Old 02-04-2014, 10:56 AM   #1
Dobster
67 6 lug to 5 lug conversion.
Is there a thread or link anyone can point me too?
Is there a direct axle swap off another chevy truck to convert the 67 6 lug to a 5 lug? I just got my posi unit installed, I assumed I could use the 70-72 5 lug axles but They are longer. I guess I should just pick up a complete axle from a 70-72 if I can find one. I could pick one up and transfer the posi. I already have a rear disk brake conversion set-up.
Dobster is offline   Reply With Quote
Old 02-04-2014, 11:00 AM   #2
Sean1985
Sean1985's Avatar
Re: 67 6 lug to 5 lug conversion.
Early classics has a 5 lug axle swap for around 300 bucks. I'm assuming you have a 12 bolt 30 spline.
Sean1985 is offline   Reply With Quote
Old 02-04-2014, 11:05 AM   #3
SCOTI
SCOTI's Avatar
x2.... Especially if you already rebuilt the differential.
There aren't any direct swap axles. Go with aftermarket units which have zero wear & are stronger than OE.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-08-2014, 10:23 AM   #4
Dobster
just spent 500 on the diff wasnt wanting to spend another 300 on axles.
Thanks for the info!
Old 02-08-2014, 11:42 AM   #5
Clyde65
Clyde65's Avatar
If you just installed a posi, did you upgrade the bearings? seals?
I had my 71/72 rear rebuilt, I gutted it and cleaned it all up and still cost me $1000, that included the master rebuild kit and the ring/pinion to 3.73. no posi.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-09-2014, 01:27 AM   #6
Dobster
I only changed the posi. The 373 ring and pinion was already installed about two years ago by the previous owner. I did use a gauge and tested the play. Right at .09. I used the original spacers. And checked the ware pattern. It was dead on with the previous diff. So I only paid for the Eaton series 4. I did all this thinking I could just swap the axels from a 71 or 72. So now I am going to buy a few axles in the near future. It just slows down my progress.
That's a sweet 65 in your sig. Clyde how's the gas milage?
Old 02-09-2014, 02:46 AM   #7
'68 Newtricks
'68 Newtricks's Avatar
Not to hyjack, but I'm in the same boat and curious about my options.
I have a 6 lug axle too, but it's garbage. Everything needs replacing. I can grab a local 12b/5 lug/ with 3.73s for around $180. Dunno the shape though. Was looking at putting a 9" together, but it's overkill and expensive. What do you guys think?
'68 Newtricks is offline   Reply With Quote
Old 02-09-2014, 02:57 AM   #8
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
I wont say it is the best option ...... but it is a reasonable option. Having the axles and drums redrilled to 5 on 5 and the centers turned down to fit the 5-lug wheel cost me $85.00 locally , just need to make sure the axles arent wore out first . Now to me the best option for a fleetside truck is to go ahead and put the wider 71-72 rear axle in if possible. Opens up alot more options for wheels with the correct backspacing .
ksbrktracer is offline   Reply With Quote
Old 02-09-2014, 08:31 AM   #9
72freak
Rottenwood Garage Member
72freak's Avatar
Re-drill them and press in 5 studs and get some 71/72 drums. Very common practice. Then get one of the many kits for the front offered for a disc conversion or a simple 5 lug conversion (CPP) being one of them if you want to go that route fro the front. We just did it on a 69.
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 02-09-2014, 09:26 AM   #10
Dobster
If I could go back I would grab the 12 bolt for $180 and get it installed with 373's already installed the ring and pinion can stay saving a few hundred bucks.
Old 02-09-2014, 11:49 AM   #11
lolife99
67-72 parts collector,…
lolife99's Avatar
Just remember the 70-72 rearends are 3/4" PER SIDE wider than the 67-69 rearends.
I would still buy new axles from Moser Engineering to replace those old axles.
$260 from Moser Engineering.
http://www.moserengineering.com/axle...spline-31.html
Summit Racing sells them.
http://www.summitracing.com/parts/msr-a3065gmt5
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 02-11-2014, 04:59 PM   #12
'68 Newtricks
Woot! (Cause this thread is dead anyway)
Picked up the axle for a cool $100 from apparently a fellow member Thanks dude! Helps a lot
Old 02-11-2014, 05:37 PM   #13
Dobster
So you scored Axel's from a member on this board on a thread I started and you are just rubbing it in my face?
Old 02-11-2014, 06:06 PM   #14
'68 Newtricks
Haha Nope. Was thanking the guy I bought it from. Was from CList, not here. But it seems all my CList dealings so far (with this truck) have been with members I don't know! Kinda cool guys, the popularity and all. I don't run into people from my Blazer forum at all.
I'll thank all the replies myself, cause it helped me out of the same boat
Old 02-16-2014, 09:02 PM   #15
Dobster
Yes I do have the 30 spline axles. thanks for the input.
Old 02-16-2014, 09:03 PM   #16
Dobster
Going to order the axles soon. thanks for your input.
Old 02-16-2014, 09:07 PM   #17
Dobster
Thanks for the input. Might be going this route if I can find a deal on a axle.
Old 02-16-2014, 09:13 PM   #18
Dobster
Some people say to re-drill the studs is unsafe? Ive got time. I think I will ether buck-up and buy the axles or if I can find a good deal on a axle out of a 71-72 just re-build it with my diff. from my 67.
Thanks for the input. Good to know I have a few options here.
Old 02-16-2014, 09:18 PM   #19
Dobster
Thumbs up Re: 67 6 lug to 5 lug conversion.
Summit sells the same Moser axles a buck cheaper and free shipping!!!
5x5 bolt pattern, axles
