Old 02-10-2014, 11:14 PM   #51
Classic-Steele
Classic-Steele's Avatar
Re: '87 tank/fuel pump supplier
Supply is a 16mmx1.5 and the return is a 14x1.5. Earls part #s are in the pics...
Classic-Steele is offline   Reply With Quote
Old 02-11-2014, 02:11 AM   #52
jamesjones
Freakin Awesome!
jamesjones's Avatar
Cool, thanks again man, you've been a huge help.
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee
jamesjones is offline   Reply With Quote
Old 10-21-2015, 08:05 PM   #53
dohc91gli
old thread I know. but this is the setup I want to run, and I had a few questions. I see the 87 sender has 4 ports. one is pressure, one is return from the corvette regulator/filter. what are the other two for? I ask because instead of running a second complete tank/sender/pump, My thought was to simply (or not so simply) run a small transfer pump from the old talk to the new tank using one of those ports on the new sender. does anyone see a problem with doing this? I have twin tanks now, and originally I wanted to run two complete setups with new tanks, senders, and walbro 255's, but I was thinking this might work too, and cheaper.
second question, how does the walbro 255 hook up in the sender, anyone have a photo?
again, sorry to bump a year old thread. but since this had the info I needed, it seemed fitting.
dohc91gli is offline   Reply With Quote
Old 10-22-2015, 05:22 PM   #54
aggie91
I'm just glad to be here!
aggie91's Avatar
Post #5 in this thread has a photo of the pump installed in the sending unit...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 11-22-2018, 09:26 PM   #55
Coursey
Coursey's Avatar
bump good info
Coursey is offline   Reply With Quote
