar
if you have upgraded to a HEI ignition then you should get rid of the yellow wire to the starter, that was for extra power while starting with the old set up and you should not be hooked up to the resistor wire that went to the old coil, your HEI will not get the full voltage required.
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 09-19-2013, 07:49 PM   #7
88Ironduke
The truck has been upgraded to HEI and does not have electric choke. The cable end looks really close to an HEI connector but it is slightly different. I have the correct connector so worst case I'll solder it in place and call it good. I'm pretty sure it was intended for electric choke but I have a manual one. Life is good.
88Ironduke
Old 09-19-2013, 07:53 PM   #8
hooverfish
hooverfish's Avatar
My pink wire goes to the elec. choke. Its a 72 350 with quadrajet, so I don't know if this is valid for your truck. But I suspect your initial guess was correct. I would post a picture but cannot get it to work, even after downsizing it.....
Larry
84 Chevy SWB, "Roy", dark blue orig paint, 6 cyl auto, PS, 88,000 miles.
72 Highlander LWB "Olive" med olive over lt yellow, air, 77,000 miles (sold)
"It's a sorry man who can't find his wife a good job"
hooverfish is offline   Reply With Quote
Old 09-19-2013, 09:00 PM   #9
slow-1
slow-1's Avatar
If you copy the "IMG" link from PB and paste it in your post, the picture shows up in the thread.
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline   Reply With Quote
Old 09-19-2013, 09:47 PM   #10
88Ironduke
Awesome. Just learned something new.
Old 09-20-2013, 09:44 AM   #11
hooverfish
hooverfish's Avatar
what is PB ?
Larry
Old 09-20-2013, 09:59 AM   #12
FirstOwner69
FirstOwner69's Avatar
PB=photobucket. Had me thinking a while also.
FirstOwner69 is offline   Reply With Quote
