Old 09-25-2012, 11:29 PM   #101
JCampbell
Re: My swap. 5.3 into a 1990 3/4 ton 4x4 Suburban.
Looks great! Dig that color.
JCampbell is offline   Reply With Quote
Old 09-26-2012, 10:54 AM   #102
JCampbell
Have you had an opportunity to get any MPG figures yet? Curious to see the numbers with that TH400.
Old 09-26-2012, 08:36 PM   #103
y5mgisi
Second Chance Program
y5mgisi's Avatar
About 12 mised driving. The problem with my numbers are that as i said, the computer is tuned wrong and my trip to work (which is most of my miles i put on my trucks...) is a whole 4 miles round trip... So, it doesnt even get to operating temp normally! I expect that when its all dialed in and if given the chance to drive normal miles it would be right at 15 as a running average. So not that great, but a bump up from the 10 it used to get!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 12-29-2012, 11:22 PM   #104
y5mgisi
y5mgisi's Avatar
Got my reprogrammed computer today! Can't wait to see what it does for my mpg and power!
Old 05-08-2013, 02:53 AM   #105
83GMCK2500
Very nice build! Update on mileage and power with reprogrammed ECM?
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is online now   Reply With Quote
Old 05-08-2013, 03:18 AM   #106
y5mgisi
y5mgisi's Avatar
No... Sadly there is quite a challenge getting a properly programmed computer for this truck. The problem being, im using a camaro harness and o2 sensors. This doesnt jive well with the 5.3 (truck) tuning. Ultimately, right now, im running a 5.3 tune and its nut reading the o2 sensors... So, my power seems about the same as with the LS1 tune, and my milage seems better. But i actually havent driven it much since i got it done, had it re painted, and got my 2012 Sierra. My long/short term plan is to rip the wiring all back out and start back from scratch using a combination of the ls1 harness and a normal truck harness. In doing so i will b e switching back to the truck o2's as well. There is a big list of hindsight issues at play here. So, it will be a while before i start driving it with any degree of consistency again, but when i do, i;ll report. Honestly tho, i feel that the 5.3 in a burb is pushing it. Its plenty of power, but its not got a lot of excess power. I think a 5.3 with a good tune, headers, and CAI is plenty well sufficient. I think if i had it all to do over, i probably wouldnt have done anything different. Its just the situation i was/am in. The old motor was so bad that it wouldnt have made it to where it is now. And i just really like everything about having a LS under the hood! But, In the end, the 5.3 wont stay in here forever. Its a place holder until i drop in a 6.0/6.2/8.1.
Bottom line, I would do a 5.3 swap into anything in a heart beat! THey just run good! They are cheap(ish) reliable, and just fun!
Old 05-08-2013, 01:16 PM   #107
Ranger6202
question: i didn't think the harness would make much of a difference, as long as everything plugs in (DBY or Cable and etc...). I agree the O2's will change the tune a little. I'd recommend (rockauto.com) to get a cheap set of o2's for the 5.3.
Ranger6202 is offline   Reply With Quote
Old 05-08-2013, 01:54 PM   #108
y5mgisi
y5mgisi's Avatar
Lol that wasn't a question. The problem is the Camaro o2s are case grounded qwhile the truck o2s are grounded through the ecm. So the computer is just flat out not reading them.
Old 05-08-2013, 03:54 PM   #109
Ranger6202
sorry if i came off ignorant, i should have phrased it more as a question than a comment. Is it a possibility to ground the O2's through the ecm by adding pins in the right spot of the ecm plugs?
Old 05-08-2013, 08:20 PM   #110
y5mgisi
y5mgisi's Avatar
Maybe. Truthfully though, im just not interested in that. I want to take it back to being a little more simple. I dont want so much mix and matching. I want to mostly, completely rewire the whole engine instal to make it a lot more factory as opposed to how i just tied it all in like i did the first go around. It would probably work forever if i went back with the LS1 tune and kept the wiring just how it is and had a tuner custom tune the fuel/spark maps. But thats just not quite what i want. I want it to be a 1990 suburban with a factory 5.3. If that makes any sense.
Old 05-15-2014, 08:37 AM   #111
NastyBuzzard
NastyBuzzard's Avatar
You did an excellent job on your swap. Did you ever get a tune sorted out? Any more pictures of how you mounted the stock air intake box?
NastyBuzzard is offline   Reply With Quote
Old 05-15-2014, 08:13 PM   #112
y5mgisi
y5mgisi's Avatar
Yes i did. In the end it was a simple matter of running the 5.3 tune and re wiring the o2 sensors. Now tho, I have ripped my wiring all back out and am in the process of re doing that. Here is where im at now!
Old 05-15-2014, 09:22 PM   #113
NastyBuzzard
Very nice! Sucks to go back and redo it tho I bet.
Old 05-15-2014, 11:28 PM   #114
mcbassin
Still Learning
mcbassin's Avatar
Very nice work on the new harness! It will definitely be worth all the trouble for piece of mind.
Old 05-16-2014, 02:56 AM   #115
y5mgisi
y5mgisi's Avatar
Kinda. But i feel like I knew this was coming. When i bought the motor i wasnt very happy about the harness. But i was so excited to have it and get it up and running that i just went ahead and installed it. The more i lived with it, the more it ate at me knowing that i was driving around a hack job. The tags (registration) went bad while i had it down for paint so i figured i would just leave them bad and start fixing some of the stuff that i put off when i was just to eager to drive it.
Might not look like much in the pics but it is turning out really good. I have done one before and learned alot from it on what i wanted out of this harness. And most importantly, just zero hack. Im 100% confidant in this harness!
Old 05-16-2014, 02:59 AM   #116
y5mgisi
y5mgisi's Avatar
During,
Pile of unneeded wire from the harness,
Old 05-16-2014, 07:25 AM   #117
NastyBuzzard
I hope to channel your patience when I tackle my wiring. I am hoping b/c I am going to integrate the entire wiring harness from my 2001 donor I won't have that big pile of "spaghetti" wiring! Looking good though, patience pays off in the long run as well as having and doing the right stuff!
Old 05-16-2014, 07:25 PM   #118
y5mgisi
y5mgisi's Avatar
Now the real fun begins. Turning all this into something that looks pretty.
Old 05-17-2014, 12:56 PM   #119
NastyBuzzard
Looks like all thats left is to loom it up!
Old 05-19-2014, 04:36 PM   #120
y5mgisi
y5mgisi's Avatar
Pretty much. I still have to make up the fuse block in the cab and route everything just right. This week leading into Memorial day I'm pretty busy so I will probably hardly touch it until next week.
Old 05-21-2014, 12:17 AM   #121
BigRed76
BigRed76's Avatar
Great job on the swap I noticed you used a VDO temp sender instead of the autometer version that most of us have used. How well does that sender work with your factory gauge? The autometer sender reads too low at full temp.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 05-21-2014, 12:28 AM   #122
y5mgisi
y5mgisi's Avatar
The VDO sender does not work with the stock gauge. Im doing it the "smart" way now with a stock sender for the burb thats turned down to the 12x1.5 thread to thread right into the head. Its pretty popular and a friend has done one also with no problems. The sweet thing is that because its brass, and therefore soft, you can chuck it up in your cordless drill and use a file to turn down the outside until its the right size to run the die over it.
Old 05-21-2014, 07:59 AM   #123
NastyBuzzard
What's your plan to mount the pcm this go round?
Old 05-21-2014, 08:37 AM   #124
BigRed76
BigRed76's Avatar
That's interesting, I never thought of doing that. Might have to give that I try with mine.
Zach
Old 05-21-2014, 06:51 PM   #125
y5mgisi
y5mgisi's Avatar
Im going to mount it between the battery and radiator on the driver side using a custom mount.
