Old 07-13-2014, 02:22 AM   #1
72K5CSTDarkOlive
72K5CSTDarkOlive's Avatar
Help: Leaf spring?
Is this ok or should I replace these?
The other side lines up flush against the spring eye bolt but the passenger side leaf springs look like a different set. I think the PO installed new ones at some point. As part of the restoration process, I separated the leaf springs so I could have them sand blasted and painted. I put them back together and this what I noticed. I'm not sure if it was like this before.
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612
Build version 2.0: 72 K5
6.0 LQ9, 4L80e, NP205
http://67-72chevytrucks.com/vboard/s...d.php?t=793192
1972 CST K5 Blazer Dark Olive
72K5CSTDarkOlive is offline   Reply With Quote
Old 08-10-2014, 06:45 PM   #2
77K10Silverado
77K10Silverado's Avatar
Re: Help: Leaf spring?
I'd say replace. Can you take it by a local spring shop to have them look at it? Won't brake the bank if so, they are reasonably priced I feel. Make sure you do it in pairs! If they are original, you'll prob gain a touch of ride height b
77K10Silverado is offline   Reply With Quote
