Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-14-2013, 10:37 PM   #176
69GMC910
MOTORHEAD!
69GMC910's Avatar
Re: 496 to be DYNO'D!
I hope to push 118mph... Next year I hope to launch it from at least 2500...
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 10-14-2013, 11:55 PM   #177
Captainfab
60-66 Nut
That's a good run IMO, especially for the first time out. Congrats.
Old 10-14-2013, 11:59 PM   #178
69GMC910
MOTORHEAD!
69GMC910's Avatar
Thank you! It was a rush!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 10-15-2013, 12:02 AM   #179
mud.man.rj
mud.man.rj's Avatar
A 140lb weight saving is quite a difference, think 100lbs is a tenth of a second alone.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 10-15-2013, 01:30 PM   #180
Super73
Super73's Avatar
Nice first pass. 118mph should be enough to go mid/low 11's
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 10-18-2013, 08:28 PM   #181
bbcmudtruck
What fuel pump are you running? I'm running an almost identical motor. Did you run a cstraub hyd roller? I've talked to mark and thats what he recommended for me. The guys over on chevelle.com are getting nasty horse power out of the afr heads! My dad said I was stupid for spending that much money on them. Can't wait to get it finished up! I really want to put him in his place. Also, what stall and trans are you running? IE, manual valve body etc..?
bbcmudtruck is offline   Reply With Quote
Old 10-19-2013, 11:10 PM   #182
69GMC910
MOTORHEAD!
69GMC910's Avatar
Holley 12-454-? 170gph. I dunno if Mark got the cam from cstraub. He has been using this cam in this motor for quite a while... He told me a couple months back that the identical engine to mine with more refining is making upwards of 725 now... Mark is always trying to make better power, and is obviously very successful!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 11-19-2013, 08:46 AM   #183
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
With timing locked out and slicks it may not work as well as you want it to.. Locked Vs unlocked is a whole chevy ford deal.
GMR-PERFORMANCE is offline   Reply With Quote
Old 11-19-2013, 10:40 AM   #184
Bad70sbchevy
Bad70sbchevy's Avatar
Actually unlocked is the "ideal" setup since you don't need as much advance down low, but for a strip truck where you spend most of the time in the top end in you power band, the optimum timing does not vary hardly at all with higher rpm so you can get away with locked timing since the motor hardly spends any time in the lower rpms (or none with a high stall TC).
1970 Chevrolet C-10 w/355sbc
2010 Silverado Daily Driver
1971 Mercedes 280sl project car
Bad70sbchevy is offline   Reply With Quote
Old 11-19-2013, 10:50 AM   #185
GMR-PERFORMANCE
If the convertor is right and the tires gear ratio and tire size etc works then yes you can keep timing locked however when things are not "perfect" if the engine bogs for what ever reason you are done .. way too much advance for given rpm etc. I would unlock it while you get the set up dialed in then once you are in the ball park then lock it out. But I see a plate on that truck so it does get driven on the street correct??
Old 11-19-2013, 01:04 PM   #186
bbcmudtruck
Well my guess from after talking to mark is that your running an ISKY hyd roller. Thanks for clarifying the fuel pump for me, wanted to be sure I had the right one. As far as the timing goes, a street ride should definitely have the vacuum advance hooked up. However its his motor and the fella who built it for him is more than knowledgeable. If I were guessing, its still timed exactly how it came off the dyno. Just be sure mark knows that your driving this thing out on the street! That little bit of info needs to be relayed to the builder.
