10-17-2013, 12:07 PM | #1 |
Re: Extreme or Mild Dropmember
Just take your time and do your research, and you will do fine. I'm actually looking at Michigan Metal works uppers and lowers. Not much dif in price but a little dif look. Lots of options out there, Not to put PB down in anyway. They are masters at what they do and make great products. All I'm saying is get what suits you the best and makes your truck you. I'm sure you will have a sweet ride when your done.
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase 1955 Chevy Stepside "Dudley" My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288 1972 Chevy C10, Project "Chevro~Layed out" Nether Storm Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523 |
10-17-2013, 12:27 PM | #2 | |
10-17-2013, 01:57 PM | #3 |
Thanks for the replies, the more I think about it the more the extreme one catches my attention. Like I said if hate to do all the work and not be satisfied. I'm taking it porter built and accuser are pretty much the best in the business with regards to the c10? Not taking anything away from the other companies, but I haven't read anything bad about either one. If ordering from porterbuilt, the supply everything I'm going to need correct, as long as I order the accuser air management system from them. (mounts, bags, etc.)
