Old 02-03-2014, 01:09 PM   #1
Windsma
LS Motor Position
Im working on a 1972 Turbo 5.3 and would like to know what extra room can be had using offset motor mounts. (between pulleys and radiator)
DD has the adjustable ones
Jegs sells 2in back for half the price.
Engine as far back as possible would be ideal.
Big favor but could you guys check on firewall to engine clearances before I buy the wrong thing.
Currently the truck has SBC frame perches, BeCool 3 core and twin electric fans.
Windsma is offline   Reply With Quote
Old 02-03-2014, 02:42 PM   #2
Matt Cramer
Re: LS Motor Position
One missing question: How much sledgehammer or Sawzall work are you willing to do to the firewall?
Overall, an LS motor is about an inch shorter than a regular SBC.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 02-03-2014, 02:46 PM   #3
Windsma
eeehhh... none.. Its pretty.
batt and heater box can go though
Old 02-03-2014, 09:13 PM   #4
crazy longhorn
Fabricate till you "puke"
I would suggest moving the sb engine stands back a set of holes on the frame, (give you 2 1/2" setback). You will need to drill the bottom hole on ea side. a set of carshop inc. 1" setback plates #CSP2370, @ $59.99, should set you as close to the stock firewall as you will want to go? Prothane #7-509 mounts ,will work with that ($86.99 through Jegs). You can also slot the engine stands & the trans crossmember, to give a little adjustment , as needed. On my app, I did include a set of Moroso engine mount shims...about $40, through a local speed shop. Down on the 4 th or 5th page, there are pics of my swap, that will show how close the engine fits in I 6 spot, but 1" forward (where I am trying to set you, by moving the sb stands rearward). Take a look @ the pics, & if you have any questions , on what I have not added/forgotten...fire away Best of fun, Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-03-2014, 09:24 PM   #5
Windsma
thanks for the info, which thread are you referring to?
I'm almost to the point of mockup and build my own.
Trying to keep AC too.
Old 02-03-2014, 09:42 PM   #6
crazy longhorn
69 longhorn,ls swap pics....just about to the bottom of page 4 in this forum. Longhorn
Old 02-04-2014, 11:30 AM   #7
Hart_Rod
Hart_Rod's Avatar
I used Dirty Dingo sliders and CPP perches. I have my engine about as far back as you can put it. I didn't do any hammering or sawsall work.
Hart_Rod is offline   Reply With Quote
Old 02-04-2014, 08:11 PM   #8
Windsma
Gonna try the cheaper way first as suggested by Longhorn.
I bought the metal stock today and it was the same cost as Carshop Inc.
so... ordered those too.
I6 location and 1in back. Hope the AC compressor still fits in the frame.
Old 02-04-2014, 11:40 PM   #9
crazy longhorn
I don't think you will find the ac compressor to fit the frame , with that mount/ bracket set up? I think the mount /spacer will need to be modded on the RH side, for compressor clearance....or an aftermarket bracket set, to mount the compressor in a higher spot. I am sure that some of the others will "chime in" on that one, as I do not run AC ? Longhorn
Old 02-04-2014, 11:58 PM   #10
68c10airstream
68c10airstream's Avatar
HI Windsma, do as i did, used the organ donor truck mounts and make your own frame brackets. I used trailblazer compressor down low on passenger side using trailblazer bracket to block. Only issue is the lower 2 bolts go through compressor and bracket into upper edge on oil pan. trailblazer pan is odd, as front axle goes through it so modding the ac bracket will work. Truck ac has suction/discharge left to right and some guys notch the frame for ac lines. I used the trailblazer compressor because the suction/discharge are in-line front to back and the blazer compressor is a little smaller so you don't need to notch the frame. If i was to do it all over the trailblazer has everything you need. The mounts look like hockey pucks and sit low and back so not in the way of anything, headers,etc,etc. I will be making up a CCOT (cycling clutch orifice tube) system like the trailblazer uses. I,m running clutch fan so electrical hook-up will be easier. Probably use 73-87 c10 evap core in my 68 ac box, r134 accumulator, trailblazer lines and trailblazer condenser. Good luck, Brian F.
68c10airstream is offline   Reply With Quote
Old 02-05-2014, 10:11 AM   #11
Windsma
Thanks Guys,
I ordered a low profile ac manifold. $26 with the correct washer kit 440-850
http://apairinc.com/detail.asp?Part=451-11521
Im sure theres lots of combinations, If this doesnt work i'll try the 01 perches.
Old 02-05-2014, 10:34 AM   #12
wgeyer88
Don't mean to hijack the thread but you wouldn't happen to have some pictures of this setup? I think it might be beneficial for everybody to see.
I was in the exact same boat as far as engine position. I know I want to go FI down the road so I mounted the engine quite far back using the DD mounts on 73-87 stands. There's no way the stock truck compressor fits down low, it hits the DD mounts and I think the frame rails.
Will
1970 CST10 SWB LQ4/4L80E
2004 Silverado (sold)
2007.5 Dodge Ram 2500
wgeyer88 is offline   Reply With Quote
Old 02-05-2014, 10:41 AM   #13
Windsma
Well i think my Delphi ac compressor is different than most.
I hope it will make it easier.. Im sure, with my luck, it wont.
Old 02-07-2014, 06:08 PM   #14
Houston Ben
Houston Ben's Avatar
I'm with this guy!! Show us how this is done 68C10airstream!!
Houston Ben is offline   Reply With Quote
Old 02-07-2014, 06:48 PM   #15
68c10airstream
Hi, I will try and post my first pics tomorrow. I will need my wife's help on this. Working midnights (12 hour shifts) this weekend, so be patient.
Old 02-07-2014, 08:08 PM   #16
Windsma
I know this is gonna be a bummer but..
Giving up on turbo for now.
I would rather have AC
1in back plates showed up today.
I'll post pics this weekend
Old 02-07-2014, 08:43 PM   #17
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
.....I only know of two Burlingtons; the one in WI, and the one in VT...neither need A/C....
Priorities are in the wrong order.
VOTEBAN
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-07-2014, 08:46 PM   #18
Windsma
I agree... Even the GF says Turbocharge it..
BUT..
Burlington NC. Last summer had several 100+ days
And GAA Classic Auction is March 7th.. (Old farts love AC not hair dryers)
I can't get everything done by then.
Doesnt sell for the number in my head... Ill come back to the turbo thing.
Old 02-08-2014, 04:12 AM   #19
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
So this is all just to flip this truck?
Old 02-08-2014, 12:46 PM   #20
littlevictories
sell that pretty thing and get a 60-66
that's what the kool kidz drive
littlevictories is offline   Reply With Quote
Old 02-08-2014, 03:28 PM   #21
68c10airstream
[IMG][/IMG] This is my first pic ever posted
Old 02-08-2014, 03:32 PM   #22
68c10airstream
Old 02-08-2014, 03:38 PM   #23
68c10airstream
[IMG][/IMG] I modified the bracket. The lower left hand side and center bolt were added by me. I will be using the lowest open bolt holes for through bolts and nuts on the back side instead of the lower bolts originally threading into the side of the trailblazer oil pan. i just installed 98-02 camaro/firebird oil pan and didn't want to weld onto the side of the pan so i modified the bracket instead
Old 02-11-2014, 11:56 AM   #24
Windsma
Time to buy a house and start a family. I have more toys.
Old 02-11-2014, 03:10 PM   #25
Houston Ben
That's awesome 69C10, I think I'm gunna do this!
