09-26-2013, 10:12 PM | #1 |
Spark plug problem
Where are the spark plugs on a cummins, I can't find them
09-26-2013, 10:58 PM | #2 |
Re: Spark plug problem
Troll
09-27-2013, 09:32 AM | #3 |
63 k20 with cummins 4bt, owned sence 1982 |
09-28-2013, 06:41 AM | #4 |
Aren't they attached at the end of the spark plug wires.
BRIAN 1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater. My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509 |
09-28-2013, 12:52 PM | #5 |
In a box behind the seat? That's where mine are, at least until I get home.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
09-28-2013, 01:28 PM | #6 |
I keep them in a van down by the river
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
09-29-2013, 10:54 AM | #7 |
they are between the blinker fluid reservoir and the kaneuter valve
"DON'T TOUCH THE TRIM!!"-Early Kyler |
09-29-2013, 08:47 PM | #8 | |
Posted via Mobile Device |
09-29-2013, 08:51 PM | #9 |
I built it
no muffler bearings. just piston return springs.
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
12-19-2013, 11:06 PM | #10 |
You have to take the Johnson rod off with a left handed screw driver (metric of course). Make sure to run hollow spark plug wires.
12-19-2013, 11:21 PM | #11 |
One foot in front of the other
Is it a vette motor?
12-20-2013, 02:18 AM | #12 |
While changing spark plugs always check for a cracked maniform...
12-20-2013, 02:08 PM | #13 |
They are under the coils
01-25-2014, 12:25 PM | #14 |
This Cummins does have spark plugs! It's a Cummins Westport.
