03-28-2014, 08:13 PM | #1 |
Re: My '67 Fleetside C10 renew
I noticed in the info on the headers it stated:
1967-91 Vehicles: Part# 69090 & 69230 may require removal of Rubber Snubber mounted on right side frame rail w/ 3bolt bracket, to complete installation. ........... I believe this would tilt the motor down enough for clearance. Link to the page I read here ~~~~~>http://www.jegs.com/i/Hedman/500/69010/10002/-1 although yours are 69010, correct. I'd try every which way before cutting the header cause that'll void the lifetime warranty. Rootin for ya. You'll get it. Its probably not an option on this build but you know I'd have that floor hacked up by now. Mmmmmmmmm hackin' |
04-01-2014, 08:58 PM | #2 | |
For my stands I simply match drilled a plate to the clam shell mount, bolted them together and welded the nuts on the backside. I used good OEM flanged ones and welded them good. Put those back on the motor, jockeyed it around till I was happy, then cut the right shape "wedges" to get them onto the front member. It's all 3/16" material and once I'm sure it's all where I want it I'll weld it home. I had to clearance the driver's frame rail a little and it looks like hell in the pics. I was just smoking little bits off until it fit and I'll go back and clean that up straight like with radiuses. That's as far as I got when the Boy blew the S10 ("Punching-Bag" Thanks Chip!) apart in there for his new heads. Got that finished up around 1 friggen thirty this morning! I'll throw a few pics up on Stupid Move, maybe a burnout vid... He's got some cleaning to do then I'll build me a cross member!
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 |
Tags |
295/50-15, 327, butternut yellow, dog dish, muncie m20 |
