#1251 |
![]() Join Date: Feb 2013
Re: How about some pics of 67-72 Burbans!
Here's an update on Earl. New 15x8 rallyes, 255/70R15 radials, Bilsteins, and sway bars. After the 1800 mile drive from Hobbs, NM to central PA I'll cut a front coil and add a 2" block out back and call the suspension 'temporarily' done. Then some engine and driveline upgrades, fix the rust, and paint. Gotta decide on satin black/white, or medium olive/white (original). Hmmm...
![]() R |
#1252 |
Southern Nevada Coal Roller
1969 suburban man
How did you do your third row seats? I need to add a third row and get my burb running. Cramming into a exra cab truck with 4 kids is no fun. Posted via Mobile Device
Chris 72 Suburban, 1 ton dodge chassis 4wd cummins, DTT 47rh 89%, PDR VE 3200 spring, PODS, Piers Turbo. 36 Chevy P/U rat rod project. 4bta cummins ![]() |
#1253 |
I took my stock third row on the suburban and flipped it around backwards so I had more cargo room. The kids just climb in from the tailgate and ride backwards. They seem to like it.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
#1254 |
C10 Club Tennessee
Do you have some pics of that?
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
#1255 |
CumminprwII --My third seat is out of a early 90's Burb and mounts in the factory floor clips. The second row has a split 70/40 seat that folds forward to get to the third seat. Real nice clean setup to install the seat.
#1256 |
Nice 1969 Suburban man.
Very clean. did you mount the third row into the wood or did you cut out the back area of a 90's suburban? I have the same set up in mine but 80's seats front buckets and middle bench. I just want to make sure how ever I mount a third row it will be safe for my kids. I been thinking about getting new middle bench and 3rd row. I just not sure about mounting yet. Thanks for the pictures and the help Chris
#1257 |
The top one and bottom one are my 2 favorite pictures I have of my Suburban. The middle one I took last night while out cruisin'.
My 72 Suburban Build - http://67-72chevytrucks.com/vboard/s...d.php?t=454019 79 Volvo Turbo LS Build - http://67-72chevytrucks.com/vboard/s...d.php?t=594252 Buggy Bed for son - http://67-72chevytrucks.com/vboard/s...d.php?t=657350 |
#1258 |
Chris, I did not install the seats, they were in the car when I purchased it so I can not say for sure if they are mounted in wood or the metal section.
I will say this, the guy I got the car from was very safety minded as he would not let his grandkids ride in the car until he had all the seat belts installed and working properly. I have a bad back so I can not look under the car, but the factory clips are very solid and if not in metal I am sure they are backed up with metal from the bottom. When the seat is in place it is very secure and seat has no play. He put a lot of work and time in making it right. Good luck with your's, Tom |
#1259 |
Thank you all for this very enjoyable post. Puppyluppy
#1260 |
Addicted user
Bruin D just amazing ride! Your kid loks pretty happy up front, my son is around the same age and loves the "garage truck"
1972 2wd Blazer - 95% completed 2015 Silverado 1500 4wd -z 2008 AERO 9-7X (TBSS cousin) LS2 1970 Jimmy 4wd - future project |
#1261 |
![]() Join Date: Jul 2012
I sold this one today 1970 2wd.
#1262 |
This is a picture of my donor suburban. lots of rust and rot. Building quad cab truck.
#1263 |
Junior Member
Stopped by "Little shop of horrors" today in Lawrenceburg, Tn and seen if Eric had anything new in the shop. He does some really nice work and his fab skills are off the charts. He said this sub was getting ready to go home to its owner. I seen this thing under construction a couple times. Dope!!
Posted via Mobile Device Posted via Mobile Device
1969 impala conv 427 #s loaded. dad bought new 1969 "Judge" RA-3, rare warwick blue/white, #'s 1968 vet convertible #s 427/435 tripower (sold) 1968 belair 2door post #s 427/385 1936 ford 5w coupe dads 1st car 1969 camaro ss (17,xxx) miles Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project. |
#1264 |
So how do i locate a headliner for a 72 suburban,mine has none?
RT |
#1265 | |
Start with construction paper or cardboard and make templates by taping it to the bows and cutting it to size. Once you've got patterns you can chose your material for the backer, and covering, and copy the patterns. Then drill holes through the backer and mount it with screws to the bows. After that, pull it down and use upholstery clips to fit the holes and push them through the backer before gluing the material on. Then just snap it in place, and if needed add a few strategic screws if the backer doesn't conform well enough to hold.
1969 C10 Suburban 350 1963 Falcon gasser 464 BBC 1946 Austin 327 SBC gasser |
#1266 |
This is my 71 burb,Originally came from Great Falls montana.The previous owner brought it to canada from the states but it sat for about nine years before i bought it this past summer.When i pulled out onto the road for a test drive and the factory installed underdash air conditioning still worked,it was sold!I put 2 1/2" drop spindles on the front, bagged the rear about 2 days after i got it home,and 18" rims i had kickin around.Then 2 days of buffing later,that original paint came back gleaming!
#1267 |
Very nice, is that upper door molding? I hadn't seen that before!
#1268 |
I have same upper door moulding on my 1970
1979 C-10 LWB |
#1269 |
Ridin' Dirty
Another nice Burb! In Alberta too!
1978 C3500 Crewcab (Project) 1979 C2500 Crewcab (Driver/project) 1988 R2500 Crewcab (Driver) 1988 V3500 Crewcab 1988 R2500 Crewcab (Mint, Ex Fire Dept) 1968 Chev Suburban (4x4 conversion) LINK 1970 Chev C20 Suburban (driver/cruiser)LINK 2005 Impala (Incognito vehicle) 2004 Yukon XL Denali (Kid hauler) 1947 Case tractor Facebook Page(1000's of pictures of GM cars and trucks organized into albums) YouTube Channel |
#1270 |
Hey, hookedonchevys, very nice burb. Am I the only Canuck outside of Alberta with a 3-door Burb? HAHA
Bob ![]() |
#1271 |
hey guys, here are some pics of the family panel it was my dads old work truck. Then grandpa, now mine
![]() changes are coming ![]()
![]() 67' Chevy C10 Panel 06' Mini Cooper S |
#1272 |
here are a few more
#1273 |
Sorry guys wrong thread!
#1274 |
Perfect thread!!!
Sweet panel. Very 80's. I love it.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
#1275 |
80's?!? Looks like a 70s Shaggin' Wagon!
1979 C-10 LWB |
