Well i need help. Surprise surprise right? On my 77 k10, i put a new blower motor and fan blade (metal) but i have nothing through the vents. I have attached pic of my outside wiring where i think the problem is. Also my heater core hoses are only... Lukewarm... Thought they were supposed to get hot as hell?
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
Re: Heater help!
It appears you don't have vacuum connected to your amplifier on the firewall. The black round thing in the front left of your picture. That could keep your blend door from opening. Warm, not hot heater hoses sounds like a bad thermostat.
Re: Heater help!
I'll get a new thermostat. Little assurance. It has a vacuum hose goin to the ball thing it goes over the box. Think it goes to the back. But my blower doesn't turn on at all :/
![]() Join Date: Jun 2010
Re: Heater help!
So are you not getting power to the blower motor? Also you might want to flush the heater core while you are in there and change the thermostat as you said.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
Re: Heater help!
See the thread here titled "Heater Blower" about possible causes why your blower motor isn't working. The black round vacuum reservoir only appears to have one vacuum hose attached to it. It needs a vacuum hose from the carb to it then another hose goes inside the cab to the heater control.
Re: Heater help!
Well small update. I put i a bew thermostat 195 since it's getting cold this timma year. Hoses only get kinda warm not hot :/ same cab before did this too
![]() Join Date: Oct 2008
Re: Heater help!
Its possible, though not probable, that the heater core is nearly completely clogged so that little to no fluid is running through it.
Also, did you check the blower fuse? |
Re: Heater help!
Will check fuse tonight. Other than this n my driveshaft i'm ready to rock. Where does the big red wire go?
Re: Heater help!
Looks like the wire that goes down to your starter but i can't really tell but that would be my guess.
Re: Heater help!
So it comes out of the firewall by the ac and heater wires to the starter? Seems odd. Does the vacuum line go to the front port or back port on the ball thing?
Re: Heater help!
Well i can't tell where it's coming from in your picture but the connector on the bottom and thickness of wire looks like the one that goes to the starter.
Re: Heater help!
Red wire might be the one that runs across the firewall to the junction block.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
Re: Heater help!
Think i'll look behind the heater box tonight. Surprisingly ye heater core doesn't leak or anything. What about all the green wires? Can i cut-n-tuck them? I won't reinstall the ac.
Re: Heater help!
Honestly, all of that wiring is a little scary looking. You might want to get a wiring diagram and clean up some of those wires. Its probably not a good idea for us to be guessing what wires are what. That could lead to some serious problems if wrong.
#15 |
Re: Heater help!
It starts n runs string n fine. All lights work just the heater >:/ aggrivating! I'll look tonight for one n i'ma try n get ridda as much as possible for simplicity
#16 |
Re: Heater help!
is there a vacuum controlled valve for hot water to the heater core? if so, bypass it and see if it gets hotter. also the heater hoses have to be hooked up where the return hose goes to the water pump and the supply hose to core comes from intake. I think thats the way it goes.
#17 |
Re: Heater help!
Fist thing to do would be to check the power at the blower and go from there. That box the wire to the blower motor comes out of is the relay switch, that would be the next thing. Sometimes you can hit the relay switch and get it going for a bit. There is also a resister but high power is not affected by this.
Get the blower working and then go from there.
Scott 87 Chevy 2WD SWB, 88 4x4 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=610652 |
#18 |
Re: Heater help!
#19 |
Re: Heater help!
So the red goes to the other side (left) of the junction block... And green goes to... Evap control switch. Do i need the evap switch for the heater or no?
#20 |
Re: Heater help!
Not sure you need that if you are not using your AC. Did you check the power to the motor?
#21 |
Re: Heater help!
I will tonight after work.
#22 |
Re: Heater help!
Are you driving this truck trying to get it up to temp or just letting it set and idle. I have had a couple of vehicles that wouldn't get very warm until they were driven. It should still be getting some temps going though.
#23 |
78K & 79C Jimmys
Re: Heater help!
lower right of pic the (brown 50),dosn't that go up in the dash with the radio wires?
if you can test it, to run ok ,from the batt I'd check the blower coils
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#24 |
Re: Heater help!
Idk if it is or not. UPDATE: Plugged in the vac hose to the FRONT of the ball and the back going into the cab somewhere, also put the red wire onto the junction block and no difference
![]() Updated pic showing more green wires unpluged what is that 2 pronged thing on the bottom right of the box? Needed?
#25 |
Re: Heater help!
I thought that was the resistor?
Tags |
blower motor, heater core, heater wiring |
