Bump stop perches
How low can I lower the front of my 77 1/2 ton before I need to remove the bump stop perches on the lower a-arms? Just to clarify, I already have drop spindles.
Re: Bump stop perches
I bet they'd clear with a 3" spring drop pretty easy. You could whittle the rubber a bit to net you more. I kinda wish I'd left mine on or cut the whole assembly down a little.
A 2in spring drop will set the tip of the rubber practically at the contact point. If you remove the rubber the perch will ocationallt make contact on hard bumps.
John 82 Chevy Silverado 350ci/TH350 ![]() |
^What he said.
If you live in Oklahoma click this link |
