Old 02-12-2014, 07:32 PM   #1
long66
I want to lift my 66 2wd. Any suggestions?
I am looking for any info. I would rather lift my 66 than lower it. It is a 66 lwb fleet .
long66 is offline   Reply With Quote
Old 02-12-2014, 07:41 PM   #2
Fatherof3
Fatherof3's Avatar
Re: I want to lift my 66 2wd. Any suggestions?
For street or off road use? It will make a difference how you need it to react at the new height - articulation vs stability etc.
65 C20 292 4spd 4:56 Eaton HO52
Fatherof3 is offline   Reply With Quote
Old 02-12-2014, 08:49 PM   #3
TJ's Chevy
TJ's Chevy's Avatar
They make body lifts so you can lift the body off the frame and put taller tires on...or you could put taller coils on as well...and if your truck came with leaf springs then taller leaf would work. If that is a 3/4 ton...then 31 inch 16's would lift it a bit as well as change the gear ratio.
Old 02-12-2014, 08:57 PM   #4
Captainfab
60-66 Nut
Here you go.......
http://www.67-72chevytrucks.com/vboa...os+long+travel
Old 02-12-2014, 10:43 PM   #5
long66
I am looking for street use. It's a half ton
Old 02-13-2014, 12:42 AM   #6
Softpatch
Softpatch's Avatar
Softpatch is offline   Reply With Quote
Old 02-13-2014, 02:06 AM   #7
argonaut
argonaut's Avatar
Why didn't i think of that!?
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 02-13-2014, 09:53 AM   #8
72freak
Rottenwood Garage Member
72freak's Avatar
It depends on the lift you are looking for. CPP has "lift springs" for the front. Not sure about the rear. I used 2" lift springs on the front of my 68 dually to level it out. Blocks, coil spring spacers. All options. Pop in the new springs , have it realigned and you are done.
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 02-13-2014, 12:00 PM   #9
argonaut
argonaut's Avatar
I wish there was enough demand for a knuckle with an offset (lower) spindle shift and caliper mount so that 2wds could lift a couple inches without suffering poor suspension geometry.
I suppose they could be fabricated.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 02-13-2014, 12:09 PM   #10
long66
Originally Posted by Softpatch View Post
All I can Say is "WOW"
Old 02-13-2014, 12:10 PM   #11
LVPhotos
LVPhotos's Avatar
Fab Tech use to have them. I had a '76 2wd I was going to lift but sold it for 4wd and the Guy dropped it to ground. I have not seen that kit in a while but couldn't you run the later ones like 88-99 with balljoints?
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 02-13-2014, 12:14 PM   #12
long66
I will have to see what I can rig up ... This is my first Old Truck that I get to fix up so I am running into this a little blind. Hence the reason I joined. There is a ton of knowledge and info here.
Old 02-13-2014, 12:19 PM   #13
argonaut
argonaut's Avatar
I seem to remember you can use the 88-99 lifted knuckle if you use a late 60s one ton lower control arm and ball joint, or something like that.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 02-13-2014, 03:24 PM   #14
Rich 5150 69
Rich 5150 69's Avatar
Not sure if they make them for GM but there are producing ball joint spacers for toyotas, used to be the hot deal in the sixties to get the front end up on coil sprung cars....
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 02-13-2014, 05:06 PM   #15
argonaut
argonaut's Avatar
The coil supports the lower control arm, so while the upper spacer will help upper control arm geometry it won't produce any lift.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 02-13-2014, 06:22 PM   #16
argonaut
argonaut's Avatar
Maybe there is also a way to drop the whole front cross member relative to the frame?
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 02-14-2014, 01:30 AM   #17
Captainfab
60-66 Nut
Apparently nobody has looked at the link I posted
Old 02-14-2014, 03:37 AM   #18
argonaut
argonaut's Avatar
From Dino's thread:
the spindles are for an 88-98 chevy c1500. You use the 88-98 upper ball joints(direct bolt in to 70 upper a-arm), 88-98 lower balljoints(need to find 67-68 3/4 ton lower arm and neww balljoint will press in) 88-98 inner and outer tie rods(the 70 center link needs to be reemed out to fit the new tie rods). For the brakes I used 88-98 6-lug rotors to match the rear of my 70, and 88-98 calipers. I havn't delt with the brake lines yet, shouldn't be that difficult though. My tie rod angle is close to stock so hopefully I wont have any bumpsteer issues. With the fiberglass fenders I am using it cleers 35's with no clearance issues. I'll try to post pics(have never done it before maybe someone can walk me through it as I am not very computer savy).
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 02-14-2014, 06:46 PM   #19
aggie91
I'm just glad to be here!
aggie91's Avatar
Dino's truck used Fabtech spindle and lift arms, neither of which are made anymore.
Rough Country makes a lift spindle for the 88-98 body style @wd trucks.
http://www.roughcountry.com/gm-lifte...dles-7500.html
Since the 63-66 crossmemeber is the same as the 73-87, take a look at this thread:
Post #18 has some great pictures of the front suspension and Post #43 has a spreadsheet of all the parts he used:
http://67-72chevytrucks.com/vboard/s...d.php?t=442205
Dino's truck had the simplest way to lift the rear of a coil spring truck....
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-15-2014, 01:33 AM   #20
Captainfab
60-66 Nut
Thanks for posting that link Karl, I had not seen that thread. I agree that using the RC parts would be easier than trying to find the Fabtech parts.
