Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 07-09-2013, 03:06 PM   #226
Hart_Rod
Hart_Rod's Avatar
Re: 1966 suburban slammed fuel injected 6.2L
Also, what radiator cooler did you use? What are you using for your A/C compressor?
Hart_Rod is offline   Reply With Quote
Old 07-10-2013, 10:21 AM   #227
c.brown
c.brown's Avatar
Originally Posted by Hart_Rod View Post
Checked out the thread ,what's your motor set at in the pics thanks
My build
c.brown is offline   Reply With Quote
Old 08-30-2013, 08:38 AM   #228
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
hey any updates!?!
gostranger is offline   Reply With Quote
Old 08-30-2013, 08:56 AM   #229
Hart_Rod
Hart_Rod's Avatar
Sorry I missed this CB, it was at 7 to get the angles right. I'm waiting on some shorter motor mounts.
Originally Posted by gostranger View Post
hey any updates!?!
+1
Old 08-30-2013, 09:11 AM   #230
c.brown
c.brown's Avatar
Ya finally fired my engine for the first time fired on the second try ,just have to adjust fuel pressure then should be good thanks for the interest guys
My build
Old 09-01-2013, 01:06 PM   #231
biohazardbill
Originally Posted by kpc01 View Post
C.brown I saw you got a boyd welding tank. I am looking for one for my 64 suburban that I will be doing porterbuilt suspension on. Can you tell me if the tank he sells fits well with the porterbuilt and if it will allow it to drop all the way still? I'm doing a LS motor as well so will be doing the EFI tank probably exactly like yours. My stock tank is only an inch or so from the floor but its about 13" tall and his is 10" I believe.
Any input or advice?
I don't know if this is too late or not but I have a tank from them in my burb with PB suspension.
Here it is installed:
http://67-72chevytrucks.com/vboard/s...d.php?t=517669
I just got my FI pump from them the other day so I could also run FI. They still have the blueprint for specs. Will allow you to use factory fuel fill.
biohazardbill is offline   Reply With Quote
Old 09-02-2013, 03:14 PM   #232
kpc01
thanks for the link. I'll definitely be doing this to mine!
kpc01 is offline   Reply With Quote
Old 09-02-2013, 08:21 PM   #233
gostranger
gostranger's Avatar
Awesome news! That is a major step good job!!!
Old 05-04-2014, 03:37 PM   #234
meltmetal
meltmetal's Avatar
Awesome burb, any more progress on it?
meltmetal is offline   Reply With Quote
Old 05-04-2014, 06:05 PM   #235
Leroy-B1
Looking cool
Leroy-B1 is offline   Reply With Quote
Old 05-05-2014, 05:39 AM   #236
gostranger
gostranger's Avatar
this thing should be getting close to being done! lets see some of the updates!!!
Old 05-06-2014, 09:16 AM   #237
c.brown
c.brown's Avatar
Originally Posted by Leroy-B1 View Post
Looking cool
Thanks for the interest and comments,finished up a few things going into winter,then worked to much to touch it,about to start getting at it again here's some pics /updates
My build
Old 05-06-2014, 09:26 AM   #238
c.brown
c.brown's Avatar
Drive shaft done,widened core support mouth for radiator and mocked up,
My build
Old 05-08-2014, 05:48 AM   #239
gostranger
gostranger's Avatar
awesome work!!!! looks great!!!!
Old 05-10-2014, 12:59 PM   #240
meltmetal
meltmetal's Avatar
Glad to see you're still cipping away at it!
Old 05-11-2014, 06:44 PM   #241
c.brown
c.brown's Avatar
Thanks guys,about to weld my exhaust together running a x pipe and flowmasters,I couldn't wait to here what they sounded like so I slipped them on real quick and fired it up ,I liked the way it sounded motivated me
My build
Old 05-12-2014, 04:45 PM   #242
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Nice work. Your burb is going to be sweet!
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 05-15-2014, 08:02 PM   #243
c.brown
c.brown's Avatar
Thanks,hope to really get at it soon
My build
Old 05-15-2014, 09:23 PM   #244
Hart_Rod
Hart_Rod's Avatar
Looking good CB what exhaust kit are you using?
Old 07-04-2014, 03:29 PM   #245
c.brown
c.brown's Avatar
Sorry missed this,I used a universal pipe kit from speedway motors and the x part ordered off amazon
My build
Old 07-04-2014, 03:36 PM   #246
c.brown
c.brown's Avatar
Here's a better look at how I ran the exhaust just have to make some hangers now
My build
Old 07-04-2014, 03:47 PM   #247
c.brown
c.brown's Avatar
Here's another pic of exhaust
My build
Old 07-05-2014, 07:10 AM   #248
piratexpress1369a
piratexpress1369a's Avatar
that one hell of a bend on the header pipe ..is that the shifter linkage you had to go around
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 07-05-2014, 10:25 AM   #249
c.brown
c.brown's Avatar
No,it was the way header was made they where for a camaro fit good besides the bend
My build
Old 07-06-2014, 11:12 AM   #250
gostranger
gostranger's Avatar
my header has the same bend and it was for the truck!
