Old 07-30-2014, 09:54 AM   #376
Kim57
Kim57's Avatar
Re: 1958 Apache 38 Dually Dump Project
Things are looking good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 08-01-2014, 03:39 AM   #377
RockTonka
RockTonka's Avatar
Thanks Kim, slowly starting to look like a truck again...just to tear it all apart for paint in a while
Got the rear frame/bed pivot pretty much done...gotta build some feet at the rear like we did at the front, but we were able to cycle it and check clearances...nothing hit or bound up
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 08-01-2014, 10:23 AM   #378
Kim57
Kim57's Avatar
Very nice.
Kim
My build thread
Old 08-07-2014, 12:39 AM   #379
RockTonka
RockTonka's Avatar
Thanks again Kim!
Working on different parts of the truck here and there, but we did finish up the transfer case shifter and linkage, made it a bit taller...more leverage and easier to reach. Made it come up through the E-brake hole...also got a couple "dodge" style billet knobs for both the tranny and transfer case.
My build thread
Old 08-11-2014, 09:57 PM   #380
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice work on the hoist mounts and the tcase shifter set up!
Ryan
1969 Chevy milk truck
Old 08-15-2014, 01:14 AM   #381
RockTonka
RockTonka's Avatar
Thanks DW, we're going to just keep chipping away at it.
Not much to add, but did get the passenger side underbody box mount done
My build thread
Old 08-19-2014, 12:51 AM   #382
RockTonka
RockTonka's Avatar
How about a too tall shifter? Damn thing is, it actually feels pretty good there Might shorten it, might not.
My build thread
Old 08-19-2014, 09:52 AM   #383
Kim57
Kim57's Avatar
I like it.
I think it goes with the truck.
Kim
My build thread
Old 08-19-2014, 03:31 PM   #384
Dieselwrencher
I think it looks great!
Ryan
Old 08-20-2014, 02:47 AM   #385
RockTonka
RockTonka's Avatar
Originally Posted by Kim57 View Post
I like it.
Kim
Well, that's it then! It stays like that
My build thread
Old 08-20-2014, 09:59 AM   #386
NEWFISHER
NEWFISHER's Avatar
Its a BeAst! Love it! You do great work and its all comming together.I missed it in tbe build...is that a suspended Bear seat? Nice work.
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 08-20-2014, 04:59 PM   #387
Advanced Design
Advanced Design's Avatar
Just went through your build. Awesome truck and really appreciate your fabrication / design skills. Very nice welding too!
Advanced Design is offline   Reply With Quote
Old 08-21-2014, 01:38 AM   #388
RockTonka
RockTonka's Avatar
Hey Jon, thanks for dropping in and the kind words! The seat is an expanded version of a low side suspension seat from Twisted Stitch that we have on a Rhino. It's a bit thinner and more upright than traditional suspension seats from Beard, PRP, Mastercraft, Corbeau, or whoever, and allowed for much more leg/gut room
Thanks AD, that means a lot to us!!
Worked a bit on making room for the radiator (really the fan, I guess). We have an inexpensive FSR double pass 31x19 that should provide sufficient cooling. In this application, we really want to use a clutch/fan/shroud set-up to optimize air flow...really no problem once we removed all that pesky stock radiator/core support/body mount stuff up front that was in the way!
I know there's a way we can make this work...gonna try to figure that out this weekend.
My build thread
Old 08-23-2014, 04:22 AM   #389
RockTonka
RockTonka's Avatar
Did a little trimming and fitting tonight...looks like we can make this work. Cutting the old rad mounting flanges off flush with the core support gave us the clearance we needed for a clutch and fan for a mid 80's C20/30 with a BBC (19", 6 blade steel fan). We'll work on new rad mounts this weekend, but should easily have about an inch or so clearance from clutch to rad. The resulting core support "window" is now the same size as the rad core.
My build thread
Old 08-23-2014, 10:46 AM   #390
Kim57
Kim57's Avatar
Nice job.
Kim
My build thread
Old 09-01-2014, 04:50 AM   #391
RockTonka
RockTonka's Avatar
Again, Thanks Kim! Your taking time to comment on this and so many other threads really does mean a lot me (and other members, I'm sure)...a little bit of encouragement goes a long ways!!
Well, we're not quite done...but did get the hard part out of the way on mounting the radiator. After slimming down the core support, the body mounts were left a bit weak...welded a small section of 2" angle in each corner to reinforce that area.
Then cut down, dimpled, and welded a piece of 3" angle across the bottom as a lower radiator mount...it all barely clears the steering gear box.
We pop riveted strips of 1/4" belting to the inner face of the core support to hold the tanks just off that surface and fit 3/4" thick sections of heavy rubber strip into the lower radiator channel to isolate from that mount. Everything is close, but nothing will rub.
My build thread
Old 09-01-2014, 05:11 AM   #392
RockTonka
RockTonka's Avatar
We had a few ideas on how we wanted to do the upper radiator mount, but it all actually fell together easier than we had initially thought.
We struggled a bit with a distorted hood latch panel before giving up and chasing down another (good) core support/latch panel today from right across town...I love it when a plan comes together.
A quick bead blast on the "new" old parts and we were done...almost. The inner lip of the latch panel perfectly holds the top of the radiator in place...couldn't have been any better! We ended up with a little less than the inch of clutch to rad clearance we were looking for, but still have plenty of room.
We will fit/weld in a bit of sheetmetal to hide the top of the radiator and then call it done!
My build thread
Old 09-01-2014, 08:55 AM   #393
6BT 56
6BT 56's Avatar
Looken good guys. very nice to see the nice big fan in there. I only wish I could have fit the proper fan on mine. those 2 pesky cylinders on the front took care of that. Im really looken forward of pics of this thing returning the favour to you guys and getting to work pulling it's weight ! It will look good puling future projects around for years to come . How are you guys going to wire it? was the orriginal harness in good enuf shape to cary over ? I put a AAW harness in mine and have nuthing but good things to say abt it .
Keep up the great work .
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 09-01-2014, 10:42 AM   #394
Kim57
Kim57's Avatar
That worked out real nice on the radiator install.
Kim
My build thread
Old 09-01-2014, 12:48 PM   #395
Jeff La
Man just read this whole thread and can't believe I missed it before. You have built a great truck. Hopefully my next will be a 58 as that's the year I was born. You and your son's talent is amazing, can't wait to see more. Great also your son's enjoy trucks also, you are a blessed man.
Jeff La is offline   Reply With Quote
Old 09-02-2014, 01:18 PM   #396
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Love the long shifter and the rad install looks real nice too!
ChuckDriver is offline   Reply With Quote
Old 09-03-2014, 01:45 AM   #397
RockTonka
RockTonka's Avatar
Thanks 6BT! We're anxious to put it to work (and play)...like, yesterday already! We were hoping end of summer, but that's kinda here...now maybe, by Christmas?? We will rewire the truck ourselves (my son enjoys it )...not too much going on that's complicated. We stripped out all the stock wiring...not worth fooling with.
Kim
Yea, kinda fell into place...tape measure said it would fit, just not how.
Thank you Jeff, your kind words don't fall on deaf ears.
Thanks CD!
Dimpled up a strip of 16 ga. and welded it into the step of the latch panel to cover the top of the radiator, was hoping to get it smooth enough to not need any filler...gonna need a bit of a skim coat though.
My build thread
Old 09-03-2014, 07:55 AM   #398
Advanced Design
That came out really nice and the skim coat would maybe be a hint of some filler, if that.
Old 09-03-2014, 10:01 AM   #399
Kim57
Kim57's Avatar
I love the dimples you're doing. Looks real good.
Kim
My build thread
Old 09-03-2014, 11:11 AM   #400
_Ogre
_Ogre's Avatar
panel looks good rocktonka
shop air compressor timer
