Old 08-29-2014, 07:24 AM   #1
parrisc19844x4_468
parrisc19844x4_468's Avatar
Real buy for someone in omaha. tach dash.
found this on craigslist. I tried to buy it have it shipped but the guy said no, only local pickup.
http://omaha.craigslist.org/pts/4639037071.html
2017 Silverado LTZ 6.2
1984 Scottsdale K10 - 468 700r 4x4 lwb
1978 GMC Sierra Grande K15 350 Soond to be 406 th350 4x4 swb
1968 GMC 20 305 V6 good ole wood hauler.
Good Fences make good neighbors
parrisc19844x4_468 is offline   Reply With Quote
Old 08-29-2014, 07:37 AM   #2
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: Real buy for someone in omaha. tach dash.
I see "AMP" so it's only a 73-75 cluster. Anything else will result in learning the ancient communication skills of Indian Smoke Signals. $50 is pretty standard unless he's willing to hook it up and prove it works, otherwise you have to go with the theory it does not and requires a rebuild.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 08-29-2014, 08:59 AM   #3
parrisc19844x4_468
Agreed, I have bought about 5 or 6 so them, only found one that the tach actually worked. But for $50, it would be worth it to me.
Old 08-29-2014, 09:17 AM   #4
parrisc19844x4_468
[QUOTE=RandyP;6821694]I see "AMP" so it's only a 73-75 cluster. Anything else will result in learning the ancient communication skills of Indian Smoke Signals. $50 is pretty standard unless he's willing to hook it up and prove it works, otherwise you have to go with the theory it does not and requires a rebuild.[/QUOTE
Not really a sceret but those cluster will work in at least a 84. I put one in mine and followed the advise I found in this fourm. I removed the amp guage and the tabs behind it. Instlled the volt meter and wired the + and - directly to the guage and to a good power source and ground.
For the oil guage , i like the manual one anyways so that was easy, just ran the copper line up to the guage.
It was some work, but what i did, I cut the pig tail going into the cluster and crimped on bullert male and female connetor to make it easy to move the wire around.
I plan on doing the same thing to my 77 and 83. when i find the right parts.
as far as the prices goes, going by ebay, the tach dash there are $300 and up and belive me, been there done that, the tachs dont work. I have a guy in town that will fix the tach for $50, if just the resiter needs to be replace.
It just takes so good old american ingenuity (and this forum).
Old 08-30-2014, 10:54 PM   #5
c10sport
c10sport's Avatar
I've found 5 tach dashes down here. All but 2 have worked. Sold one when I sold my C10 and gave the other two to my friend that has two squares.
Jay
2001 Pontiac Aztek GT
c10sport is offline   Reply With Quote
Old 09-04-2014, 10:02 AM   #6
MalibuSSwagon
I got super lucky on my tach dash. Paid $40 for it and pulled from the C70, worked 100% and super clean. Even from the same year truck so it matched the gauge style perfectly.
MalibuSSwagon is offline   Reply With Quote
dash, real buy, tach
