04-30-2014, 08:16 PM | #51 |
Re: Project "Financial Burden": 1968 SWB C10
Going to go with a rear mounted gas tank for the LS engine fuel system. No need for the filler neck hole on the cab anymore although it is one of my favorite features of these classic trucks.
1968 SWB C10 http://67-72chevytrucks.com/vboard/s...d.php?t=508675 2011 Dodge Ram 1500 2012 Camaro ZL1 |
04-30-2014, 08:22 PM | #52 | ||
Thanks for the comments. Back when I was a kid my older brother told me about a drag car he saw labeled "Financial Burden." I've always thought it was a great name for a project. I like "Going Broke" too!
04-30-2014, 08:24 PM | #53 |
Man that rust repair looks oh so familiar. So glad that stage is over for me! Your metalwork looks meticulous! I like it!
04-30-2014, 08:36 PM | #54 |
Rusty Nuts
Love your craftsmenship. Your doing a fine job and its looking great.
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
05-01-2014, 12:13 AM | #55 |
Still Learning
You have done a great job on the chassis and cab. I really like the rust repair work. You are making it look too easy. I remember before I repaired my cab, I saw a bunch of pictures like your's, I thought well that looks easy enough...little did I know the repair panels were a joke in many cases, the rust is everywhere on these old trucks and it takes some serious time to do it right. Very clean work and some nice welders you have there.
Looking foward to following the rest of the restoration. |
06-07-2014, 06:15 PM | #56 |
Thanks again for all the comments. It sure helps me stay motivated. I was able to save the lower part of the original rear door pillar and finished up the front pillar repair.
06-08-2014, 08:13 AM | #57 |
Since I've gotten a few requests to show more details around my work I've decided to do a more in depth summary of the cab corner replacement on this side of the truck. The first thing you need is a quality replacement patch panel. This picture shows the main thing to look for in a cab corner patch panel. You want a nice 90 degree contour on the bottom of the panel just like the original. This task is already challenging enough so make sure you start with good materials. The lower panel would have been a lot more work so I used the Goodmark branded panel (that I got from GMCPaul's Truck Parts) and sent the other one to the scrap pile.
06-08-2014, 08:18 AM | #58 |
I then used Eastwood's Weld Thru Primer on everything that was going to be covered up by the new patch panel. I was able to cut along the brace line for this repair which hides most of the patch seam where you can't see it from the inside. I also added a small brace (before I cut anything out) to help keep things in alignment.
06-08-2014, 08:24 AM | #59 |
Using the old panel as a template I made a rough mark on the patch panel with about 3/4 of an inch to spare. This helps get the panel in a more workable size. I also like to use a small round file to remove the burrs left behind to prevent cutting my hands up. Always were gloves when handling sheet metal!
06-08-2014, 08:30 AM | #60 |
I then prepped the rocker panel and cab corner interface to get a nice tight fit between the two pieces. I used a hammer and dolly to get things flat and then removed a bit of the "puckered" areas with a grinder.
06-08-2014, 08:34 AM | #61 |
I then clamped the patch panel in place making sure to align it with the rocker and scribed the inside of the panel for the final cut line.
06-08-2014, 08:40 AM | #62 |
To get the other side of the final cut line (since I could not scribe it from the inside) I made an offset mark from the cab cut line using my 12 inch steel ruler. I then clamped the patch panel back in place and used the offset line to transfer onto the patch panel using the same 12 inch steel ruler.
06-08-2014, 08:44 AM | #63 |
I then added a couple of rosette weld locations at the bottom of the panel and trimmed off some excess material. I like to use a red scuff disk to remove the e-coat and prep everything for welding.
06-08-2014, 08:57 AM | #64 |
Now we can start welding! I like to start near the rocker panel and work my way around about every inch or so making sure that the panel fitment is tight along the way. I then weld in between the previous set of welds and then in between the next and so on until you have a continuous weld. I like to lightly smooth the welds in between each round and use a wire wheel to keep things nice and clean. The wire wheel also removes the heat marks so you can see exactly where your new round of welds are located. I take a lot of time in this process to keep the panel cool.
06-08-2014, 09:04 AM | #65 |
Now that the panel is fully welded I smooth things out with a variety of sanding disk including the sanding rolls that are used for porting cylinder heads. Now you have to be sure to work the hammer and dolly when necessary in between all those rounds of welding to keep everything as flat as possible. I hope this was helpful. Now onto rocker panel installation...
06-29-2014, 07:46 PM | #66 |
Now onto the rocker panel installation. You can never have too may clamps.
06-29-2014, 07:50 PM | #67 |
I put on some primer just to keep the bare metal from rusting and took a picture of all of the sections I had to remove.
06-29-2014, 07:58 PM | #68 |
I had to make some room for the Tremec T56 transmission I am planning on running by doing a high hump conversion.
06-29-2014, 09:28 PM | #69 |
67-72 parts collector,…
Very nice work!
06-30-2014, 01:09 AM | #70 |
X2 ^^
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
06-30-2014, 08:25 AM | #71 |
Still Learning
Excellent write up and pictures. You are a master at making those repairs look easy.
Keep the pictures coming. |
07-19-2014, 04:46 PM | #72 |
Had to fix the 1990's era modifications for a CD player. Luckily I scored a patch panel for $10 at a swap meet.
07-19-2014, 08:23 PM | #73 |
Nice work! I sure wish I had these skills.
07-19-2014, 11:56 PM | #74 |
Awesome work!
07-23-2014, 04:57 AM | #75 |
A day late and $1 short...
VERY VERY nice work, I am really impressed with your repairs so far. I'm ready for more updates so get with it!!
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
