Old 02-19-2014, 12:16 AM   #1326
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: 68 S/C update.....
Probably the best looking '68 on the planet!!
ChuckDriver is offline   Reply With Quote
Old 02-25-2014, 12:37 AM   #1327
boynton
boynton's Avatar
Originally Posted by Hart_Rod View Post
Thanks guys! I'm fortunate to have a good friend like Ernie (BuckSS) motivating me and helping out. I borrowed a set of blocks from Ernie to get it up in the air so it's easier to work on. So I've been bolting stuff on and checking clearances. I'm going to have to rework my CPP trannly mount due to the design of the 6L80 tail shaft mounting pad, but I think I've got it figured out (just need to do some cutting and welding). My original shifter lever/linkage almost works as is. I just need to do some tweaking after motor and tranny are bolted down for good. Headers couldn't fit any more perfect, a big BZ to Doug Thorley!!!! The factory 6L80 pan hangs down pretty low, so I found a pan off of a Caddy STsV that is a lot thinner and will bring it up about 1". The factory tranny lines are going to work like a champ too, . Also, the Cadillac CTsV oil pan did me right again, I love how it fits the crossmember and it works great with either CPP motor mounts or ECE motor mounts. Enough rambling, here are some pictures.
PS I talked to John at Speartech and will be ordering my harness after the holiday weekend. I've "bugged" him a bunch, but he's always taken the time to answer my questions.
Who would have thought?
Notes are good,
Just let me know, .
I'm not sure on the connector. How many wires go into yours? I bet you could call PSI and ask him what you would need to do to convert it. I'm going to have John at Speartech build it into my harness.
Thanks Rus!
Here's a few pictures of the mock up mount that I built out of aluminum. I just wanted to make sure I liked the pedal placement. Now, I'll build another out of 3/16th steel.
1 Do you have any "final" pictures of your shift linkage and what did you have to modify
2 Do you have any pictures of the back side of the pedal mod/were there any issues on the other side of the firewall or did you just use the original pedal bolts to hold it in (i observed a ~1/2" bolt at the top)
3 any final horsepower numbers
I am starting a 6.0 ly6/6l90 from a 2009 3/4 ton and these are a few loose ends I am trying to iron out. Your knowledge would be much appreciated!
This is one sweet truck. Mine will not be this nice but I am shooting for something in the same ballpark.
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 02-26-2014, 07:04 PM   #1328
superflysteiny
superflysteiny's Avatar
Truck is turning out amazing
superflysteiny is offline   Reply With Quote
Old 02-26-2014, 07:50 PM   #1329
Hart_Rod
Hart_Rod's Avatar
Originally Posted by Bucks68 View Post
Now that you can mess with it yourself it will never REALLY be done!
True...
I'm glad you like it!
1. I used a LOKAR shifter (part number ACA-1801). I used this one because it is bent and offset by .5". I had to send the aluminum piece back to LOKAR to get it splined to work with the 6L80 shaft. You could probably use the ACA-1800 and just add a .5" spacer.
2. I didn't have to modify the pedal any. Its bolted to a flat bracket that bolts to the firewall using the 3 original nutserts that the original pedal bolted to.
3. It should be around 600+ RWHP
Thanks!
Hart_Rod is offline   Reply With Quote
Old 02-28-2014, 09:16 PM   #1330
NewType72
NewType72's Avatar
very very cool brother rock on!
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 03-02-2014, 10:15 AM   #1331
lchall
Would you mind sharing some details on your oil and transmission cooler setups? I would appreciate the info.
From some of the pics it looks like you are using a Derale heat sink cooler mounted under the core support for oil. Didn't see the transmission cooler setup.
Thanks - Chad
1967 Chevy SWB
1972 Chevy SWB
1972 Chevy SWB K20 4x4
1991 Ford F-150
2013 Dodge Ram 1500 4x4
lchall is offline   Reply With Quote
Old 03-02-2014, 05:39 PM   #1332
Hart_Rod
Hart_Rod's Avatar
Thanks, glad you like it!
Thanks - Chad
Chad - I don't have an oil cooler, just 2 transmission coolers. The engine originally came with an oil cooler, but I couldn't make it work with my motor mount setup. What I did on the transmission was run the hot side out of the tranny to the transmission cooler in the radiator, and then I ran the cold side out of the radiator to a dual pass heat sink cooler under the core support and then bank to the transmission. I'm not sure how much it helps (can't hurt right?), but I do know it gives me approximately another quart of capacity for transmission fluid.
Old 03-02-2014, 09:18 PM   #1333
lchall
I'm pretty much thinking the same thing for the transmission cooler. Only thing different I was thinking about was adding a bypass thermostat for the extra cooler. That way the cooler in the radiator can help the fluid warm up faster and still try to maintain minimum temps. I don't know how much the added cooler, cools. Not sure if it'd make much of a difference, but its pretty cheap to add.
http://derale.com/products/coolers/a...unt-kit-detail
For the oil cooler I'm guessing you are talking about the stock cooler that came on the Camaro oil pan? I'm with you, I don't see a way to make it work with the slider mounts. I was thinking about trying something different with that, using a remote mounted cooler and an adapter. Not sure if you've looked at the ones from Improved Racing, but they have a thermostat built into them and AN fittings so you can mount a cooler wherever. They do have a version without a thermostat, too. Seems a little expensive and I'm not sure if its necessary to have an oil cooler anyway.
http://www.improvedracing.com/cooler...28e4c74df943c5
Thoughts?
1967 Chevy SWB
1972 Chevy SWB
1991 Ford F-150
Old 03-02-2014, 09:30 PM   #1334
Hart_Rod
Hart_Rod's Avatar
If you're scared, just say you're scared......
Old 03-06-2014, 01:33 PM   #1335
Hart_Rod
Hart_Rod's Avatar
Getting ready to drop some coin on a new stall converter. Leaning towards a multi-disc 3000 stall.....
Old 03-16-2014, 12:12 AM   #1336
Hatzman
Hatzman's Avatar
Hart Rod.... It took me THREE (3) days to read your 54 page thread... All I can say is... Wow... Your project is insane and you have given me several ideas for my new LQ9 engine swap. If you don't mind, I will begin picking your brain tomorrow.
Steve
___________________________________
http://67-72chevytrucks.com/vboard/s...d.php?t=618848
Hatzman is offline   Reply With Quote
Old 03-20-2014, 04:47 PM   #1337
Hart_Rod
Hart_Rod's Avatar
Thanks!
The new Circle D converter showed up today!!!
Old 03-22-2014, 11:54 PM   #1338
likaroc13
Rollin' Old Skool
I've got a plan.......
You wouldn't want this ole piece of junk, .
Here's a couple pictures with the center caps on at our local Saturday night car show. PCMCobra allowed me to park next to him so I wouldn't feel so alone, . There was a nice LS1 67 step there also.
Was digging for pics of your Vintec wheels when I came across Post #377... looks like my old friend Gary is in the background of the first pic (top left)...last time I spoke to him was probably Spring 2010...sadly we've lost contact...if you run into him sometime, please tell him Phillip & Haley (my wife) said hello
BTW, the truck looks awesome! It has changed a good bit since I last saw it. Keep up the nice work.
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 03-24-2014, 11:14 AM   #1339
Hart_Rod
Hart_Rod's Avatar
Thanks! What does he drive?
Old 03-24-2014, 12:18 PM   #1340
likaroc13
Rollin' Old Skool
I'm not sure what he has now. When we moved, he had a newer body style S-10 reg. cab that was pearl white & mildly customized. At the time, he was also working on a 73-87 Chevy pickup. I wanna say it was brown. Last time I spoke with him, he mentioned he gave the S-10 to his son.
Here's a better pic of him when we were at Cruisin' the Coast '09:
http://www.flickr.com/photos/98543199@N05/12213724574/
Phillip
My Build threads:
Pics:
Previous Rides:
Old 03-24-2014, 05:23 PM   #1341
beckmand78
beckmand78's Avatar
subscribed.
69 c10, mild 350, TH400, LWB......Starting build 3/14
beckmand78 is offline   Reply With Quote
Old 03-24-2014, 09:03 PM   #1342
SeTx67
SeTx67's Avatar
What stall did you go with?
SeTx67 is offline   Reply With Quote
Old 03-24-2014, 09:14 PM   #1343
Hart_Rod
Hart_Rod's Avatar
265mm Pro III 6L80E Torque Converter, 2800 Multi-disc:
http://www.circledspecialties.com/p-...converter.aspx
Old 03-24-2014, 09:28 PM   #1344
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Put that thing in yet??
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 03-24-2014, 10:06 PM   #1345
Hart_Rod
Hart_Rod's Avatar
I'm waiting on my good friend from Niceville to come over......
Old 03-24-2014, 10:25 PM   #1346
C10_ustacould
I'm trying to go the way of the blister... show up AFTER the work is done!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 03-25-2014, 09:26 AM   #1347
SeTx67
SeTx67's Avatar
2800 is a good choice for a Maggie
Old 03-26-2014, 08:42 AM   #1348
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
Just curious... why did you decide on this brand over others? Previous experience?
chevyguy_72 is offline   Reply With Quote
Old 03-26-2014, 10:00 AM   #1349
Hart_Rod
Hart_Rod's Avatar
Several friends recommended it.
Old 03-26-2014, 10:13 AM   #1350
C10_ustacould
Yep, Circle D is the best choice for LSx converters. Great prices, great products, and great customer service!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
