Closed Thread
Old 01-25-2014, 10:36 AM   #26
contagious102
contagious102's Avatar
Re: What did you do to your truck today part II.
Got the new shoes on the project.!!
Go Fast and Have Fun.!!
My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185
contagious102 is offline
Old 01-25-2014, 10:33 PM   #27
TJ's Chevy
TJ's Chevy's Avatar
^^^Fantastic work!!!^^^^Love yer fuel injection system!!!
What I did with mine today....used it to haul tools and stuff around while I was working in the field.
TJ's Chevy is offline
Old 01-26-2014, 06:56 PM   #28
Lugnutz65
Lugnutz65's Avatar
I'm getting my grille support ready for media blasting. Fixed a couple of dents today. This was the worst of them. If I can do it - so can you! When I get scared about trying stuff I have never done before I hafta keep reminding myself - it's a truck, not a Ferrari!
Just heat the metal. Bang on it. Heat. Bang bang bang. Heat. Bang bang bang.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline
Old 01-26-2014, 09:10 PM   #29
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Thanks for starting this thread.
And thanks to those who added links to the old, and from the old.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline
Old 01-26-2014, 09:10 PM   #30
AngryPirate
AngryPirate's Avatar
I picked up another truck today for parts. It's a GMC, but as far as I know most stuff is interchangeable.
It has the original GMC 305 V6.
AngryPirate is offline
Old 01-26-2014, 10:43 PM   #31
steveb64
Active Member
steveb64's Avatar
Finished installing my Porterbuilt rear suspension kit, and picked a cool grill off a C50 at the junk yard. Still had a T3 sealed beam on one side.
steveb64 is offline
Old 01-27-2014, 10:53 AM   #32
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Nice find!!
If you are not using the "Heat" knob, I'd take it off your hands if the price is right!
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline
Old 01-27-2014, 11:50 AM   #33
racecougar
racecougar's Avatar
Disassembled the frame and loaded it back on the trailer for it's second trip to the quarter car wash.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline
Old 01-27-2014, 12:16 PM   #34
AngryPirate
Originally Posted by chevy_man5 View Post
Nice find!!
I'll have a look when I'm out at the property again where it's kept.
Old 01-27-2014, 06:53 PM   #35
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Thanks!
Jason
Old 01-28-2014, 10:24 AM   #36
kieth
kieth's Avatar
Changed out modified 700r4 transmission pan for a stock one that did not leak, now the garage floor is clean. Also closed off the blazer fuel tank vents so it no longer smells up the garage. Wife is now happy (or is that really possible.)
Started cleanup on LT1 TPII engine, installed kit to relocate A/c compressor, alternator etc so we can transplant engine using stock 350 motor mounts without modifying the frame........will change engine as soon as we figure out wiring adaptation.....Kieth
kieth is offline
Old 01-28-2014, 06:47 PM   #37
TJ's Chevy
TJ's Chevy's Avatar
Thought about mine today.....thinking of paint and two tone options...what I am going paint my frame....weather or not I am going to do a 3/4 ton suspension swap....oh..stuff stuff and more stuff.
Old 01-31-2014, 01:17 PM   #38
Fatherof3
Fatherof3's Avatar
Flipped, shaved, & clearanced my crossmember. Not owning a plasma cutter this was to much work with only a sawzall and cut off wheels. I will buy a aftermarket one if there is a next time.
65 C20 292 4spd 4:56 Eaton HO52
Fatherof3 is offline
Old 01-31-2014, 05:11 PM   #39
64 wedge
It must be nice to find trucks around that have not rotted away back into the ground. Up here in the northeast salt and scrappers have got them all.
64 wedge is offline
Old 01-31-2014, 10:07 PM   #40
BubbaSR49
Put new Rally's on my 66 Fleetside.Name:  My 66.jpg
BubbaSR49 is offline
Old 01-31-2014, 10:09 PM   #41
TJ's Chevy
TJ's Chevy's Avatar
Played around with me '77 today! https://www.youtube.com/watch?v=nKWv_X4VbW4
Old 02-01-2014, 08:44 PM   #42
TJ's Chevy
TJ's Chevy's Avatar
Moved brush around the fields to the burn pile. Thought about doing a burn out vid but got to tired to. lol. Next time we'll see about lighten them tires up!
Old 02-02-2014, 02:54 PM   #43
txinliner
txinliner's Avatar
fixed low idle stumble accelerator pump return spring wasn't seated .. easy peasy
65c10 43,000 original miles ,230 stovebolt,powerglide,3" drop spidles 3" drop springs w/ half coil cut and 5 drop springs in back with 1 1/2 blocks... c notch soon to add hei offy 4 v intake and holley 390
txinliner is offline
Old 02-02-2014, 03:39 PM   #44
Grizz1963
Grizz1963's Avatar
Not so much to, but with....
Well, it is winter, and we have had the wettest January since 1909 when records were begun.
Today Nicola and I decided to take the truck out for a decent run as we both have a bit of cabin fever, and deliver mate Martin the latest copy of Classic American (we subscribe to different mags and swop after reading them)
So we made a few stops at Chatham Dockyard where we were chased away by security........
Then off to the yacht basin to get a few pics.
I have been looking for a decent photo of the truck to enlarge to about 1200mm X 1500mm for my study, to replace the Super Hero wall I have there at the moment.
Not sure if any of the pics I ended up keeping really make the grade. I may have to look for a better setting at some point.
So please give your opinions too.
So there went another weekend.
Frustrating PotatoBucket !!!
Turns pics about.
No idea how to overide it, tried rotating in files.
Last try
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline
Old 02-02-2014, 05:13 PM   #45
TJ's Chevy
TJ's Chevy's Avatar
I like all the pictures except the last one....I can't quite get my neck in a good position.....
Old 02-02-2014, 06:42 PM   #46
rickywideglide
rickywideglide's Avatar
finished painting around grill, buttoned up headlamp upgradeName:  010.jpg
rickywideglide is offline
Old 02-02-2014, 08:19 PM   #47
19GMC66
19GMC66's Avatar
Put in new Ididit tilt and Billet specialties steering wheel !
19GMC66 is offline
Old 02-02-2014, 09:41 PM   #48
jayoldschool
Moderator
grizz, in almost all your shots, you are making the same mistake: there is something in the background "growing" out of your subject matter. Beams, signs, tugboats, barges, you've got it all! Try and frame the shot so the subject matter is the focus, not blending into the background, for example, the picture of the blue glass building with a red truck in front. Make sure that there are no obstructions "growing" out of the subject matter. Hope this makes sense.
jayoldschool is online now
Old 02-03-2014, 12:39 AM   #49
contagious102
Fixed it for ya.!!
Old 02-03-2014, 11:08 AM   #50
ACK
ACK's Avatar
I didn't want to install battery taps, so I put a 150 amp bus bar under the hood and a fuse block under the dash. A set of dash switches goes in next so I can hook up the aftermarket washer bottle with built-in pump and a set of driving lights.
My truck ain't dead, it just smells funny.
ACK is offline
Closed Thread
