Old 02-21-2014, 11:35 PM   #51
81chevys
Re: TEXAS 81 swb build 5.3 4l80
Running into some probs though.... I got no power under 3000rpm. It barely moves itself until then but over 3k it blows the tires away. I did restall the converter to 2800-3200. It seams the engine is the one with the problem though. Also posted on ls1tech. I tried swapping o2 sensor plugs from side to side. No luck. Anybody got any ideas?
81chevys is offline   Reply With Quote
Old 02-24-2014, 11:18 AM   #52
mattcrp1
mattcrp1's Avatar
Did you find that with the Dirty Dingo mounts and the factory a/c position that the drag link came way to close to the oil pan and harness? I ended up removing the a/c and moving the whole eng/trans back to gain clearance on my LS install. Did you have to do the same?
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 02-25-2014, 03:42 AM   #53
81chevys
I pulled the dirty dingos and swapped for moroso because of the schnoenfeld headers. Too close to drglink as you stated. Moroso worked better for me
Old 02-25-2014, 10:23 AM   #54
mattcrp1
mattcrp1's Avatar
Thanks, did you relocate/remove the a/c and did you have to relocate the starter wiring? Got any pics of the Moroso set up? Good looking build so far.
IG mattcrp1
Old 02-25-2014, 11:46 AM   #55
81chevys
Ill try for in the morning to load some.
