03-08-2014, 06:25 AM | #226 |
Re: Project Family Hauler
Very Nice!
03-08-2014, 11:04 PM | #227 |
Thanks. Soon I will be back to the suburban. Unless my dad is ready for floors in his Corvair first.
Travis 2005 K2500 Duramax (hauls the junk home) 1967 Chev C10 (hauls a$$) 1970 Suburban (Yukon XL 4 door) 1968 GMC 3/4 ton (sheetmetal only, chassis gone) 2005 Malibu (wife's car, still a Chevy) Project Family Hauler New Home for Chevys (Moved in and working) |
03-31-2014, 12:49 AM | #228 |
Little side project is done. I will be back to the suburban soon.
03-31-2014, 12:51 AM | #229 |
Fuel filler is done too.
03-31-2014, 10:22 AM | #230 |
03-31-2014, 03:18 PM | #231 |
6>8 Plugless........
Holly cow, that looks amazing! Great work!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
04-04-2014, 11:55 AM | #232 | |
05-10-2014, 11:03 AM | #233 |
Hello guys I want to say hi I live out in yelm if you guys would like to get toghter say hi I will be in Puyallup today helping my daughter move in my 70 suburban panel
06-07-2014, 02:27 AM | #234 |
If you want to find local get togethers check out northwest c10s on Facebook. We have local meets to check out every ones trucks. Not a car club, just a bunch of Chevy truck owners.
09-30-2014, 01:14 AM | #235 |
Any updates?.?..
HSRACER Slammed 53 5 window Blown/Bagged 54 Pickup Patinaed 67 LS stepside Supercharged 67 Nova Bagged 69 Suburban Turbo'ed 5.3 LS |
10-27-2014, 02:16 AM | #236 |
Just finishing a small addition to my garage so my finished truck will be better protected from the dirt. Then I can work on it again.
10-28-2014, 03:59 PM | #237 |
nice work, subscribed!
1968 Chevy C-10 Suburban - 350/350 1969 Chevy C-10 Panel Delivery - 454/400 1972 GMC K1500 Jimmy - 350/350/np205 1978 Chevy Corvette Silver 25th Anniversary reddit.com/r/chevyc10 <-Join it! |
02-01-2015, 10:18 PM | #238 |
Bump
02-01-2015, 11:26 PM | #239 |
I saw him breathing on Facebook the other day.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
02-08-2015, 07:22 PM | #240 |
I have been working on it slowly. Mostly rust repair to the passenger side. I also found out why the back door didn't fit right. The body bushing just in front of the rear tire was missing, causing the body to sag 3/4". Because of all my rust it really twisted the body.
Here is where I left off. With the body mount corrected the doors open and close better. The floor is done behind the B pillar. I tack welded the front floor patch. Then I ground down all the welds and painted the bare metal. I rebuilt the bottom of the B pillar and removed the suburban part of the rocker panel. Then I grafted it onto the truck rocker panel. Next I will finish the bottom of the B pillar and be playing with the rocker panels. Also need to make the back door latch.
02-08-2015, 10:02 PM | #241 |
Good thing you caught that body mount befòre ya got too far along.
01-02-2016, 09:53 PM | #242 |
Time flies with out updates. Got burned out on bodywork, then busy for the summer. Bought a donor vehicle from an auction to use. Not sure if it will yet.
Stripped and sold all the parts I didn't need then rolled the frame into the garage. The wheelbase was 135" and I needed 127" so I took 8" out of the middle. Then I rolled the old frame out and the new frame under only to find the engine is set back farther in vans and it hit the firewall. So I pulled the engine out so I could position the frame correctly. Then cut off the motor mount stands and moved them forward 2 1/2" so the engine would clear the firewall. The drivers side had to be notched around the front differential mount. After all that work I don't like how the frame hangs way below the body. Instead of being inside the body supports it is under them. Add to that the frame is 1 1/2" taller and it is very visible. Any ideas to make it fit better would be welcome. Or I am putting the original frame back under.
01-03-2016, 02:25 PM | #243 |
Looks like you've really put in a lot of well thought out work. How many times have you pulled the engine / put it back in? Looking good so far
01-03-2016, 09:57 PM | #244 |
The engine has only been in and out 3 times since the frame went under.
01-03-2016, 11:41 PM | #245 |
Junk Yartist
wait, what! how did I not get update notifications on this!
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
01-04-2016, 09:30 PM | #246 |
Nice work! I have no real helpful ideas on how to hide the frame from showing. Step tubes are my only idea. That might hide it some what.
01-05-2016, 12:07 AM | #247 |
Channel the body over the frame?
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
01-05-2016, 01:34 AM | #248 |
Junk Yartist
I gotta say, from the pictures, the frame doesn't stand out that much. being that it's fully boxed, I like it. being a van frame, it does seem more of a challenge. for the crew we just said screw it, cut the floor and set the cab where we wanted it, then built a whole sub framed floor to fit the newer frame. for my burb, I plan on keeping as much of the donor floor as possible. being that you're burnt out on body work, I can understand not wanting to dive into any more mods. I imagine the van floor sat way too high to have a flat deck and clear the power train, so my suggestion would be just snip bits out of the way of the body until it sits where you want, then built a subframe for the floor where needed. this may give you better mounting points later as well. since its 4x4, how much of the frame do you really need to hide?
01-08-2016, 03:20 AM | #249 | |
That's what I was thinking.
By the way it's not a 4x4. It's AWD. They sit lower and it sounds sportier.
11-13-2016, 11:16 AM | #250 |
What's the latest on this? I don't want to be the only one using an AWD van for a frame swap, that's a bad sign! Mine is almost finished so if you're still pressing forward I could offer up some advice on lowering/steering/brakes, the things that took me the longest to figure out. Best wishes, Ben.
