Old 02-10-2014, 06:05 PM   #1
eighteenninetytwo
How much to have 700 R4 installed
I'm going to have to change out the tranny - it's pi$$ing fluid all over and rattles and grinds like nobody's business - to have the leaks stopped is several hours work and several hours work may as well be done installing a new one. This is NOT something that I could tackle myself at all. Question is how much should i be paying for it on top of the cost of the transmission itself? How long does it take? Another question is, currently vehicle has 4" lift. When I lower it back to stock, will there need to be further work on the transmission as the distance to the Rear axle will shorten very slightly?
eighteenninetytwo is offline   Reply With Quote
Old 02-11-2014, 08:44 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: How much to have 700 R4 installed
I'm guessing at least $300 to $400 over the price of the new tranny.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 02-12-2014, 12:54 AM   #3
eighteenninetytwo
Thats indicating it s a 5 -7 hour job maybe? Can I ask what is the ballpark hourly rate is where you are? Here it is $85 or $120 depending upon where you go so this would be about $500 to $700 extra here
Old 02-12-2014, 07:19 AM   #4
68Timber
68Timber's Avatar
I'm sure prices will run a little higher in CA over AL, but still I'm probably low. I found out the other day the tranny guy I know gets $700 to rebuild a TH350 now - blew my mind... I think rates are around $70/hr here.
John
74 Honda Z50 build
Old 02-12-2014, 07:29 AM   #5
LEEVON
LEEVON's Avatar
I think if you call around the difference between a carry-in transmission and the full remove/replace isn't that big. Here in Missouri you can get a 2wd 700r4 rebuilt and R&R'd for $700-800. I would expect to pay more like $1200 for a 4wd at a larger shop.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
