Old 12-09-2013, 11:45 PM   #26
papastrk
Re: 1954 3100 C4 Tube Chassis Build
Frame looks nice. What size tubing and what wall thickness did you use?
papastrk is offline   Reply With Quote
Old 12-10-2013, 12:20 AM   #27
oldman3
oldman3's Avatar
That's looking great, ready for more...Jim
oldman3 is offline   Reply With Quote
Old 12-10-2013, 12:37 AM   #28
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
The frame is 2x4 .120 wall. Its just a bit thicker than my factory frame and since its a box instead of a C channel I figured it would be ok. I looked online and found a few aftermarket companies building chassis that are 2x4 .120 wall so I feel it should be alright. Thanks for the compliments guys.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 12-10-2013, 08:38 AM   #29
papastrk
Thanks for the reply. Will you fabricate a front crossmember or use the GM original? I'm curious about the tie rod clearance. The Vette spindle locates the integral steering arm so high that it makes it difficult to get the tie rod to clear the frame rail.
Old 12-10-2013, 09:26 AM   #30
STOCKISH
STOCKISH's Avatar
My plans are to make a cross member based on the C4 cradle measurements. I will notch the frame for the steering rack. If I didn't notch the frame the cradle would hang low and the ride height would probably be near stock height. Thanks for the comments.
--Josh
Old 12-10-2013, 11:16 AM   #31
99 to Life
99 to Life's Avatar
looking good, can't wait to see some more unfold.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 12-10-2013, 04:49 PM   #32
STOCKISH
STOCKISH's Avatar
Thanks man. I'll be back at it tonight.
--Josh
Old 12-10-2013, 06:03 PM   #33
69CST-V
69CST-V's Avatar
Am I late? This build is moving fast. Looks great. sub'd
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 12-10-2013, 06:23 PM   #34
STOCKISH
STOCKISH's Avatar
Thanks man, going to get some more done tonight for sure. I have fishplates I need to TIG on and still need to square the cab up on the chassis, determine wheelbase, ride height, etc. I threw a fender and running board on last night just to get an idea. Looks sick! I believe I will have about 6 inches under the front crossmember that supports the core support, etc.
--Josh
Old 12-10-2013, 10:16 PM   #35
xpickup
xpickup's Avatar
1972SuperCheyenne, great job on the frame. I had to notch the hell out of the frame for the steering. I then bent some 1 5/8 tubing to go from the bottom of the crossmember to the bottom of the radiator crossmember to add some strength back into the front of the frame. Going to be a great build.
Shannon
xpickup is offline   Reply With Quote
Old 12-10-2013, 11:48 PM   #36
STOCKISH
STOCKISH's Avatar
Thanks alot Shannon, means alot. Issues with the welder tonight, no progress unfortunately. Will get back at it later this week.
--Josh
Old 12-15-2013, 10:06 PM   #37
sqrlnts
Along for the ride! Great work so far!
sqrlnts is offline   Reply With Quote
Old 12-15-2013, 10:37 PM   #38
STOCKISH
STOCKISH's Avatar
Thanks guys, not alot of progress this weekend. Hopefully soon though.
--Josh
Old 12-20-2013, 04:36 PM   #39
STOCKISH
STOCKISH's Avatar
Got started on the fish plates on the rear of the chassis. More this weekend hopefully!
--Josh
Old 12-20-2013, 05:07 PM   #40
99 to Life
99 to Life's Avatar
those look nice, you have them made?
Old 12-20-2013, 05:18 PM   #41
mcbassin
Still Learning
mcbassin's Avatar
Very cool braces! Water jet? Looks like a lot of welding too.
Old 12-20-2013, 05:24 PM   #42
STOCKISH
STOCKISH's Avatar
I did. A place called Mid Atlantic Fabrication in Knightdale NC made them. They are 3/16. He charged me $200 for eight of them.
--Josh
Old 12-20-2013, 11:05 PM   #43
xpickup
xpickup's Avatar
1972SuperCheyenne, nice looking fish plates. That will be nice and strong.
Shannon
Old 12-21-2013, 12:15 AM   #44
STOCKISH
STOCKISH's Avatar
Thanks Shannon. I sure hope so!
--Josh
Old 12-21-2013, 12:34 AM   #45
oldman3
oldman3's Avatar
Looks sweeeeet...Jim
Old 12-21-2013, 01:03 AM   #46
skymangs
skymangs's Avatar
Sweet build. I'm in!
skymangs is offline   Reply With Quote
Old 12-22-2013, 11:51 AM   #47
STOCKISH
STOCKISH's Avatar
Sweet, glad youre tagging along. I need all the help I can get!
I hope to get the rear cab mounts welded to the chassis, square up the cab and get the rear of the chassis finished up today.
--Josh
Old 12-22-2013, 01:16 PM   #48
dubb702
Great build I will be in class on time lol
I have a tube chassis that I bought from Tucker's here in Vegas but it wasn't finished so I will be asking a lot of question here thanks for any help
First question the rear on frame where the frame kicks up and back down (c-notch) what are your measurement and how much bed floor raise you have
How low will it lay .
My frame was made @ stock measurement and I will be adding shock waves later and would like to lay low as I can so I think my rear c-notch area may need to be redone
I included pict
dubb702 is offline   Reply With Quote
Old 12-22-2013, 06:17 PM   #49
STOCKISH
STOCKISH's Avatar
I made my frame the same as the stock frame except the notch over the rear axle is 6 inches higher and a few inches longer. The other measurements all came out of my assembly manual. Thanks for the watching.
--Josh
Old 12-22-2013, 08:01 PM   #50
dubb702
