Old 03-31-2014, 08:08 PM   #1
jsett83
which mainfolds?
I am swapping a 5.3/4l60E into a 1987 Chevy 4x4. I used the dirty dingo adjustable mounts and was wondering what manifolds you guys would recommend? I have the truck manifolds but do not want to notch the frame? I have read about the ls3 and ls1 manifolds but have no experience with either...do some have the front O2 bungs in them? Any info is greatly appreciated...
jsett83 is offline   Reply With Quote
Old 03-31-2014, 08:22 PM   #2
mattcrp1
mattcrp1's Avatar
Re: which mainfolds?
I have trailblazer ss manifolds on my 76 2wd. Same frame I think.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 03-31-2014, 08:28 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Trailblazer SS (ls2) manifolds fit most applications, as do some of the Doug Thorley swap headers (I think they have one for 4x4 but check their website). LS1 tubular manifolds from like the 98 fbodies fit some applications, but the truth is that the exact fitment depends on more than one factor.
Your year/frame affect it, as does which style motor mounts and perches you use, and/or if you set the engine back or forward. Not to mention the clearance to the ears on the bellhousing.
The above is a start, but since I see your newer you might find a huge wealth of resources have already been posted/discussed with pictures and all that good stuff. If you take a look at the Builds section at the top, and the FAQ, there are some nice parts lists/costs/pictures etc throughout. It definately takes a while to look through all the builds but some of the best info and pics are buried in them. If you have a hard time finding what ur looking for, or are impatient like me, try using our search functions. The "search this thread" lets you look in just the LSx section, and should get you to what you want once you find the right terms.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-31-2014, 09:23 PM   #4
ivorton74
ivorton74's Avatar
Im using f-body manifolds on my 74 2wd...from a 98 camaro
1983 C10 Silverado 5.3 swap
1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122
2001 BMW 530i 5 speed
2019 Nissan Titan SV Midnight
1979 Datsun 210 4 door
1980 Datsun 120y(back home in Trinidad)
ivorton74 is offline   Reply With Quote
Old 03-31-2014, 09:36 PM   #5
littlevictories
im using tbss pacesetter headers, and i dont think they'd clear the 4wd transfer case on the passenger side. why not notch the frame though? seriously, it takes like 10 minutes.
littlevictories is offline   Reply With Quote
Old 03-31-2014, 10:23 PM   #6
Blackpony
Blackpony's Avatar
2010 camaro manifolds will fit with just a minor touch of grinding the frame. I notched maybe 1/8 inch and that was just because I wanted a little more clearance.
Blackpony is offline   Reply With Quote
Old 03-31-2014, 10:57 PM   #7
Blackpony
Blackpony's Avatar
Old 04-01-2014, 01:29 AM   #8
woodwright
Enjoying left field
woodwright's Avatar
Ive got truck manifolds on my 70 suburban. I'm cutting off the flanges and welding on vbands.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 04-01-2014, 09:12 AM   #9
Blackpony
Blackpony's Avatar
Old 04-01-2014, 09:14 AM   #10
Blackpony
Blackpony's Avatar
Double post
Old 04-01-2014, 08:57 PM   #11
jsett83
Thanks for the quick replies gents. After test fitting the truck manifolds again it looks like the pasenger side may clear. I think this is because my the of the adjustable mounts and the motor sitting further to the rear. Is there anything I should watch out for if the motor is further back than norm? I plan to use top mount a/c, p/s issues maybe? Thx
Old 04-02-2014, 12:11 AM   #12
solidaxel
solidaxel's Avatar
Are you using a column shift?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-02-2014, 06:52 AM   #13
jsett83
Yes I am. The shifter linkage lined up and I have all gears I believe
Old 04-02-2014, 05:02 PM   #14
69sinker
69sinker's Avatar
I've got a set of 02 Camaro manifolds you can have. I go to Wood River once a week if you need them. They need a little attention. pm me if you want them. Dave
My 69 cst lwb 2wd LS1 swap 5.7/4L60e build
http://67-72chevytrucks.com/vboard/s...d.php?t=589869
69sinker is offline   Reply With Quote
Old 04-03-2014, 11:14 PM   #15
solidaxel
solidaxel's Avatar
That is what I am using also, and for a bonus I slid the engine back on my DD mounts until the trans linkage and drive shaft fit in the right spot !
I think my 78 SWB is the same as yours
LS 3 4L70E
Old 04-03-2014, 11:45 PM   #16
dman1982
dman1982's Avatar
i was curious about this as well...to put the flanges on mine i got to take out a 1/4 inch or so on the drivers side, the passenger fits fine...im just gonna pull out the grinder on the drivers side
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 04-04-2014, 07:24 PM   #17
chebyshortbox65
chebyshortbox65's Avatar
I used the truck manifolds only had to slight clearanceing of the left lower frame rail with home made plates.also I have a set of vette manifolds that look like they might fit pretty good looks like the old school rams horn manifolds
chebyshortbox65 is offline   Reply With Quote
Old 04-04-2014, 07:39 PM   #18
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
lol I just realized this thread was about "MAINFOLDS".
This guy has some MAINFOLDS on his scooter.
Old 04-05-2014, 07:03 PM   #19
72_K10_Vegas
72_K10_Vegas's Avatar
HAH!
Funny Stuff
72_K10_Vegas is offline   Reply With Quote
