Old 04-28-2014, 09:24 AM   #1
ziplock
ziplock's Avatar
1964 C10 Hercules Diesel
Hello fellow diesel fans. I was not aware this section of the board existed.
Little info on the engine. Its a 3.7L Hercules Diesel. VE pump, Original GM application, SM465. Found while looking for a 4bt. Was originally in a Chevy delivery van. Thinking maybe a repower for a 6.2.
Here are a few photos of the build.
Yes, Its painted Cummins Beige, Sue Me!
Little bit of CM modification.
ziplock is offline   Reply With Quote
Old 04-28-2014, 09:30 AM   #2
ziplock
ziplock's Avatar
Re: 1964 C10 Hercules Diesel
I'm currently running 2.92s out back from an old big block Cadillac. Not real happy with this setup. I would like to find a NV4500 or maybe a 3500.
Old 04-28-2014, 04:35 PM   #3
marvgarr68
marvgarr68's Avatar
Kudos. I like setups like this everyone does a Cummins. I like it a lot I went the custom 6.5 route. My build is in this forum as for the trans did you only want a manual? I building a 4l80e full manual no electronics. Awesome job I just love how it came out. Hows the power?
1976 k20, 350 built, 44/14 axles
1968 c10 6.5 turbo diesel,t5 trans
1977 gmc c3500 dually, crew, 4-53t, 5&3 trans
http://67-72chevytrucks.com/vboard/s...d.php?t=591188
marvgarr68 is offline   Reply With Quote
Old 04-29-2014, 08:26 PM   #4
ryanroo
ryanroo's Avatar
i know nothing about that little engine, but it sure looks like a heck of a truck. Well done!
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 05-01-2014, 07:38 PM   #5
superduty_59
Cool truck and build. Most lowered trucks run gassers. Nice to see a lowered coal roller!
superduty_59 is offline   Reply With Quote
Old 05-21-2014, 08:45 PM   #6
mooseknuckles
mooseknuckles's Avatar
sweet truck bro!
mooseknuckles is offline   Reply With Quote
Old 05-23-2014, 09:11 PM   #7
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Awesome truck and great job doing the swap!
Ryan
1969 Chevy milk truck
Old 07-22-2014, 12:41 PM   #8
ziplock
ziplock's Avatar
Thanks Dudes! I recently swapped in a NV4500 out of a 92. Upgraded to the hydro clutch (very easy) and love it. Having the extra gear is awesome on the highway. I still lug pretty hard from 2nd to 3rd. Ive got the 3200 governor spring I need to install along with turning up the power screw. We will see if that helps any. If not I will look into replacing the gears in the rear over the winter.
Old 07-22-2014, 06:53 PM   #9
mooseknuckles
this truck is super cool!
Old 07-23-2014, 09:17 PM   #10
1972RedNeck
1972RedNeck's Avatar
You have a pyro, correct?
What turbo does it have?
1972RedNeck is offline   Reply With Quote
Old 07-23-2014, 09:22 PM   #11
1972RedNeck
Ignore
Old 07-24-2014, 11:13 AM   #12
dieseldude4bt
What intercooler are you using? Do you have any pic's of it?
I would like to put one on my truck and still have room for an AC condenser and leave the battery where it is.
63 k20 with cummins 4bt, owned sence 1982
dieseldude4bt is offline   Reply With Quote
Old 07-28-2014, 10:07 AM   #13
ziplock
ziplock's Avatar
Its a Garrett that came with the engine. Its mounted in front of the radiator on the backside of the core support. I cant seem to find the pictures i took while i was installing it. But here it is.
it measures roughly 24"X11"X3"
Old 08-21-2014, 10:34 PM   #14
angrymanhands
I like this. What's the power like? I'm in the process of gathering information for a swap. Right now I'm considering a 4bt, but I haven't put money on anything yet.
angrymanhands is offline   Reply With Quote
