Old 08-11-2014, 07:34 PM   #1
theastronaut
theastronaut's Avatar
1940 Packard 120 Convertible Restoration
I've had a ton of guys asking about our next build so here it is. It's a 1940 Packard 120 Convertible Coupe with tons of rust. The owner is from Connecticut and heard about us from another Packard Club member who lives near us and stops by our shop regularly. It was bought as a driver but the owner kept finding more and more wrong with it so it came apart for a full restoration. He and his wife drove down a few weeks ago to meet us and check out some of our work and he decided to have us restore it. We had only seen pictures until now... had no idea it would be this bad! We'll be doing the rust repair, metal work, bodywork, paint, upholstery, and final assembly. The owner and a friend have already done the suspension and mechanical work.
This is it as it was delivered, we have the rest of the parts in storage. The owner was a helicopter mechanic and is very detail oriented so all of the parts were boxed meticulously; each box is labeled with a list of parts and hardware inside.
theastronaut is offline   Reply With Quote
Old 08-11-2014, 07:48 PM   #2
theastronaut
Re: 1940 Packard 120 Convertible Restoration
Pics of the rust. There won't be much original Packard metal in the lower 8" once we're done.
Trunk area.
Bondo check... used my 3" grinder to get to bare metal around the bottom edge. Lots of filler over caved in metal, and there are gobs of brass showing around all the "patches".
Old floor "repair" with aluminum pop riveted over the original rusty floors. The rivets had fallen out long ago.
Old 08-11-2014, 07:50 PM   #3
theastronaut
I made body braces out of 1x1 tubing with turnbuckles welded in so I can adjust the door gaps before everything it welded back in. Some of the body mounts are completely rusted away so it's doubtful that the body is still sitting squarely on the frame. This will also keep the body from folding in half once it's on the rotisserie.
Old 08-11-2014, 09:13 PM   #4
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I'm in, love watching your work..plus I'm learning alot. Thanks for sharing. ..
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 08-11-2014, 09:18 PM   #5
MP&C
MP&C's Avatar
Ouch! Definitely have your work cut out! Subscribed
Robert
MP&C is offline   Reply With Quote
Old 08-11-2014, 09:19 PM   #6
duallyjams
duallyjams's Avatar
You like a challenge and it will keep the shop busy and we get see a Packard coupe.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 08-11-2014, 10:02 PM   #7
flashed
Im in for another one.
flashed is offline   Reply With Quote
Old 08-11-2014, 10:14 PM   #8
hopped up
hopped up's Avatar
This is gonna be good!
hopped up is offline   Reply With Quote
Old 08-11-2014, 10:24 PM   #9
NONHOG
NONHOG's Avatar
Now I can feel better about your F100 project finishing!
Watching and learning.
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 08-12-2014, 08:38 PM   #10
tune_1
Great to see the next project. I really like the work that you do so please post a lot of pictures, and your explanations really help.
Dwight
tune_1 is offline   Reply With Quote
Old 08-14-2014, 01:40 PM   #11
theastronaut
Started digging into the driver side lower cowl, rocker area, and lower quarter panel. It was tough to find the rocker seams in the door jamb since they were butt-welded from the factory. I took everything apart the way it was assembled so I could use the original parts for templates. I'll leave the other side together for reference until the driver side is back together.
The cowl was pretty rough, had stress cracks all over it plus rust at the bottom. Cut it out to get to the inner layers.
Made a paper template before cutting it out.
Inner door post.
Inner panel rust.
Starting on the rockers. Tons of lead and filler.
Trying to find the rear rocker and quarter panel seam.
Old 08-14-2014, 01:47 PM   #12
theastronaut
Cutting out the quarter panel.
B pillar post base.
Removing the outer rocker.
Old 08-14-2014, 01:52 PM   #13
theastronaut
Removing the inner rocker. Had to cut the inner fenderwell back.
Not much left to go by on the body mount areas.
Rear half of inner rocker removed.
Turnbuckle added to adjust height of body.
Cutting out the front pillar.
The way the inner brace and sheetmetal were layered made this hard to cut out without doing any damage.
Old 08-14-2014, 01:55 PM   #14
theastronaut
Pillar and inner brace cut out.
Cutting out the toe board.
Front half of inner rocker removed.
Car is now halfway rust free!! That was the easy part.
Body brace/mount under the rear seat.
Made a template of 1/2 of the inner rocker.
Old 08-14-2014, 03:22 PM   #15
dantimdad
dantimdad's Avatar
Good Lord! I thought my truck was bad!
Off to a good start though.
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline   Reply With Quote
Old 08-14-2014, 03:24 PM   #16
dantimdad
dantimdad's Avatar
I know it's going to turn out amazing.
Old 08-14-2014, 05:29 PM   #17
duallyjams
duallyjams's Avatar
Now that's peeling a onion.
James
IG duallyjams
Old 08-14-2014, 05:54 PM   #18
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Watching this build. That's a rare piece right there.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
http://67-72chevytrucks.com/vboard/payments.php
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 08-15-2014, 03:15 PM   #19
Clyde65
Clyde65's Avatar
IMO for a 74 year old car, that isnt "a lot" of rust but its enough to make the job a tough one! Thinking of where it came from (north East) it may be rust free!
I love seeing your work, very nice and professional!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-17-2014, 01:17 PM   #20
Ol Blue K20
I'm glad you're not scared of it. Thanks for the pics and info
Dale
Old 08-18-2014, 10:25 AM   #21
alaska gasser
alaska gasser's Avatar
I used to have my own custom shop till the old lungs said no more to doing it full time. It did and still does tick me off when I see a car that was "fixed" like this one so someone could make $ on an unsuspecting individual.
You have your work cut out for you and I'm in for this build.
http://67-72chevytrucks.com/vboard/s...d.php?t=592642 '48 Chev extended cab with attitude
http://67-72chevytrucks.com/vboard/s...d.php?t=592769 My daughter's '46 International PU
alaska gasser is offline   Reply With Quote
Old 08-19-2014, 10:08 AM   #22
theastronaut
Steven
Thanks Steven!!
Not much left of the onion now...
Yeah, not sure exactly how many were made or still exist but they're pretty scarce.
Thanks, it's not as bad as it could have been for sure. Atleast there is a little bit left for patterns.
Welcome!
We see it a lot too. Since we're the only shop around that does glass/weatherstripping on older cars we get tons of cars that are fresh out of the paint shop. It's amazing how many are quickly patched up and painted and the owner never knows!
Old 08-19-2014, 10:14 AM   #23
theastronaut
Pattern made for the rear half of the inner rocker.
Inner A-pillar support was straightened, repaired, and blasted.
Making a new A-pillar skin.
Making patterns for a new B-pillar bottom.
Made the part in three pieces. It still needs two more pieces on the front half.
Rear pieces welded in and smoothed.
Old 08-19-2014, 10:39 AM   #24
Russell Ashley
Russell Ashley's Avatar
Loving this build already. I'm definitely following along with this one. Going to be a beauty when it's done.
Russell Ashley is offline   Reply With Quote
Old 08-19-2014, 04:25 PM   #25
theastronaut
Thanks!!
Got the B-pillar post done.
