Old 11-19-2013, 05:49 AM   #76
Hart_Rod
Hart_Rod's Avatar
Re: Trouble codes
Originally Posted by jorgensensc View Post
Look at your grounds again. I've read over and over misfires on a bank keep coming up as ground issues.
Roger that Shawn, the thing is, there is only one grounding wire in the entire Speartech harness. So if grounds were a problem, you would affect both sides, and not just one. Is there anything mechanical that could cause this problem?
Hart_Rod is offline   Reply With Quote
Old 11-19-2013, 02:07 PM   #77
OldCreek
OldCreek's Avatar
Re: Trouble codes
Random thoughts, but I'm no mechanic….
Put a stethoscope on each injector to see if they're firing correctly.
Pull each plug and ground it and then watch it spark. How do the plugs look?
Fuel rail clogged? Bad pressure regulator on the rail?
Intake manifold leak?
It's been my experience that one bad injector will make your trims on that side look bad…but not misfire multiple cylinders.
Good luck with what is probably very frustrating!
Wil
also, have you run an ohmmeter on your harness to confirm wiring?
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 11-19-2013, 02:40 PM   #78
Hart_Rod
Hart_Rod's Avatar
Re: Trouble codes
Wil
Thanks OldCreek. The injectors, coil packs and O2's are good becaue I swapped them from side to side with no change in symptoms. I'm starting to lean towards a intake manifold leak or a bad ground somewhere. I'm going to do a smoke test tonight and see if I can eliminate that. If that's not it, I will start checking wires.
Old 11-19-2013, 10:05 PM   #79
clinebarger
Re: Trouble codes
Originally Posted by Hart_Rod View Post
Thanks CB. Any thoughts on the possible problem?
Check the harness first....Make sure all Injector drivers on that bank are wired to the correct cylinder.
Make sure all Ignition coil drivers are wired to the correct cylinder.
Load test the Coil grounds, I use a Halogen sealed beam headlamp, Then check ALL ECM grounds.....Not many with a E38.
Load testing is the ONLY way to truly check a ground. If you need help on test procedures, Let me know.
clinebarger is offline   Reply With Quote
Old 11-19-2013, 10:14 PM   #80
Hart_Rod
Hart_Rod's Avatar
Re: Trouble codes
Thanks CB. Do you have pin out for the injector drivers and coil drivers?
Old 11-20-2013, 12:44 AM   #81
clinebarger
Re: Trouble codes
Can you see the diagram that I posted earlier? Some of the files I have don't download well on this site (too small).
Old 11-20-2013, 11:31 AM   #82
Hart_Rod
Hart_Rod's Avatar
Re: Trouble codes
CB - I printed it, but the resolution is not very readable. Can you email it to me @ robert.hartley@navy.mil? Thanks,
Rob
Old 11-21-2013, 11:01 AM   #83
Hart_Rod
Hart_Rod's Avatar
Re: Trouble codes
CB - Whats the procedure you use for the load test?
Last night I did a compression check on all 8 cylinders just trying to eliminate any possible mechanical problems. All cylinders were 215+ psi. Friday I will do a smoke test to make sure I don't have any vacuum leaks. If that checks well, I'll start digging into the wiring....
Old 11-21-2013, 02:27 PM   #84
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Trouble codes
Did you ever take care of that metal-nub that you showed me the Manual pictures of?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-21-2013, 03:21 PM   #85
Hart_Rod
Hart_Rod's Avatar
Re: Trouble codes
Not yet. I'm going to do a smoke check to see if I have a vacuum leak first.
Old 11-21-2013, 08:20 PM   #86
clinebarger
Re: Trouble codes
Disconnect the ECM & TCM BEFORE performing any test, The last thing you want is to fry/brick a module. Unplug the ECM & Unplug the trans.
Load testing is very straight forward. I use a headlamp because you can SEE if the ground is poor, If the lamp is bright, the ground is good. If the lamp is yellow/brown or doesn't come on....the ground is poor.
Test it straight to the battery first to get a feel on how bright & color the light is.
The diagram should help, Hook one side of the Lamp to the positive side of the battery.
With a suitable probe & lead hooked to the other side of the Lamp......Probe the ground circuit your testing, This will load that circuit.
What I mean by "Suitable Probe" is Don't stretch out the terminal in the connector your probing. Or damage the plastic connector.
Old 11-22-2013, 07:58 AM   #87
Hart_Rod
Hart_Rod's Avatar
Re: Trouble codes
Thanks CB! I'll be working on it this weekend.
Old 11-22-2013, 10:37 AM   #88
faribran
Re: Trouble codes
CB thank you for posting the "load test".... i will file this away for future use. as will others i am sure.
faribran is offline   Reply With Quote
Old 11-26-2013, 09:57 AM   #89
Hart_Rod
Hart_Rod's Avatar
Re: Trouble codes
Quick update guys. I messed around with the truck all weekend, with very little luck. Did a compression check, all cylinders 220 psi +/- 5. Did a smoke check, could not find any vacuum leaks. Stonewalled. Totally scratching my head.... I had set up an appt to get the exhaust put back on yesterday. I almost cancelled it since the truck would hardly run, but since I had taken the day off, I went ahead and called a rollback and had it hauled to the exhaust shop. I had planned on putting on some new Magnaflows that I had laying around, but they wouldn't fit, . I had wanted to switch the Magnaflows because I had read that they sound better with the LS motors, oh well....And with the new crossmember I built for the 6L80 tranny, my electric cutouts weren't working out so well either, . So I just told the exhaust guy to reconnect the Flowmasters that were on there (50 series) and at least I could do some tuning without getting fumigated. OK, so we get everything hooked up and I start the truck up just to see how it sounds....and to my surprise, I like it! And to my even bigger suprise, I hook the HPTuners scanner up and all the issues I was having with misfires and crazy Fuel Trims were gone!!!! Other than running a little rich, the idle is good and it's not throwing any codes. So the Moral of the story is, NEVER do any tuning on a FI motor unless you have the exhaust on and don't believe everything you read on the internet, . I'm eating some serious humble pie, I would never have thought that not having the exhaust on would have created the "symptoms" that I was seeing going on with my motor. Go figure. I did learn a lot through this experience, and will be a better "tuner" because of it. Now I have to undue some things I did when I was chasing a problem that wasn't there, .
Old 11-26-2013, 12:46 PM   #90
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Trouble codes
Interesting. I don't think I realized you were tuning running open headers? So lets see the exhaust!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-26-2013, 01:13 PM   #91
Hart_Rod
Hart_Rod's Avatar
Re: Trouble codes
Well I technically I wasn't trying to tune it. I was just trying to get it running well enough to load onto a trailer to take it to the exhaust shop. Big mistake. Won't happen again. The exhaust is nothing special. I cut the orginal exhaust in from of the mufflers, so all he had to do is go from the headers to the mufflers. I'll try to post some pictures this evening.
Old 11-26-2013, 03:36 PM   #92
smoky02
Location: Sunny, Florida, some might call it South Alabama
Re: Trouble codes
What cut out where you using? And why didn't you like them?
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 11-26-2013, 03:55 PM   #93
Hart_Rod
Hart_Rod's Avatar
Re: Trouble codes
I have QTP cutouts and really like them. I had them installed prior to doing the LS install. My new tranny crossmember is in the way. We could have made them work, but I just wanted to get the exhaust on so I could get it running. After I get everything lined out, I'll probably have him redo everything.
Old 11-26-2013, 06:32 PM   #94
Custom 68
Custom 68's Avatar
Re: Trouble codes
yea I didn't realize you didn't have full exhaust either. I am guessing you were getting some air back in and causing the o2 sensors to freak out so to speak. Glad it is coming together much better now.
good luck
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 11-27-2013, 12:10 AM   #95
solidaxel
solidaxel's Avatar
Re: Trouble codes
YES, thank You, I will file that right next to using a flasher for checking shorts to ground
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 11-27-2013, 11:24 AM   #96
Hart_Rod
Hart_Rod's Avatar
Re: Trouble codes
Haven't heard this one. Please explain. TIA.
Old 11-27-2013, 11:56 AM   #97
solidaxel
solidaxel's Avatar
Re: Trouble codes
When looking for a short that keeps blowing a new fuse, temp. wire a flasher can to the fuse posts, when it stops "clicking" and you have isolated the short, you have a good circuit, now replace the fuse
LS 3 4L70E
Old 11-27-2013, 12:52 PM   #98
Hart_Rod
Hart_Rod's Avatar
Re: Trouble codes
Sweet!
Old 12-08-2013, 11:55 PM   #99
Hart_Rod
Hart_Rod's Avatar
Re: Trouble codes
I'm still getting a couple of trouble codes but I think I might just need to delete them out. Here they are:
[] P057C - (SES) (Pending) (Old) (History) (Current) (Immature)
[] P0621 - Generator L-Terminal Circuit (Pending) (History) (Current) (Immature)
[] P0622 - Generator F-Terminal Circuit (Old) (History) (Current) (Immature)
[] P2537 - Ignition Switch Accessory Position Circuit Low (Old) (History) (Current) (Immature)
I'm running a 2 wire alternator off of a 2004 Chevy truck (140A). I had it checked and it checked out as "good". Any thoughts?
Old 12-09-2013, 01:16 AM   #100
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Trouble codes
The generator codes may be because the 04 alternator has an internal regulator, and your engine/pcm would normally use a PCM controlled regulator. It doesn't see the voltage it would be trying to control. OR you have a short on one of the wires.
The p057c code came up as an SES for failed cruise control module. I'm guessing you might have something wired off the TCC/brake switch incorrectly (lol I know you and JorgenSC have gone back and forth on diagrams for this in the other thread).
can't find anything on the p2537
