07-23-2014, 09:26 AM | #1 |
Solid engine mounts.....
Ok I need a little help I got a new set of factory mounts but I think the engine I'm putting together is just gonna rip them .... I have a friend that has had to replace his twice already... I think I need to switch mine out before I even put them in.... Has anyone on here used a solid mount if so what kind and where can I get them ??? All I can seem to find is a clamshell design and mine aren't made that way ....
It's been a long time coming... It's time to get it done.. |
07-23-2014, 09:55 AM | #2 |
Re: Solid engine mounts.....
Summitrcing.com take your pick they have dozens of applications
07-23-2014, 01:03 PM | #3 |
chain the block down
07-23-2014, 05:42 PM | #4 | |
07-23-2014, 09:16 PM | #5 |
Ok so any of them will work just as long as I get them for a small block 350 ??? Is this what I'm understanding???
07-23-2014, 09:20 PM | #6 |
I thought about it .... It just looks tacky I also thought about a turn buckle just to make it look better... I'm thinking I might just make a homemade front motor plate out of some scrap 1/4" aluminum plate and use the two bolt holes at the bottom front of the block....
It's been a long time coming... It's time to get it done.. Last edited by papsoldblue72; 07-23-2014 at 09:24 PM. Reason: addition |
07-23-2014, 11:04 PM | #7 | |
07-24-2014, 08:45 AM | #8 |
Thanks 69chevytrucker I think I will just do that ...
07-24-2014, 09:22 AM | #9 |
2WD Jimmy
Get the Energy Suspension mounts. You cat rip those .
Tags |
engine mount |
