Old 08-28-2014, 04:52 PM   #26
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: My 89 CC Dually: Double Wide
Glad to see that you finally put this in a build thread. I have been hearing all this stuff about the dually, but you know what they say, pictures are worth a 1000 words.
You work looks great and well planned out. Hopefully we can get together over the fall/winter and see this thing in person.
BTW, we just moved into our new house and the boss says I can start building my shop as soon as the updates to the house are done! Ordered the door yesterday for one room and hopefully the carpet and laminate flooring this weekend...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 08-28-2014, 04:55 PM   #27
aggie91
aggie91's Avatar
just noticed something...
The wheels changed between post #1 and post #13. What's up with that?
Karl
The LST Challenge:
Old 08-28-2014, 04:59 PM   #28
SCOTI
SCOTI's Avatar
Thanks to everyone! I appreciate the nice feedback.
I finally got the extra set of a-arms back late last night. I knocked one of the bump/steering stop pads off @ lunch today. I'll get the 2nd one done after work & start the slicing & dicing.....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 08-28-2014, 05:41 PM   #29
Jonboy
Slots go on anything!
Scoti has a thing for Alcoas. He just doesn't like them.
Scot, what master cylinder and prop valve did you use? You did do discs on the rear, right?
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 08-28-2014, 06:00 PM   #30
SCOTI
SCOTI's Avatar
Yep.... I've never cared for the small hole 16" Alcoa's. My buddy had these on his 94 but the fronts were pretty rough. I DA'd the snot out of them w/some 80grit to remove the heavy gouges & then just started sanding them w/finer grade paper until running some ScotchBrite over them. Haven't decided if they'll stay. If so, they'll get polished. I did consider Eagles 20" wheels but tire sizes for them are limited & to do 22's would require more $$ than I wanted to spend on a shop/tow truck (wheels, adapters, tires, widening the fenders, & repaint adds up quickly).
Or...... (wait for the shocker......).....
I just might run steelies. Some close to me might say I should change my NET name to N2Steel since I tend to stick w/low budget OE type steel wheels
I stuck w/the OE drum set-up out back so it's just a master cyl for a 75-79 C20 app Burb w/13" vac brakes & uses the stock prop valve. I considered the disc swap based on the cost factor since I had to replace just about all of the parts but in the end I really felt the big arse drums on these things would suffice so I kept it simple. The OE bias valve for the rear brakes was removed.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-28-2014, 06:07 PM   #31
SCOTI
SCOTI's Avatar
I liked the current wheels because of the caps. No scrubbing between the lugs....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-29-2014, 09:33 AM   #32
aggie91
aggie91's Avatar
I kinda like those with the caps, bet they would really pop with some polishing...
Karl
The LST Challenge:
Old 08-29-2014, 05:51 PM   #33
Drewkimble48
looks pretty awesome man. My buddy with a 86 crew cab dually would be pretty jealous, especially it being red too and all that suspension work you've done.
Drewkimble48 is offline   Reply With Quote
Old 08-30-2014, 08:22 PM   #34
SCOTI
SCOTI's Avatar
I appreciate the good vibes guys!
So I got the a-arms back late Wed night. I started cutting the bump stops off Thursday as well as laying out my cut lines & Friday I picked up the re-chromed OE front bumper.
Today I chased down all new bumper bolts as the ones that came off had seen better days. Once back @ the shop, I got the bumper back on but it will need to come back off again to open up some holes & allow adjustments (needs to be pulled back 1/2" on the pass side to equal the driver side).
Then I moved on to the a-arms.
Drilled holes for the corners to minimize stress related issues....
Cut the spring pockets out....
Cleaned everything up & removed the remaining shock gusset on the bottom....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-09-2014, 11:36 PM   #35
SCOTI
SCOTI's Avatar
One almost done. The inner structure is welded on the outside seams now. I dropped it back into the 'pocket' & everything still fits well. This allows the front bags to be @ their spec'd height (~6") with the gap currently between my current lower a-arms & the bottom of the x-member @ ride height (~4.5-5"). There's approx 1/2" clearance between the bag & the sides.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-11-2014, 10:24 AM   #36
Low Elco
Looks goood to me! Please continue, we all enjoy it.
Low Elco is offline   Reply With Quote
Old 09-11-2014, 10:35 AM   #37
SCOTI
SCOTI's Avatar
Since you asked..... 2nd side prepped. They're ready for welding this weekend.
Now to research sway bar options....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-11-2014, 12:09 PM   #38
lolife99
67-72 parts collector,…
lolife99's Avatar
Scot,... can you run an "end-link" style sway bar (Addco), by welding a tab to the front side of your control arm?
Keith
Convert to disc brakes.
Old 09-11-2014, 12:42 PM   #39
SCOTI
SCOTI's Avatar
That's the plan. Fab a mount the can be welded inside/outside of the arm w/end links vs the OE bushing arrangement. I was looking @ Addco & RideTech as possible replacement sources.
*Edit* It appears the largest bar Addco offers for the 73-87 square body is 1 1/8". I'd prefer 1.25" as the minimum.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-11-2014, 01:00 PM   #40
Low Elco
Check this out-Might help
http://67-72chevytrucks.com/vboard/s...563833&page=49
Old 09-11-2014, 01:05 PM   #41
bigblock73
yeller
bigblock73's Avatar
Nice work on the A-arm fab! My only concern would be the amount of dirt, gravel, water and debris that will collect in them...leading to corrosion and maybe even bag damage. Would it make sense to open up the four corners just a tad, to allow some of this stuff to escape out the bottom?
bigblock73 is offline   Reply With Quote
Old 09-11-2014, 01:13 PM   #42
SCOTI
SCOTI's Avatar
Holes will be drilled in the corners to allow necessary drainage.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-11-2014, 04:33 PM   #43
aggie91
aggie91's Avatar
Scot - The Addco bar I used in Korbin's truck was 1.25" diameter. I got it thru Travis at ProPerformance. It is a PBFab bar for the PB Forward Arms I put on that truck.
I think you could make it work...If I was closer or you could wait till early October, you could borrow it for a test fit...I am planning to go to GG's at TMS October 4th and 5th.
Karl
The LST Challenge:
Old 09-11-2014, 05:04 PM   #44
SCOTI
SCOTI's Avatar
I can wait to validate fit. But..... I'll be on vacation the week before GG's & will actually be returning from out of town that Saturday morning (Oct 4) so timing might be a possible issue.
I do plan to be @ the show Sat though. I remember when he did the install but will go back through the thread for a 2nd look.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-12-2014, 09:38 AM   #45
aggie91
aggie91's Avatar
OK, sounds good. Maybe we can touch base before you leave out on Vacation.
On the initial install that is in the thread, we put it in using an existing hole in the frame for the frame mounts, we should have moved it forward 1/2"-3/4" to avoid some interference when laid out. But since we only ran it at a set height, it worked really well.
Karl
The LST Challenge:
Old 09-12-2014, 11:15 AM   #46
SCOTI
SCOTI's Avatar
Well.... I jumped the gun.
I just ordered a Bell Tech 1 3/8" bar. It was about the same price as the Addco units & available to ship immediately (I've heard of shipping delays from Addco/PB units) so I didn't want to get mixed up in that. I couldn't justify the additional expense for the Ride Tech 1.25" Muscle Rar (although I do like their end links).
The down side to this kit is it's a silver bar w/red bushings. My uber analness won't allow red bushings so I ordered some black ones while clicking away. To my door @ $200. I'll fab my own sway bar tab on the arms & will install the frame mounts where the bar dictates once attached to the arms (relocating if necessary). Since I'm doing the caster mod, the frame attachment point will change....
The arms are fully welded now too
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-13-2014, 10:07 PM   #47
COS399
COS399's Avatar
Subscribed and can't wait to see this one.
One of these years I plan on redoing my 88 R30.
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 09-14-2014, 02:46 AM   #48
SCOTI
SCOTI's Avatar
Cleaned up the weld slag today & then started trimming the lower arms for the caster mod. I trimmed them enough to yield 3/4" forward shift... But, to be honest I'm not liking how close things are between the lower arms & x-member even after the clearancing.
I really want some PB 1" forward arms but trying to keep this thing @ low/no budget. The caster mod helps drivability & front wheel position (somewhat). I just don't want to open another can-o-worms so I'll keep pushing forward. New lower shaft kits are scheduled to be delivered on Monday so I'll mock things up again to see if the budget approach will work.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-14-2014, 08:33 AM   #49
lolife99
lolife99's Avatar
What about moving the balljoint pocket forward on the a-arm?
(instead of doing it from the cross shaft end)
Plate it top and bottom and call it good.
Keith
Old 09-14-2014, 04:35 PM   #50
bluex
bluex's Avatar
What thickness of plate did you use to "cup" the arms? Does the pocket hang down further than the lowest point of the arms? I'm thinking of doing that to mine when its apart for the frame swap. Might have the crossmember sectioned as well. The only problem with that is then the front will drop lower than the rear lol. If you can could you post a picture of the bottom side of the arm?
bluex is offline   Reply With Quote
