Old 06-05-2014, 02:18 PM   #1
Jo Daddy's Garage
Question Oddball 1968 GMC
Ran across this GMC with a vin of CM3OVPB41045. I will be looking at it this afternoon. It is a short bed, V6, 4 speed, power drum brakes, buddy bucket seats, and a 1 ton chassis. No sticker in glove box... It was ordered as a cab and chassis by a farmer from what I understand. Anybody ever see something like this?
Jo Daddy's Garage is offline   Reply With Quote
Old 06-05-2014, 02:47 PM   #2
mgkgmc
mgkgmc's Avatar
Re: Oddball 1968 GMC
Look at the frame in front of the rear wheels and see if it has been cut down and welded to a shortbed.
1970 GMC 1500 stepside
1972 GMC Jimmy Custom
2004 Chevy Colorado
1989 Swb Silverado
1972 Aj's Stormer
mgkgmc is offline   Reply With Quote
Old 06-05-2014, 04:25 PM   #3
67chevy1series
67chevy1series's Avatar
GM did not make a 1 ton or 3/4 ton as a shortbed. With that being said there a couple possible scenarios: 1 the frame is a factory 1/2 ton shortbed frame with 3/4 ton or 1 ton suspension installed under. 2 the frame and suspension are all from a 3/4 ton or 1 ton and the frame was cut down.
67chevy1series is offline   Reply With Quote
Old 06-05-2014, 05:16 PM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
...and the bed being a different color (primer?) means it was either cut down or off a different truck.
However, the bed appears to be a true shortbed box (see the pics and my post in the thread below
http://67-72chevytrucks.com/vboard/s...ht=cut+longbed
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 06-05-2014, 06:24 PM   #5
jdw
Looks like the one ton brake booster...
jdw is offline   Reply With Quote
Old 06-05-2014, 07:41 PM   #6
haminator
haminator's Avatar
Without seeing the frame I won't say it's not a 1 ton that has been shortened. More than likely a 3/4 ton that has been shortened. I don't what the vin says about it but maybe a 1 ton cab has been mounted on another frame as well. V-6 is fairly common in the 67-68 GMC's, less common if its a 351. Looks like a Custom cab, what does the GMC emblems say, 2500 or 3500, V-8 or V-6? Buddy buckets are a nice score too, also found a lot in 67-68 GMC's. I would say more often than Chevys anyway. Either way looks like a good solid project.
haminator is offline   Reply With Quote
Old 06-05-2014, 08:42 PM   #7
Jo Daddy's Garage
I bought the truck. It is a 1 ton. 3500 and v-six on the fender emblem. The frame has been shortened. It was a cab and chassis order, so it would not have had a bed from the factory. More than likely it had a stake bed on it. I may try to find a 6 foot stake bed and sell the other one. Other than a little rust in the rockers, it just needs some trim around the front, and down the sides. I will probably pull out the V6 and put in a 350 and a 700r4. This needs to be my daily driver, but I don't want it all polished and shiny...
Old 06-05-2014, 08:45 PM   #8
Ozzy2013
Ozzy2013's Avatar
Nice solid truck to build wish my GMC had the buckets .
Ozzy2013 is offline   Reply With Quote
Old 06-05-2014, 08:47 PM   #9
slow-1
slow-1's Avatar
That will be a cool truck with a flat bed...looks solid.
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline   Reply With Quote
Old 06-05-2014, 09:45 PM   #10
chipflyer
chipflyer's Avatar
Glad to see you here with the pics! Cool looking old truck, and I am fond of those AR-226 wheels, I have a set of 5 lug like those on my 36 2 door sedan.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 06-05-2014, 10:00 PM   #11
uncle
Not to bust your bubble but it's a cut down truck. It's been floating around SC and Ga. for a while. Tried to buy several times myself.
uncle is offline   Reply With Quote
Old 06-05-2014, 10:16 PM   #12
chipflyer
chipflyer's Avatar
Not to burst your bubble uncle but he did say a couple messages above that he knew that
Old 06-05-2014, 10:40 PM   #13
uncle
Yep. Like I've said before and even to myself. Reading is fundamental.
Old 06-06-2014, 06:48 AM   #14
Jo Daddy's Garage
I'll try to keep things up to date as it moves along.
Old 06-06-2014, 06:50 AM   #15
Jo Daddy's Garage
So what happened that you didn't buy it?
Old 06-06-2014, 07:19 AM   #16
uncle
First time ( probably 10 + yrs ago)it sold fast, second time it was lil high IMO. Still a neat truck either way.
Old 06-06-2014, 08:33 AM   #17
DWilbur
Let me know if you decide to sell the short bed. I have been looking for one.
DWilbur is offline   Reply With Quote
Old 06-06-2014, 08:50 AM   #18
67ChevyRedneck
For those that "know"... the inside looks stock and untouched...
Was it correct to have parchment door panels/arm rests with sandlewood dash/seats/instrument cluster/steering column/wheel? I know they did weird stuff with GMCs...
Congrats on the purchase. Very cool truck. If you add a stake bed, are you going to stretch the chassis back to 133"?
Jesse James
Project "On a Dime"
Old 06-06-2014, 09:17 AM   #19
Jo Daddy's Garage
I'll keep that in mind. It's not perfect, but it's not rusty either.
1955 Chevy Belair rat rod
1968 Camaro RS
1968 Balboa dune buggy
1968 Buick Riviera
1968 Mustang coupe (wife's car)
1968 GMC oddball
Old 06-06-2014, 09:19 AM   #20
Jo Daddy's Garage
Thanks. I think I'll leave it a short bed. May add power discs to the front though. I need it to be my daily driver at some point. Not shiny, but built to be used.
1968 Camaro RS
1968 Buick Riviera
1968 GMC oddball
Old 06-06-2014, 11:49 AM   #21
haminator
haminator's Avatar
good score non the less. I've had 2 GMC's that didn't have a SPID or even signs of one on the glove box. In the 67 I found the option sheet behind the carpet that covers the gas tank because of the buckets. you may look there, also maybe under the carpet or rubber mat. The 68 I traded off before I could look around for the option sheet. wonder if 67-68 GMC's used a SPID on the glove box?, Anyone know?
Old 06-06-2014, 12:19 PM   #22
chipflyer
chipflyer's Avatar
Yes, some GMC's used SPIDS some did not.
Jeff
1 ton, gmc, short bed
